4 Replies Latest reply on Jun 7, 2017 4:37 AM by Mattmcquiff
    Alter a script help please. Golden Ratio Scpt.
    Mattmcquiff Level 1
      Hi I have downloaded this script.
      Golden Crop for Photoshop - FAQ
      And I have been able to alter the script for my own overlay.
      Its quite an in depth script but super useful.
      I have a few more changes that I would like to put in place.
      prior to the crop make the canvas fit the ratio of 2:3 and expand where required.
      When you transform the crop mask I would like the width and height linked. (fixed ratio) I think it can be found around line 2123 (I'm guessing this is where I might need to be place it.
      Can the transforms anchor point be changed to a specific location? That point would be x=(w/2), y=(131/408)*h  Where w and h are the original dimensions.
      Also with the last menus prompts 'Canvas extension detected' can this be default to [A] and choose Crop style be defaulted to [1] so that there are less prompts.
      A lot to ask, but I am not too familiar with the photoshop script more with applescript.
      Many Thanks
      Matt
        • 1. Re: Alter a script help please. Golden Ratio Scpt.
          Jarda Bereza Level 4
          You don't need script for this. This is already built-in Photoshop.
          • 2. Re: Alter a script help please. Golden Ratio Scpt.
            Mattmcquiff Level 1
            This doesn't allow a custom overlay. True everything in the old script is in the CC however I said I managed to alter the code for a custom overlay. I need to move the anchor point to the centre of my cross but, by default and lock the aspect ratio.
            • 3. Re: Alter a script help please. Golden Ratio Scpt.
              You probably could replace opening transform mode with my code. You can set some default values for transformation mode.
              var idTrnf = charIDToTypeID( "Trnf" );
                  var desc59 = new ActionDescriptor();
                  var idFTcs = charIDToTypeID( "FTcs" );
                  var idQCSt = charIDToTypeID( "QCSt" );
                  var idQcsi = charIDToTypeID( "Qcsi" );
                  desc59.putEnumerated( idFTcs, idQCSt, idQcsi );
                  var idPstn = charIDToTypeID( "Pstn" );
                      var desc60 = new ActionDescriptor();
                      var idHrzn = charIDToTypeID( "Hrzn" );
                      var idPxl = charIDToTypeID( "#Pxl" );
                      desc60.putUnitDouble( idHrzn, idPxl, 202.000000 ); // anchor X
                      var idVrtc = charIDToTypeID( "Vrtc" );
                      desc60.putUnitDouble( idVrtc, idPxl, 141.000000 ); // anchor Y
                  var idPnt = charIDToTypeID( "Pnt " );
                  desc59.putObject( idPstn, idPnt, desc60 );
                  var idLnkd = charIDToTypeID( "Lnkd" );
                  desc59.putBoolean( idLnkd, true ); // keep aspect ratio
              executeAction( idTrnf, desc59, DialogModes.ALL ); //DialogModes.ALL = keep transform mode open
              • 4. Re: Alter a script help please. Golden Ratio Scpt.
                Mattmcquiff Level 1
                I had a look in the code and this is the area I believe the transform takes place.
                I tried to sandwich the line in after line 11
                1. var idLnkd = charIDToTypeID( "Lnkd" );
                2.     desc59.putBoolean( idLnkd, true ); // keep aspect ratio
                But the that ddin't work for me and caused the script to stop wrk (no specific error as it is running from within photoshop )
                Matt
                Stdlib.userGoToFreeTransform = function(doc, layer) {
                    function _ftn() {
                        function preMove() {
                            var desc = new ActionDescriptor();
                            var lref = new ActionReference();
                            lref.putEnumerated(cTID("Lyr "), cTID("Ordn"), cTID("Trgt"));
                            desc.putReference(cTID("null"), lref);
                            desc.putEnumerated(cTID("FTcs"), cTID("QCSt"), cTID("Qcsa"));
                                var desc75 = new ActionDescriptor();
                                desc75.putUnitDouble( cTID('Hrzn'), cTID('#Pxl'), 1.000000 );
                                desc75.putUnitDouble( cTID('Vrtc'), cTID('#Pxl'), 1.000000 );
                            desc.putObject( cTID('Ofst'), cTID('Ofst'), desc75 );
                            executeAction(cTID("Trnf"), desc, DialogModes.NO);
                        function retPostMoveDesc() {
                                desc75.putUnitDouble( cTID('Hrzn'), cTID('#Pxl'), -1.000000 );
                                desc75.putUnitDouble( cTID('Vrtc'), cTID('#Pxl'), -1.000000 );
                            return desc;
                        var state = true;
                        preMove();
                        var lvl = $.level;
                        $.level = 0;
                        try {
                          executeAction(cTID("Trnf"), retPostMoveDesc(), DialogModes.ALL);///ALL
                        } catch (e) {
                          state = false;
                          if (e.number != 8007) { // if not "User cancelled"
                            throw e;
                          executeAction(cTID("Trnf"), retPostMoveDesc(), DialogModes.NO);
                        } finally {
                          $.level = lvl;
                    return state;
                    return Stdlib.wrapLCLayer(doc, layer, _ftn)
