I am having the same problem. With every pdf file I convert to Word, there are spelling, spacing, and font errors. I have Adobe PDF pack. Is there a solution to this problem. I spend a long time trying to correct all the errors in the converted document and sometimes, when there is "computer language" I am unable to correct the errors at all.
Thanks.
Hi ginnym49,
Sorry for the delay in response.
As you are experiencing the issue in exporting PDF, did you try to export PDF online?
If not, please try once to export PDF online here: https://cloud.acrobat.com/exportpdf
Check if you get the same result.
If you still experience the issue, can you share any one file with us?
You may refer the steps provided here to share the file: How to share a document
Let us know if you need any help.
Regards,
Meenakshi
