8 Replies Latest reply on Jun 9, 2017 3:25 AM by BjornEricsson
    Assembler issue: Masterpage definition in XDP?
    BjornEricsson Level 1
      Background
      I'm working on a process that combines XDPs with an DDX and Assembler Service. Now I have come across a situaition where if I combine two specific XDPs (each with its own Masterpages) then the last one (the one that gets included into the other) will loose its Connection to its Masterpage and instead use the Masterpage of the first one. This is also shown when I view the combined XDP in Designer. The pattern I have found is that the problem occurs when a form withut pagination element (xdp/config/present/pagination) is combined with one that does have it. Then the first form will dictate that there will be no pagination element and the second one will suffer. I hope that I will be able to fix this with XSLT when I have understood what should be fixed and when.
      My questions:
      1. How do I read the Masterpage Connection in the XML of the XDP?
      2. Have sombody else had the same issue and found a fix?
      /Björn
      who likes the new forum where formatting works with IE.
