For PDF, 1.7 with Adobe extensions level 3
PDF Reference and Adobe Extensions to the PDF Specification | Adobe Developer Connection
PDF/X-5 is based on PDF 1.6
Thanks! I appreciate it so much!
Actually, both PDF/X-4 and PDF/X-5 are the most recent PDF/X versions, created and published by ISO on the exact same date in 2008 with a slight revision in 2010. They serve very separate purposes, though.
PDF/X-5 is for special purposes where not all the graphic or profile content is in the PDF file itself. PDF/X-5g allows use of reference XObjects, PDF graphics brought in during display or print from other locations. PDF/X-5pg further provides not only for referenced XObjects, but also reference Output Intent profiles. PDF/X-5n allows for n-color output intents external to the PDF files. For 99.999999% of users, PDF/X-5 is totally irrelevant. (In fact we know of no applications that actually produce PDF/X-5g and PDF/X-5pg.
PDF/X-4 is the mainstream PDF/X standard recommended by Adobe and anyone in the graphics industry who really understands reliable PDF print publishing workflow. It allows and encourages use of ICC color management (keep your artwork and images in their original RGB with ICC profiles color spaces) and live transparency. Only Luddites would advise or require PDF/X-1a, a great standard for the 1990s! PDF.X-4 is supported by Adobe Illustrator, InDesign, Photoshop, Acrobat, and all RIPs/DFEs supporting direct PDF printing via the Adobe PDF Print Engine.
FWIW, ISO TC130 is currently working on the PDF/X-6 standard based on ISO 32000-2 PDF 2.0.
The PDF 2.0 standard is expected to be published by ISO within the next few weeks. PDF/X-6 is probably 2 years off until publication and availability of applications to generate same.
- Dov
(Chair, ISO TC130 WG2/TF2 - PDF/X)
In fact about the PDF / X I don't knew it until I start to work in a Labels company and I started to know about this.
I don't understand everything (and the information in spanish is limited) but I'm still studying and reading and asking and everything as I need.
thanks a lot!
