14 Replies Latest reply on Nov 6, 2017 6:10 AM by ivan.gusyev
    photoshop scroll bar mac os sierra issue
    ivan.gusyev
      when scroll bar is used photoshop freezes/crashes. liquify filter was used for test. i am running latest version of ps 2017.1.1 and mac os sierra 10.12.5
      MacBook Pro (Retina, 15-inch, Mid 2015)
      2,2 GHz Intel Core i7
      16 ГБ 1600 MHz DDR3
      Intel Iris Pro 1536 МБ
      please fix this issue or recommend how to bypass it
      video and screenshot added
        • 1. Re: photoshop scroll bar mac os sierra issue
          Akash Sharma Adobe Employee
          Hi ivan.gusyev,
          Please post the crash report here, Reproduce the crash and post the report here so that we may identify the root cause,
          The freeze/crashes with Photoshop liquify normally occurs due to outdated/buggy GPU drivers.
          Akash
          • 2. Re: photoshop scroll bar mac os sierra issue
            ivan.gusyev Level 1
            how can i post crash report if actually it is not crashes, it is just freezes, loads my cpu up to 100% and does not respond for any actions? please check the video in attachments. i have just spent more than 2 hours with your friend Inderjeet Singh from customer support trying to find out the reason via remote desktop access (ticket #0189012423). but we had no luck. as i have already said the reason is not in outdated/buggy GPU drivers because i use the latest versions of mac os and ps. btw we also tried to disable gpu in ps settings - and again got no luck
            • 3. Re: photoshop scroll bar mac os sierra issue
              We're sorry you still having trouble after contacting customer support team. Please try creating a new root user account on your computer and check if it makes a difference. See Install or run Adobe applications in new user account | Mac OS X for instructions.
              Akash
              • 4. Re: photoshop scroll bar mac os sierra issue
                ivan.gusyev Level 1
                it was also already done during remote desktop session with customer support representative - no difference
                • 5. Re: photoshop scroll bar mac os sierra issue
                  S_Gans Adobe Community Professional
                  Hi. I just tested the same test as you did. I was wondering, since I only recently upgraded to Sierra 10.12.5 (also newest Photoshop). I tried scrolling in Liquify (on both a regular object and a smart object), and scrolling an open window. I had no problems. I'm even using an older Mac Pro  tower - in which I have a non-standard GPU (upgraded, using a GPU made for Windows and flashed to work with Mac), and it still worked for me. So, I kind of feel maybe the issue isn't with Photoshop at all, but maybe your system.
                  One thing that's worked for me for other problems in the past was that even when disabling/re-enabling the GPU made no difference, the setting under "Advanced Graphics Processor Settings" did help. When I had some problems before, changing the setting from Advanced to Normal seemed to help. Might be worth a shot.
                  Otherwise, I might suggest talking to someone at the Genius bar... I hate to say that, but after all you've been through with Adobe on this, there may be a Mac-based incompatibility you're experiencing? LUCK!
                  • 6. Re: photoshop scroll bar mac os sierra issue
                    ivan.gusyev Level 1
                    hi. thanks for the reply. just tested with normal mode - did not helped. and i am almost sure it is not mac-based incompatibility because all other apps it is running good and passed all stress tests like geekbench 4 and native MacBook selftest also fine
                    just now figure out that the problem actually is not in liquify filter only! i get the same issue using all other filters like adaptive wide angle, lens correction and vanishing point etc.. the only one place where the scroll bar is working fine is the main menu of ps (without no filters)
                    and this issue is only seen when the scroll bar is used (as shown in attachments). but when it is used mouse scroll wheel or trackpad gestures everything  works fine. so this fact makes me think again that the reason is in PS incompatibility but not in gpu or other hardware/drivers
                    • 7. Re: photoshop scroll bar mac os sierra issue
                      ivan.gusyev Level 1
                      i did not find any frame here to hide this huge logs so i post them directly here
                      Process:               Adobe Photoshop CC 2017 [1239]
                      Path:                  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
                      Identifier:            com.adobe.Photoshop
                      Version:               18.1.1 (18.1.1.252)
                      Code Type:             X86-64 (Native)
                      Parent Process:        ??? [1]
                      Responsible:           Adobe Photoshop CC 2017 [1239]
                      User ID:               501
                      Date/Time:             2017-06-09 12:12:24.787 +0300
                      OS Version:            Mac OS X 10.12.5 (16F73)
                      Report Version:        12
                      Anonymous UUID:        0B37F788-E957-6106-AF67-5C6F11FBC9FB
                      Sleep/Wake UUID:       0A519695-8028-4A62-AF07-84D98A1929E0
                      Time Awake Since Boot: 5700 seconds
                      Time Since Wake:       5400 seconds
                      System Integrity Protection: enabled
                      Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                      Exception Type:        EXC_CRASH (SIGABRT)
                      Exception Codes:       0x0000000000000000, 0x0000000000000000
                      Exception Note:        EXC_CORPSE_NOTIFY
                      Termination Signal:    Abort trap: 6
                      Termination Reason:    Namespace SIGNAL, Code 0x6
                      Terminating Process:   Activity Monitor [1238]
                      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                      0   com.apple.SkyLight             0x00007fffe59af79d SLEventGetIntegerValueField + 696
                      1   com.apple.AppKit               0x00007fffd1e2703d -[NSEvent _initWithCGEvent:eventRef:] + 1307
                      2   com.apple.AppKit               0x00007fffd2011c2e -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3884
                      3   com.adobe.Photoshop           0x0000000103103441 0x1011c3000 + 32769089
                      4   com.adobe.Liquify             0x000000016f04b349 0x16ee57000 + 2048841
                      5   com.adobe.Liquify             0x000000016ef75e70 0x16ee57000 + 1175152
                      6   com.apple.AppKit               0x00007fffd1fabe1b -[NSScroller mouseDown:] + 744
                      7   com.adobe.Liquify             0x000000016ef76b67 0x16ee57000 + 1178471
                      8   com.apple.AppKit               0x00007fffd218f24f -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
                      9   com.apple.AppKit               0x00007fffd218ba6c -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
                      10  com.apple.AppKit               0x00007fffd218af0a -[NSWindow(NSEventRouting) sendEvent:] + 541
                      11  com.apple.AppKit               0x00007fffd200f681 -[NSApplication(NSEvent) sendEvent:] + 1145
                      12  com.adobe.Photoshop           0x0000000103102c74 0x1011c3000 + 32767092
                      13  com.adobe.Photoshop           0x0000000103103b6a 0x1011c3000 + 32770922
                      14  com.adobe.ps.spaces           0x0000000116f04a3d 0x116ede000 + 158269
                      15  com.apple.AppKit               0x00007fffd1aec0f8 -[NSApplication _doModalLoop:peek:] + 563
                      16  com.apple.AppKit               0x00007fffd1ccc374 __35-[NSApplication runModalForWindow:]_block_invoke + 64
                      17  com.apple.AppKit               0x00007fffd1ae9b98 -[NSApplication runModalForWindow:] + 137
                      18  com.adobe.Photoshop           0x0000000103102aa8 0x1011c3000 + 32766632
                      19  com.adobe.Liquify             0x000000016efa0c9d 0x16ee57000 + 1350813
                      20  com.adobe.Liquify             0x000000016eecea17 0x16ee57000 + 490007
                      21  com.adobe.Liquify             0x000000016eed10a5 0x16ee57000 + 499877
                      22  com.adobe.Liquify             0x000000016efee3b5 0x16ee57000 + 1668021
                      23  com.adobe.Liquify             0x000000016efeeb12 0x16ee57000 + 1669906
                      24  com.adobe.Photoshop           0x0000000101eddb5d 0x1011c3000 + 13740893
                      25  com.adobe.Photoshop           0x00000001018e3252 0x1011c3000 + 7471698
                      26  com.adobe.Photoshop           0x00000001018e5eb2 0x1011c3000 + 7483058
                      27  com.adobe.Photoshop           0x00000001018e0182 0x1011c3000 + 7459202
                      28  com.adobe.Photoshop           0x00000001018e7265 0x1011c3000 + 7488101
                      29  com.adobe.Photoshop           0x0000000101f6a3e5 0x1011c3000 + 14316517
                      30  com.adobe.Photoshop           0x0000000101f6aef3 0x1011c3000 + 14319347
                      31  com.adobe.Photoshop           0x00000001018e009e 0x1011c3000 + 7458974
                      32  com.adobe.Photoshop           0x0000000101f661b1 0x1011c3000 + 14299569
                      33  com.adobe.Photoshop           0x0000000101f669e2 0x1011c3000 + 14301666
                      34  com.adobe.Photoshop           0x00000001018dfb07 0x1011c3000 + 7457543
                      35  com.adobe.Photoshop           0x00000001018e73c2 0x1011c3000 + 7488450
                      36  com.adobe.Photoshop           0x000000010198bcf5 0x1011c3000 + 8162549
                      37  com.adobe.Photoshop           0x0000000101278fdd 0x1011c3000 + 745437
                      38  com.adobe.Photoshop           0x000000010127883f 0x1011c3000 + 743487
                      39  com.adobe.Photoshop           0x0000000101286755 0x1011c3000 + 800597
                      40  com.adobe.Photoshop           0x0000000101261f9b 0x1011c3000 + 651163
                      41  com.adobe.Photoshop           0x0000000101261db8 0x1011c3000 + 650680
                      42  com.adobe.Photoshop           0x0000000103103c02 0x1011c3000 + 32771074
                      43  com.adobe.ps.spaces           0x0000000116f04aba 0x116ede000 + 158394
                      44  com.apple.AppKit               0x00007fffd188a427 -[NSApplication run] + 1002
                      45  com.adobe.Photoshop           0x00000001031045a2 0x1011c3000 + 32773538
                      46  com.adobe.Photoshop           0x0000000103105928 0x1011c3000 + 32778536
                      47  com.adobe.Photoshop           0x000000010126268d 0x1011c3000 + 652941
                      48  com.adobe.Photoshop           0x00000001015da7df 0x1011c3000 + 4290527
                      49  com.adobe.Photoshop           0x00000001015daa69 0x1011c3000 + 4291177
                      50  libdyld.dylib                 0x00007fffe9515235 start + 1
                      Thread 1:: MPSupport Worker
                      0   libsystem_kernel.dylib         0x00007fffe9643bf2 __psynch_cvwait + 10
                      1   libsystem_pthread.dylib       0x00007fffe972f7fa _pthread_cond_wait + 712
                      2   MultiProcessor Support         0x000000011348d0fb 0x113443000 + 303355
                      3   MultiProcessor Support         0x000000011348d01b 0x113443000 + 303131
                      4   MultiProcessor Support         0x00000001134ae7a6 0x113443000 + 440230
                      5   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      6   libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      7   libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 2:: MPSupport Worker
                      Thread 3:: MPSupport Worker
                      Thread 4:: MPSupport Worker
                      Thread 5:: MPSupport Worker
                      Thread 6:: MPSupport Worker
                      Thread 7:: MPSupport Worker
                      Thread 8:: VulcanMsgRecv
                      0   libsystem_kernel.dylib         0x00007fffe9643df6 __recvfrom + 10
                      1   VulcanMessage5.dylib           0x000000010cac8308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
                      2   VulcanMessage5.dylib           0x000000010cac76cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
                      3   VulcanMessage5.dylib           0x000000010cac69c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
                      4   VulcanMessage5.dylib           0x000000010cac6888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
                      5   VulcanMessage5.dylib           0x000000010cac14c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
                      6   VulcanMessage5.dylib           0x000000010cac1f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
                      7   VulcanMessage5.dylib           0x000000010cac18ef vcfoundation::io::Serializer::Deserialize() + 9
                      8   VulcanMessage5.dylib           0x000000010cac5974 vcfoundation::ncomm::Connection::ReadIn() + 22
                      9   VulcanMessage5.dylib           0x000000010cac53cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
                      10  VulcanMessage5.dylib           0x000000010cac50ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
                      11  VulcanMessage5.dylib           0x000000010cac500d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
                      12  VulcanMessage5.dylib           0x000000010cab8848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
                      13  VulcanMessage5.dylib           0x000000010cab7a86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
                      14  VulcanMessage5.dylib           0x000000010cac620c vcfoundation::thread::AbstractThread::Run() + 72
                      15  VulcanMessage5.dylib           0x000000010cac8109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
                      16  libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      17  libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      18  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 9:
                      0   libsystem_kernel.dylib         0x00007fffe963c386 semaphore_wait_trap + 10
                      1   libtbb.dylib                   0x00000001089a8100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
                      2   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      3   libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      4   libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 10:
                      Thread 11:
                      Thread 12:
                      Thread 13:
                      Thread 14:
                      Thread 15:
                      Thread 16:: BridgeTalk
                      0   libsystem_kernel.dylib         0x00007fffe9643f46 __semwait_signal + 10
                      1   libsystem_c.dylib             0x00007fffe95cab72 nanosleep + 199
                      2   com.adobe.PSAutomate           0x000000011698fce8 0x1167bc000 + 1916136
                      3   com.adobe.PSAutomate           0x0000000116971b5c 0x1167bc000 + 1792860
                      4   com.adobe.PSAutomate           0x000000011698f871 0x1167bc000 + 1914993
                      Thread 17:: com.apple.NSEventThread
                      0   libsystem_kernel.dylib         0x00007fffe963c34a mach_msg_trap + 10
                      1   libsystem_kernel.dylib         0x00007fffe963b797 mach_msg + 55
                      2   com.apple.CoreFoundation       0x00007fffd3d9c434 __CFRunLoopServiceMachPort + 212
                      3   com.apple.CoreFoundation       0x00007fffd3d9b8c1 __CFRunLoopRun + 1361
                      4   com.apple.CoreFoundation       0x00007fffd3d9b114 CFRunLoopRunSpecific + 420
                      5   com.apple.AppKit               0x00007fffd19e2f02 _NSEventThread + 205
                      Thread 18:
                      2   com.adobe.headlights.LogSessionFramework 0x000000010bbe0ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                      3   com.adobe.headlights.LogSessionFramework 0x000000010bbdf5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
                      4   com.adobe.headlights.LogSessionFramework 0x000000010bb8d059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
                      5   com.adobe.headlights.LogSessionFramework 0x000000010bb5bcfb RealTimeProcessor::WorkerThread(int, int) + 3633
                      6   com.adobe.headlights.LogSessionFramework 0x000000010bbde969 boost::(anonymous namespace)::thread_proxy(void*) + 185
                      7   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      8   libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      9   libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 19:: com.apple.NSURLConnectionLoader
                      5   com.apple.CFNetwork           0x00007fffd2ed9734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
                      6   com.apple.Foundation           0x00007fffd57beb3d __NSThread__start__ + 1243
                      Thread 20:
                      2   com.adobe.headlights.LogSessionFramework 0x000000010bb8e152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
                      3   com.adobe.headlights.LogSessionFramework 0x000000010bb8d0db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
                      4   com.adobe.headlights.LogSessionFramework 0x000000010bb8cbae IdleTimeLogger::IdleTimeWorkerThread() + 2804
                      5   com.adobe.headlights.LogSessionFramework 0x000000010bbde969 boost::(anonymous namespace)::thread_proxy(void*) + 185
                      Thread 21:: Update Activation Menu Items
                      2   com.adobe.Photoshop           0x00000001015263a2 0x1011c3000 + 3552162
                      3   CITThreading                   0x000000010906605e boost::(anonymous namespace)::thread_proxy(void*) + 130
                      4   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      5   libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      6   libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 22:
                      2   libc++.1.dylib                 0x00007fffe80ae4cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
                      3   com.adobe.Photoshop           0x00000001011c82fd 0x1011c3000 + 21245
                      4   com.adobe.Photoshop           0x00000001011c8f5b 0x1011c3000 + 24411
                      5   com.adobe.Photoshop           0x00000001011c8d4e 0x1011c3000 + 23886
                      Thread 23:
                      Thread 24:
                      Thread 25:
                      Thread 26:: NetworkConfigWatcher
                      5   com.apple.Foundation           0x00007fffd57ae4e2 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
                      6   org.chromium.ContentShell.framework 0x000000014192eeee 0x14038e000 + 22679278
                      7   org.chromium.ContentShell.framework 0x000000014192e72c 0x14038e000 + 22677292
                      8   org.chromium.ContentShell.framework 0x0000000141947113 0x14038e000 + 22778131
                      9   org.chromium.ContentShell.framework 0x000000014196a7d2 0x14038e000 + 22923218
                      10  org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      11  libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      12  libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      13  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 27:: DnsConfigService
                      0   libsystem_kernel.dylib         0x00007fffe9644d96 kevent + 10
                      1   org.chromium.ContentShell.framework 0x000000014199e3e7 0x14038e000 + 23135207
                      2   org.chromium.ContentShell.framework 0x000000014199bebd 0x14038e000 + 23125693
                      3   org.chromium.ContentShell.framework 0x000000014192de2f 0x14038e000 + 22674991
                      4   org.chromium.ContentShell.framework 0x0000000141947113 0x14038e000 + 22778131
