3 Replies Latest reply on Jun 7, 2017 7:15 AM by CMcDowall
    Paths always inverted wrong way
    CMcDowall Level 1
      Scenerio: I use the pen tool to create a simple path. In the paths palette is shows up as a work path. I select the work path, then at the bottom of the path palette click on the "Load path as a selection" - and the selection is made on the image area. When I fill or paint, it floods the area OUTSIDE my path, to the edges of the image. To work INSIDE the path, I must inverse the selection, every time, over and over, all day long.  It did not used to be that way.
      Does anyone know how to make the active area INSIDE the path, like it was a version or two ago ?
      Many gracias.
      Craig
