3 Replies Latest reply on Jun 5, 2017 3:20 PM by try67
    Combined pdfs have different page sizes
    nfotx6708 Level 1
      When I combine pdfs into one "Binder" often the pages appear in different sizes although everything began as 8 1/2 x 11" paper.  Is there a method for making all pages of a pdf the same size.  It does not present a very professional appearance - looks kind of dorky.Screen Shot 2017-06-05 at 1.53.41 PM.png
        • 1. Re: Combined pdfs have different page sizes
          If that's the case it means the files didn't have the same page size in the first place. Acrobat does not modify the page sizes when combining files, not to make them identical and certainly not to make them different from one another...
          • 2. Re: Combined pdfs have different page sizes
            nfotx6708 Level 1
            To try67,
            Thanks, but they were the same size.  Perhaps it is due to different originating systems.  Or, because I used “Comments” on each page, then saved, then “Combine files into one pdf . . .” it made the page sizes different.  Is there a way to know what Acrobat “sees” as the page size before performing the “combine” function?
            • 3. Re: Combined pdfs have different page sizes
              Maybe they look the same, but are not. You need to look at the zoom level you're at, not just at the size of the page on the screen...
              And adding comments has no influence on the page size.
              To see the actual page size go to Edit - Preferences - Page Display and tick the box that says "Always show document page size".
              Then it will appear at the bottom left corner of each page you open, for example:
