In the admin CFIDE server mode, I want to set up couple WSDL URLs that uses axis version 1. I changed the web server version to 1 but I still get the following messages on the log
Using Axis 2 for consuming the service http://local.domain.com/MembershipWebservice.asmx?WSDL
Downloaded the wsdl http://local.domain.com/MembershipWebservice.asmx?WSDL
Next is the error log
Cannot generate stub objects for web service invocation. Name: http://imisappprod/iMIS/AsiCommon/Services/Membership/MembershipWebservice.asmx. WSDL: http://imisappprod/iMIS/AsiCommon/Services/Membership/MembershipWebservice.asmx?WSDL. org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.databinding.UnmatchedTypeException: No type was mapped to the name propertyValue with namespace SetPropertyValue_input It is recommended that you use a web browser to retrieve and examine the requested WSDL document to ensure it is correct. If the requested WSDL document cannot be retrieved or is dynamically generated, it is likely that the target web service has programming errors.
Keep in mind that if I try to open the http://local.domain.com/MembershipWebservice.asmx?WSDL via the browser it works but it needs to consume using axis version 1.
thanks, Lou
Have something to add?