                      5   org.chromium.ContentShell.framework 0x000000014196a7d2 0x14038e000 + 22923218
                      6   org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      Thread 28:: Chrome_DBThread
                      5   org.chromium.ContentShell.framework 0x000000014192ec4f 0x14038e000 + 22678607
                      6   org.chromium.ContentShell.framework 0x000000014192e72c 0x14038e000 + 22677292
                      7   org.chromium.ContentShell.framework 0x0000000141947113 0x14038e000 + 22778131
                      8   org.chromium.ContentShell.framework 0x0000000141064354 0x14038e000 + 13460308
                      9   org.chromium.ContentShell.framework 0x00000001410644c3 0x14038e000 + 13460675
                      10  org.chromium.ContentShell.framework 0x000000014196a7d2 0x14038e000 + 22923218
                      11  org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      12  libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      13  libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      14  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 29:: Chrome_FileThread
                      5   org.chromium.ContentShell.framework 0x0000000141064384 0x14038e000 + 13460356
                      6   org.chromium.ContentShell.framework 0x00000001410644d0 0x14038e000 + 13460688
                      7   org.chromium.ContentShell.framework 0x000000014196a7d2 0x14038e000 + 22923218
                      8   org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      9   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      10  libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      11  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 30:: Chrome_FileUserBlockingThread
                      8   org.chromium.ContentShell.framework 0x00000001410643b4 0x14038e000 + 13460404
                      9   org.chromium.ContentShell.framework 0x00000001410644dd 0x14038e000 + 13460701
                      Thread 31:: Chrome_ProcessLauncherThread
                      8   org.chromium.ContentShell.framework 0x00000001410643e4 0x14038e000 + 13460452
                      9   org.chromium.ContentShell.framework 0x00000001410644ea 0x14038e000 + 13460714
                      Thread 32:: Chrome_CacheThread
                      8   org.chromium.ContentShell.framework 0x0000000141064414 0x14038e000 + 13460500
                      9   org.chromium.ContentShell.framework 0x00000001410644f7 0x14038e000 + 13460727
                      Thread 33:: Chrome_IOThread
                      5   org.chromium.ContentShell.framework 0x0000000141064444 0x14038e000 + 13460548
                      6   org.chromium.ContentShell.framework 0x0000000141064504 0x14038e000 + 13460740
                      Thread 34:: BrowserBlockingWorker1/105731
                      2   org.chromium.ContentShell.framework 0x00000001419672cf 0x14038e000 + 22909647
                      3   org.chromium.ContentShell.framework 0x0000000141966976 0x14038e000 + 22907254
                      4   org.chromium.ContentShell.framework 0x0000000141969c5d 0x14038e000 + 22920285
                      5   org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      Thread 35:: IndexedDB
                      8   org.chromium.ContentShell.framework 0x000000014196a7d2 0x14038e000 + 22923218
                      9   org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      10  libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      11  libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      12  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 36:: CompositorTileWorker1/107779
                      2   org.chromium.ContentShell.framework 0x0000000141a1d698 0x14038e000 + 23656088
                      3   org.chromium.ContentShell.framework 0x0000000141969c5d 0x14038e000 + 22920285
                      4   org.chromium.ContentShell.framework 0x00000001419662f7 0x14038e000 + 22905591
                      Thread 37:: AudioThread
                      Thread 38:: NetworkConfigWatcher
                      Thread 39:: Chrome_DevToolsHandlerThread
                      Thread 40:: com.apple.CFSocket.private
                      0   libsystem_kernel.dylib         0x00007fffe9643eb6 __select + 10
                      1   com.apple.CoreFoundation       0x00007fffd3dd766a __CFSocketManager + 682
                      Thread 41:
                      5   com.apple.Foundation           0x00007fffd58c1f49 -[NSConnection run] + 144
                      Thread 42:: CEPMonitorThread
                      5   com.apple.Foundation           0x00007fffd58540f2 -[NSConcreteTask waitUntilExit] + 213
                      6   com.adobe.PlugPlugOwl         0x000000010939ec4b -[HtmlEngineMonitor monitorThreadProc] + 160
                      7   com.apple.Foundation           0x00007fffd57beb3d __NSThread__start__ + 1243
                      8   libsystem_pthread.dylib       0x00007fffe972e93b _pthread_body + 180
                      9   libsystem_pthread.dylib       0x00007fffe972e887 _pthread_start + 286
                      10  libsystem_pthread.dylib       0x00007fffe972e08d thread_start + 13
                      Thread 43:
                      Thread 44:: CEPMonitorThread
                      Thread 45:: General Background Service
                      2   com.adobe.Photoshop           0x00000001015a5fb1 0x1011c3000 + 4075441
                      3   com.adobe.Photoshop           0x00000001034af81c 0x1011c3000 + 36620316
                      4   com.adobe.Photoshop           0x00000001034aecac 0x1011c3000 + 36617388
                      5   com.adobe.Photoshop           0x00000001034b0ba6 0x1011c3000 + 36625318
                      6   CITThreading                   0x000000010906605e boost::(anonymous namespace)::thread_proxy(void*) + 130
                      Thread 46:
                      Thread 47:: CEPMonitorThread
                      Thread 48:: BrowserBlockingWorker2/87899
                      Thread 49:: BrowserBlockingWorker3/83727
                      Thread 50:: CachePoolWorker1/141371
                      Thread 51:: Font Initialization
                      Thread 52:: DeepFont
                      Thread 53:
                      0   libsystem_kernel.dylib         0x00007fffe964444e __workq_kernreturn + 10
                      1   libsystem_pthread.dylib       0x00007fffe972e621 _pthread_wqthread + 1426
                      2   libsystem_pthread.dylib       0x00007fffe972e07d start_wqthread + 13
                      Thread 54:
                      Thread 55:
                      Thread 56:
                      Thread 57:
                      Thread 58:: CEPMonitorThread
                      Thread 59:
                      Thread 60:
                      1   libsystem_pthread.dylib       0x00007fffe972e48e _pthread_wqthread + 1023
