• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RoboHelp 2017 not publishing on RoboServer 10
Community Beginner ,
Jun 06, 2017 Jun 06, 2017
Hello I've Installed Robohelp 2017 and server 10. When I try to publish on the server it keeps failing.
The server is running and I was able to log in.
I use this URL (http://localhost:8080/robohelp/server )  for the server name since both Robohelp & sever are on same PC.
Please advice thank you!
Views
564
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Jun 21, 2017 Jun 21, 2017
Tnx to Ajit from Adobe support I was able to publish my project to the Robo Server.
Problem was that I had 32bit Java while my Tomcat was 64bit. So tomcat was not working properly.
Votes
Translate
Translate
Advisor ,
The server URL looks correct for a localhost scenario.
From your browser, did you login with this URL:
http://localhost:8080/robohelp/admin/login.jsp
If you were able to login with the default credentials, then everything should be working.
Had you used the web admin application to create any new Areas, or are you just using the default "General" area?
Sometimes I've noticed that in creating a new Server Publishing Setting I inadvertently forget to make sure I re-enter the Username and Password. You might check that.
Also see if there are any errors showing up in your "Output View" pod after you generate and publish.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
John Daigle
Newport, Oregon
Votes
Translate
Translate
Report
Report
Jun 07, 2017 Jun 07, 2017
Still unsuccessful and frustrated, Does not want to workout.
I even created a new area.
"Added result path to RoboHelp.cfg
Finished compiling WebHelp Pro output (for RoboHelp Server) in 3 sec(s)
Warning: Failed to publish to "RoboHelp Server". reason: Unable to connect to the RoboHelp server on http://localhost:8080/Robo. If RoboHelp Server is not being used, generate WebHelp instead. More information on RoboHelp Server is available in the help file..
Votes
Translate
Translate
Report
Report
Advisor ,
I can tell from your screenshot that somehow your URL got messed up. Also, if you create a new Area, you need to "refresh" the list and select it as shown in the screenshot.
John Daigle
Evergreen, Colorado
John Daigle
Newport, Oregon
Votes
Translate
Translate
Report
Report
Jun 08, 2017 Jun 08, 2017
John,
No luck, I've tried almost everything. It just not connecting.
http://localhost:8080/robohelp2
Tomcat server
Im logged in fine.
Votes
Translate
Translate
Report
Report
LATEST
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
