3 Replies Latest reply on Jul 25, 2017 4:28 PM by Kevin-Monahan
    Moving Objects and/or Particles first controlled, then randomly?
    Reiner_M Level 1
      I am looking for a 2 ways to animate a lot of layers/texts...
      I would like to know about: first using expressions, second using TC Particular.
      First:
      I am using this expression:
      tMin = .25; //minimum segment duration
      tMax = 1.0; //maximum segment duration
      minVal = [0.1*thisComp.width, 0.1*thisComp.height];
      maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
      end = 0;
      j = 0;
      while (time >= end){
        j ++;
        seedRandom(j,true);
        start = end;
        end += random(tMin,tMax);
      endVal =  random(minVal,maxVal);
      seedRandom(j-1,true);
      dummy = random(); //this is a throw-away value
      startVal =  random(minVal,maxVal);
      ease(time,start,end,startVal,endVal)
      It moves around the object/text randomly from one to next position. How can I define the starting position. I would like to have control of the movement first (by using keyframes or moving along a path) and at a certain time make the object move randomly / drifting.
      Second: I would like to achive the same with Particular.
      The first part of the movement of the particles (not the emitter) should be straight upwards. After a while (let's say half the screensize), the particles should start to move randomly in space / drift.
      I don't understand how to do it. I have a Point-Emitter.  Using direction "Directional" makes them drift out of the Composition. Moving along a path makes them stop at the end of the path and "Air Resistance" can't be changed with keyframes. I am not very firm with Particular I must admit...
      Thanks!