                      Thread 61:
                      Thread 0 crashed with X86 Thread State (64-bit):
                        rax: 0x0000000000000000  rbx: 0x00007fffe59afed8  rcx: 0x0000000000000000  rdx: 0x00007fffe59af685
                        rdi: 0x00007fb99c6933a0  rsi: 0x0000000000000001  rbp: 0x00007fff5ea35a20  rsp: 0x00007fff5ea35a10
                         r8: 0x0000000000000040   r9: 0x00007fffee802828  r10: 0x000000016f7cc310  r11: 0x00007fb9a51bc0f0
                        r12: 0x0000608232d322a0  r13: 0x0000000000000000  r14: 0x00007fb99c6933a0  r15: 0x00007fb99c29d4e0
                        rip: 0x00007fffe59af79d  rfl: 0x0000000000000297  cr2: 0x0000608232d32000
                      Logical CPU:     0
                      Error Code:      0x00000000
                      Trap Number:     222
                      Binary Images:
                             0x1011c3000 -        0x1079b0f87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
                             0x108999000 -        0x1089d0fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
                             0x108a16000 -        0x108a39fe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
                             0x108a71000 -        0x108a72ffb  libCyrillicConverter.dylib (69) <9797394A-56E2-393D-B265-F1CF09553FFF> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                             0x108a77000 -        0x108b1ffff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                             0x108b80000 -        0x108c1efff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                             0x108c72000 -        0x108df5ff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
                             0x108f55000 -        0x108fc4ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
                             0x109056000 -        0x10906ffff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
                             0x1090b4000 -        0x1091b2ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                             0x1091e6000 -        0x1092ecfff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                             0x109305000 -        0x10957bff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
                             0x10984d000 -        0x1098c3fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
                             0x1099ae000 -        0x109a57ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                             0x109a84000 -        0x109a89ffb  org.twain.dsm (1.9.5 - 1.9.5) <870046C5-F052-3F7C-BB2B-452392CAC599> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                             0x109a99000 -        0x109ab7fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                             0x109aca000 -        0x109c5cff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                             0x109ca9000 -        0x10a00fff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                             0x10a088000 -        0x10a0acfff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
                             0x10a0d8000 -        0x10a3a1ffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                             0x10a410000 -        0x10a70dffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                             0x10a760000 -        0x10a783ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                             0x10a793000 -        0x10a7b7ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                             0x10a7dc000 -        0x10a906ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                             0x10a95e000 -        0x10aaa8ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                             0x10aabf000 -        0x10aadbffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                             0x10aae5000 -        0x10aba5ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                             0x10abee000 -        0x10ad68fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                             0x10aebe000 -        0x10b416fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
                             0x10ba88000 -        0x10bc22fff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                             0x10bcfb000 -        0x10ca40fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                             0x10ca57000 -        0x10ca80ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                             0x10ca98000 -        0x10ca9bfff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                             0x10caaa000 -        0x10cae5ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
                             0x10cb32000 -        0x10cc2efff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                             0x10ccdb000 -        0x10ce2aff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                             0x10ce82000 -        0x10cf7cff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                             0x10cf94000 -        0x10d097ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                             0x10d0e5000 -        0x10d22cfef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
                             0x10d384000 -        0x10d5a6ff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
                             0x10d5fb000 -        0x10d7d8ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
                             0x10d8c4000 -        0x10db56ffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
                             0x10dbdd000 -        0x10dd11fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                             0x10dfff000 -        0x10e001ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                             0x10fbaf000 -        0x10fbcbffb  libJapaneseConverter.dylib (69) <2B89173A-C9D8-31AA-8EC3-0555DDA3FAB9> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                             0x10fbd1000 -        0x10fbf3fff  libKoreanConverter.dylib (69) <B51485DD-33BF-3325-A113-6B667CF9882F> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                             0x10fbf9000 -        0x10fc08ffb  libSimplifiedChineseConverter.dylib (69) <C966895E-338A-39FB-92F5-D524981610EA> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                             0x10fc0d000 -        0x10fc1fff3  libTraditionalChineseConverter.dylib (69) <B6441C47-699A-35C5-B1DB-440F750DC03D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                             0x10fc52000 -        0x10fc5afff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
