1 Reply Latest reply on Oct 17, 2008 8:29 PM by Newsgroup_User
    feature request - Akima spline curves for vector graphics
    jmichae1 Level 1
      Akima spline curves give drawing freedom, at least some kind of interpolating spline curve where you can just simply lay the points down and the curve follows along the points - I can't get bezier curves to do what I want. It's like
      Alice in wonderland using a flamingo for a mallet in a game of croquet. unweildly.
      Bezier Curves were introduced into Windows NT and all windows NT family products after that. It
      soon followed that all paint programs began including Bezier Curves as a drawing method. Big
      mistake. They should have introduced Akima spline curves into Windows. I am not saying take
      Bezier curves out - I am saying Add Akima Spline curves, or the bettered (modified) version of
      Akima Spline curves that doesn't react as much. At least some type of interpolating spline curve
      where you just lay the points down and the curve follows the points.
      Akima spline curves are cool. just put points along where you want the curve. simple. you just
      need more points around sharp edges, or you get a "ringing" effect around that area. (See
      discussion and visuals link).
      part of the challenge of using Akima spline curves is that the first 2 data points must be faked
      or dropped. same goes with the last data point. this can be taken care of with some simple
      engineering tricks.
      http://en.wikipedia.org/wiki/Spline_(mathematics)
      Wikipedia article on Spline curves (mathematics). This does not cover the Akima Spline, which
      keeps its curve along the data points rather than just near it like a B-spline curve does.
      http://www.cse.unsw.edu.au/~lambert/splines/
      demonstration of the various curve types in action. (requires Java) play with the spline curve for
      a while (delete the existing points other than 0 first to get started)
      http://demonstrations.wolfram.com/BSplineCurveWithKnots/
      B-Spline curve with Knots (can be active demo)
      GNU Scientific Library Reference Manual
      http://www.network-theory.co.uk/docs/gslref/InterpolationTypes.html
      book - has Akima Spline & Cubic Spline. See also
      http://www.gnu.org/software/gsl/manual/html_node/Interpolation-Types.html
      GNU Manual
      http://www.iop.org/EJ/abstract/0031-9155/18/4/306
      PDF file from medical site on akima and spline methods and its associated errors. Recommendations
      for fixing the significant overshoot on abrupt changes, and suggestion to use more closely spaced
      points around those regions. must purchase.
      http://portal.acm.org/citation.cfm?id=116810
      The Akima Univariate Interpolation Method (spline) article from the acm. by Hiroshi Akima.
      requires web account and probably money to buy the PDF article.
      http://www.iue.tuwien.ac.at/phd/rottinger/node60.html
      Equations for Akima Spline
      http://www.alglib.net/interpolation/spline3.phpdiscussion and visuals of Akima Spline and its
      drawbacks. also has source code in C++, C#, Delphi, VB6, Zonnon.
      http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TYG-414N645-
      2&_user=10&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000050221&_version=1&_urlVersi on=0&_us
      erid=10&md5=17dccffcfa40e5b420c7c377fc24b5f7
      pay-for article on some sort of improved-smoothness spline. Shape of data is preserved.
      http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=1814&objectType=f ile
      MATLAB model.
      http://en.wikipedia.org/wiki/Spline_(mathematics) http://www.cse.unsw.edu.au/~lambert/splines/
