• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Mp4 video does not load/play in preview or in LMS - tried different formats.
New Here ,
Jun 07, 2017 Jun 07, 2017
I've tried and searched for similar topics, all I found was a discussion that included a HTML5 version of a learning project.
I have a problem with several videos, that are in .mp4 format, that just won't load nor play, even in preview. I've checked whether they are copy protected or otherwise restricted, but they weren't. Also conversion into .flv didn't solve my problem. The videos are not larger than 10 MB.
All I get is the loading bar in the top left of the video-window.
Is there anyone who encountered the same?
Thanks for your help.
TOPICS
Audio and video
Views
6.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here , Jun 09, 2017 Jun 09, 2017
Thanks for your suggestion. I finally found out, after A LOT of trial and error. That the problem wasn't my videos. Well, actually they were, BUT: Adobe never specified anywhere that you only can use MPEG encoded MP4-video files to add into your projects. I re-encoded every video file that I had, and now it works, on the captivate prime based LMS.
Whoever experiences a similar kind of problem: Captivate will not accept H.264 encoded MP4 files, which I find rather strange, but it will accept MPEG
Votes
Translate
Translate
Community Expert ,
Have you tried uploading your SCORM zips to SCORM Cloud to test on their platform?  That will tell you whether the issue is with your project or your LMS.  The issue with MP4's not playing locally might be due to browser security.  HTML5 course content should always be tested from a web server environment.  You get that with SCORM Cloud as well.  No cost involved.
Votes
Translate
Translate
Report
Report
New Here ,
Whoever experiences a similar kind of problem: Captivate will not accept H.264 encoded MP4 files, which I find rather strange, but it will accept MPEG encoded ones. It will then, when publishing the project, convert them into FLV files, which then, surprisingly work with Captivate Prime.
ALSO: don't try MOV files, they are not even recognized by captivate..
But thanks for your suggestion, I am sure that would've helped as well.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 19, 2018 Mar 19, 2018
I have this same problem.
What are you converting your files to and how?
I can't figure out how to make a MPEG encoded MP4
Captivate doesn't recognize .MPEG .
James
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Captivate ships with another application called the Adobe Media Encoder.  You can use this app to encode video files in many different formats to MP4 so that they can then be inserted into Captivate.
Votes
Translate
Translate
Report
Report
Resources
Help resources