                             0x1105c0000 -        0x110603ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
                             0x1124a9000 -        0x1124c9fff  com.apple.CoreNLP (1.0 - 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
                             0x112b6d000 -        0x112b71fff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                             0x113343000 -        0x1133bffef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
                             0x113443000 -        0x1134bcff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                             0x114eb6000 -        0x115001fff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
                             0x1163e1000 -        0x116484ff7  ColorSyncDeprecated.dylib (502.2) <FDB3BCCA-7C71-3DAA-9AB2-528E0CC60616> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                             0x1167bc000 -        0x116bf1fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Scr iptingSupport
                             0x116ede000 -        0x116fbeff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
                             0x116fe6000 -        0x117024ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                             0x11704c000 -        0x117065ffb  libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
                             0x117afa000 -        0x117ca0fff  GLEngine (14.0.16) <1999FBF9-0B82-34B1-8876-87B4F82101BB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                             0x117cdf000 -        0x117d09fff  GLRendererFloat (14.0.16) <8D11C08E-8249-38DB-9856-BFC01EEDE0CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                             0x117d13000 -        0x117d8bff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.25.13 - 10.2.5) <77FF34DB-2688-393A-BBBA-456DF3834B7F> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD5000GraphicsMTLDriver
                             0x1182e2000 -        0x1182f3ff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Me asurementCore
                             0x118303000 -        0x118340dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
                             0x14038e000 -        0x145e10faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
                             0x146510000 -        0x146a6bff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.25.13 - 10.2.5) <2C0CF883-843A-3CCF-BE6C-2AA7DE5F4E61> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
                             0x148a73000 -        0x148aa5ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                             0x148ab1000 -        0x148adafff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                             0x148aec000 -        0x148b65fff  com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                             0x16ee57000 -        0x16f663fff +com.adobe.Liquify (18.1.1 - 18.1.1) <FF6B43F2-ACAA-3C18-AF90-852AD7282F5E> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/Filters/Liquify.plugin/Contents/MacOS/Liquify
                          0x7fffce9c6000 -     0x7fffced0bff7  com.apple.RawCamera.bundle (7.03 - 912) <1476F375-6C4B-382A-ABDB-99B7DCBF4F6D> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                          0x7fffd053d000 -     0x7fffd0541ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <752FDB92-EF67-3D04-BF40-A352BF1075CF> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                          0x7fffd0542000 -     0x7fffd0703fff  com.apple.avfoundation (2.0 - 1187.36) <8C7813BE-B548-33E3-A61E-FF1F1984386A> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                          0x7fffd0704000 -     0x7fffd07a6ff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                          0x7fffd0871000 -     0x7fffd0871fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                          0x7fffd0872000 -     0x7fffd0889ffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                          0x7fffd088a000 -     0x7fffd0da3feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                          0x7fffd0da4000 -     0x7fffd0f15ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                          0x7fffd0f16000 -     0x7fffd0f2affb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                          0x7fffd0f2b000 -     0x7fffd1321fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                          0x7fffd1322000 -     0x7fffd1338fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                          0x7fffd1339000 -     0x7fffd133ffff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                          0x7fffd1340000 -     0x7fffd1354ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                          0x7fffd1355000 -     0x7fffd14dcfe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                          0x7fffd14dd000 -     0x7fffd158ffff  libvMisc.dylib (600.60.1) <98F27D2D-E5DD-38EF-8747-0C4DE821A23D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                          0x7fffd1590000 -     0x7fffd1590fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                          0x7fffd1591000 -     0x7fffd15ceffb  com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
                          0x7fffd15cf000 -     0x7fffd184eff7  com.apple.AddressBook.framework (10.0 - 1756.20) <EF74B8FF-3AFE-3336-82B0-02792B17406C> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                          0x7fffd184f000 -     0x7fffd2628ff3  com.apple.AppKit (6.9 - 1504.83.101) <EC7BD195-F9E1-3E43-820A-5FDD0B2B0B67> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                          0x7fffd263a000 -     0x7fffd263afff  com.apple.ApplicationServices (48 - 48) <4C71CBA8-47E4-38BF-BE3B-F20DF8667D5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                          0x7fffd263b000 -     0x7fffd26a9ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                          0x7fffd2743000 -     0x7fffd2872ff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                          0x7fffd2873000 -     0x7fffd28bdfff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                          0x7fffd291a000 -     0x7fffd294dfff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                          0x7fffd29ba000 -     0x7fffd2a64ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                          0x7fffd2a65000 -     0x7fffd2ab6fff  com.apple.HIServices (1.22 - 592.1) <7353E76E-9A3A-3693-87AF-41953585E024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                          0x7fffd2ab7000 -     0x7fffd2ac6ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                          0x7fffd2ac7000 -     