"Could not use the healing brush because the source document has a different bit depth." Photoshop
Are you cloning from one document to another?
If so both documents need to be at the same bit depth e.g. 8 bit or 16 bit. Check each in Image Mode
No, not cloning from one to another. I have a single image in 16 bit but I keep getting the same message and have no idea how to correct the discrepancy.
gettting an error message using "Place embedded" can anyone help?
I'm trying to remove wrinkles from a neck with the healing brush, but I keep getting the
message. I have tried the 8, 16 and 32 bit selections under the Image>Mode dropdown,
but it doesn't work on any of the three settings.
open the brush type options and select the soft round brush. this will solve your problem
