0 Replies Latest reply on Jun 3, 2017 7:20 PM by alanb27747612
    FlashBuilder generated swf files are different
      I am using FlashBuilder to create flash file to show streaming video.  Please see the following code:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="1280" minHeight="720">
              <!-- Place non-visual elements here, for example, services and value objects -->
                  import mx.events.FlexEvent;
                  import org.osmf.net.StreamingURLResource; import org.osmf.net.FMSURL;
                  protected function vp_preinitializeHandler(event:FlexEvent): void
                      var myURL:StreamingURLResource = new StreamingURLResource("http://www.sample-videos.com/video/mp4/720/big_buck_bunny_720p_1mb.mp4");
                      myURL.urlIncludesFMSApplicationInstance = true;
                      myVideoPlayer.source = myURL;
          <s:VideoPlayer id="myVideoPlayer" autoPlay="true" preinitialize="vp_preinitializeHandler(event)"  x="2" y="2"  height="100%" width="100%" />
      After I click Menu >> Project >> "Export Release Build", FlashBuilder generates a swf file, which looks fine.  However, I found that the swf file changed EVEN IF I did not change any code.  In other words, the same code generates different swf files in each "Export Release Build" click.  I used command line fc to compare the generated swf files and confirmed each file is different.
      I installed FlashBuilder of the newest version (ver 4.7 from Adobe). I wonder why the same code generates different swf files, and what kind of information is included in those different swf files.
      Your help is greatly appreciated.