0x7fffd2b14fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                          0x7fffd2b15000 -     0x7fffd2b50fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                          0x7fffd2b51000 -     0x7fffd2b5cfff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                          0x7fffd2b5d000 -     0x7fffd2d69fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <91D2BA22-B168-3A9A-9008-6FFC5A8FDC1E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                          0x7fffd2d6a000 -     0x7fffd2d6afff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <8C0153FD-FEFF-309C-AACD-BF9657A31F8E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                          0x7fffd2ed3000 -     0x7fffd32adfff  com.apple.CFNetwork (811.5.4 - 811.5.4) <4DBF8932-6286-3B23-87D9-63615B9958D9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                          0x7fffd32c7000 -     0x7fffd32c7fff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                          0x7fffd32c8000 -     0x7fffd32cbfff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                          0x7fffd32cc000 -     0x7fffd35d5fff  com.apple.HIToolbox (2.1.1 - 857.8) <CAB143FE-AEAF-3EDE-AD7B-C04E1B7C5615> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                          0x7fffd35d6000 -     0x7fffd35d9ff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                          0x7fffd35da000 -     0x7fffd35dffff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                          0x7fffd35e0000 -     0x7fffd3677ff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                          0x7fffd3678000 -     0x7fffd3692fff  com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                          0x7fffd3693000 -     0x7fffd3694ff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                          0x7fffd3695000 -     0x7fffd3697ff7  com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                          0x7fffd3698000 -     0x7fffd369eff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                          0x7fffd369f000 -     0x7fffd377effb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                          0x7fffd377f000 -     0x7fffd377ffff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                          0x7fffd38c9000 -     0x7fffd3956fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                          0x7fffd3957000 -     0x7fffd396afff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                          0x7fffd396b000 -     0x7fffd3c66fff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                          0x7fffd3c67000 -     0x7fffd3d13ff7  com.apple.CoreDisplay (1.0 - 1) <AAD5DF0B-0D22-305E-86FF-BB1431130363> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                          0x7fffd3d14000 -     0x7fffd41adff7  com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                          0x7fffd41ae000 -     0x7fffd4830fff  com.apple.CoreGraphics (2.0 - 1070.22) <78E7C882-837D-3CC3-B221-767B999873CE> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                          0x7fffd4831000 -     0x7fffd4a74ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                          0x7fffd4a75000 -     0x7fffd4adaff7  com.apple.corelocation (2101.0.63) <B76E6C13-E10B-3F2F-AFD7-DB2C0DEF6579> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                          0x7fffd4adb000 -     0x7fffd4b8cfff  com.apple.CoreMedia (1.0 - 1907.59.1.5) <6CCDE81A-6992-33ED-A1D9-9D27A4C1E31F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                          0x7fffd4b8d000 -     0x7fffd4bd8ff7  com.apple.CoreMediaIO (805.0 - 4932) <ACE54DDE-C526-31CA-9755-3938603E3751> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                          0x7fffd4bd9000 -     0x7fffd4bd9fff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                          0x7fffd4bda000 -     0x7fffd4c2bfff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                          0x7fffd4c2c000 -     0x7fffd4f07ff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                          0x7fffd4f08000 -     0x7fffd4f3bfff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                          0x7fffd4f3c000 -     0x7fffd4f44ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                          0x7fffd4f45000 -     0x7fffd50b1ff7  com.apple.LaunchServices (775.19 - 775.19) <94D15A2A-852C-3B4B-A701-43043C8F1527> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                          0x7fffd50b2000 -     0x7fffd5162ffb  com.apple.Metadata (10.7.0 - 1075.40) <DA911E1B-3977-386D-930D-96BD5085CB8E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                          0x7fffd5163000 -     0x7fffd51c2fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <C709A773-4FA0-33DD-B3E2-FBA41E00F177> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                          0x7fffd51c3000 -     0x7fffd5233fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                          0x7fffd5234000 -     0x7fffd5279ff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                          0x7fffd5302000 -     0x7fffd544fffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                          0x7fffd5450000 -     0x7fffd5485ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                          0x7fffd5486000 -     0x7fffd54f7ffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                          0x7fffd552a000 -     0x7fffd5535ff3  com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                          0x7fffd55f5000 -     0x7fffd55fafff  com.apple.DiskArbitration (2.7 - 2.7) <8AC72143-D3C4-3AA6-84DF-734E3AFAC49B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                          0x7fffd578c000 -     0x7fffd5b32ff3  com.apple.Foundation (6.9 - 1349.81) <730B7944-BB43-35D5-A546-9F6CCED4B9F3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                          0x7fffd5b33000 -     0x7fffd5b5dff7  com.apple.GLKit (1.0 - 87) <B47CA8EF-415D-35C8-A628-F9FF2F538235> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
                          0x7fffd5b5e000 -     0x7fffd5b8fff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                          0x7fffd5b90000 -     0x7fffd5ba8ff7  com.apple.GameController (1.0 - 1) <DAC8C83B-7EC8-3A88-A725-E13DD905BF4F> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
                          0x7fffd5c4f000 -     0x7fffd5cf2ffb  com.apple.Bluetooth (5.0.4 - 5.0.4f18) <B3FED7E7-45EE-32DD-B59E-7942BCE9426C> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                          0x7fffd5cf3000 -     0x7fffd5d89ff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                          0x7fffd5d8a000 -     0x7fffd5d90ffb  com.apple.IOSurface (159.7 - 159.7) <40550017-EF96-3C52-B400-806AFEE4B134> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                          0x7fffd5d91000 -     0x7fffd5de2ff7  com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                          0x7fffd5de3000 -     0x7fffd5f43fef  com.apple.ImageIO.framework (3.3.0 - 1599.10.2) <87AA4D39-0AFC-3A34-98EF-02710E2BF3CA> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                          0x7fffd5f44000 -     0x7fffd5f48fff  libGIF.dylib (1599.10.2) <6ED05614-1301-3452-943B-118F00F20C8D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                          0x7fffd5f49000 -     0x7fffd6039ff7  libJP2.dylib (1599.10.2) <72C00423-55F0-3CAD-B198-EF00950791E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                          0x7fffd603a000 -     0x7fffd605dffb  libJPEG.dylib (1599.10.2) <78945614-990F-3705-A91C-46F717F7C635> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                          0x7fffd605e000 -     0x7fffd6085ff7  libPng.dylib (1599.10.2) <B800C14F-6E41-36B6-8DC1-1AE97A83A964> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                          0x7fffd6086000 -     0x7fffd6088ff3  libRadiance.dylib (1599.10.2) <037D95B4-82A7-3A59-B3EB-0FF0977CF7A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                          0x7fffd6089000 -     0x7fffd60d7fff  libTIFF.dylib (1599.10.2) <CA2C7BF9-FDDB-36CF-B063-B075B29F8878> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                          0x7fffd6235000 -     0x7fffd6e3dff3  com.apple.JavaScriptCore (12603 - 12603.2.4) <FFD37381-05F4-3907-BD31-74CFC3D7868F> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                          0x7fffd6e3e000 -     0x7fffd6e57ff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                          0x7fffd6e58000 -     0x7fffd6e8efff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                          0x7fffd70e0000 -     0x7fffd70e6fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                          0x7fffd70fc000 -     0x7fffd7635ff7  com.apple.MediaToolbox (1.0 - 1907.59.1.5) <2024A2A2-50B6-36AA-BC6D-3AAFA78EB707> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                          0x7fffd7636000 -     0x7fffd7691fff  com.apple.Metal (87.18 - 87.18) <5C2F12FB-45C1-3103-A827-3D225BF8D05A> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                          0x7fffd76ab000 -     0x7fffd7f2afff  com.apple.ModelIO (1.0 - 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
                          0x7fffd7f7a000 -     0x7fffd7f82fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                          0x7fffd8159000 -     0x7fffd8161ff7  libcldcpuengine.dylib (2.8.5) <73E1E526-01DF-3199-9B48-155F0329EF44> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                          0x7fffd8162000 -     0x7fffd81b0ff3  com.apple.opencl (2.8.6 - 2.8.6) <5FAF6F49-2648-39E6-922B-5630A5D7F7E4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                          0x7fffd81b1000 -     0x7fffd81caffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                          0x7fffd81cb000 -     0x7fffd81d6ff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                          0x7fffd81d7000 -     0x7fffd81d9fff  libCVMSPluginSupport.dylib (14.0.16) <A20EC348-37C9-33B6-9A81-06006F3214A1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                          0x7fffd81da000 -     0x7fffd81ddff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                          0x7fffd81de000 -     0x7fffd81e2fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                          0x7fffd81e3000 -     0x7fffd81ecff7  libGFXShared.dylib (14.0.16) <63542E68-EB1A-3ECF-AAFB-E7B8AB313C70> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                          0x7fffd81ed000 -     0x7fffd81f8fff  libGL.dylib (14.0.16) <84BEED97-0A93-356D-A922-97EA311EA446> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                          0x7fffd81f9000 -     0x7fffd8235ff7  libGLImage.dylib (14.0.16) <3518A85C-6905-3511-A6C9-2F82C519D28F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                          0x7fffd8236000 -     0x7fffd83acff3  libGLProgrammability.dylib (14.0.16) <0EDA89D8-7C28-3D53-BDBA-7CB25232C329> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                          0x7fffd83ad000 -     0x7fffd83eeff7  libGLU.dylib (14.0.16) <9860DCF7-56E0-3A8F-A377-52635C9D8B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                          0x7fffd8d56000 -     0x7fffd8d64fff  com.apple.opengl (14.0.16 - 14.0.16) <27E7D76E-A26B-39F8-8CF2-AB57920776A3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                          0x7fffd8e01000 -     0x7fffd8f48fff  com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                          0x7fffd8f49000 -     0x7fffd91b3ff7  com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                          0x7fffd91b4000 -     0x7fffd927bfff  com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                          0x7fffd927c000 -     0x7fffd97a2ff7  com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                          0x7fffd97a3000 -     0x7fffd97c6ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                          0x7fffd97c7000 -     0x7fffd98b4fff  com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                          0x7fffd98b5000 -     0x7fffd98b5fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                          0x7fffd98b6000 -     0x7fffd9ab6fff  com.apple.QuartzCore (1.11 - 453.39.3) <AB46D60D-17A8-3122-800E-2A9DA604FCBA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                          0x7fffd9ab7000 -     0x7fffd9b0cfff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                          0x7fffd9b0d000 -     0x7fffd9b22fff  com.apple.SafariServices.framework (12603 - 12603.2.4) <BD072E0A-9759-341D-9E59-5D869380076B> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                          0x7fffda01d000 -     0x7fffda31fff7  com.apple.security (7.0 - 57740.60.18) <021AACF6-D15F-37E0-840B-88853684BA00> /System/Library/Frameworks/Security.framework/Versions/A/Security
                          0x7fffda320000 -     0x7fffda395fff  com.apple.securityfoundation (6.0 - 55132.50.7) <4433C0CC-FE90-3DD3-BAC1-CC31D515B510> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                          0x7fffda396000 -     0x7fffda3bffff  com.apple.securityinterface (10.0 - 55079.50.4) <50E3EAA8-1AF0-3910-AAFD-57D93D958DFF> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                          0x7fffda3c0000 -     0x7fffda3c3ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <9F285B19-B53B-3502-85A2-72C26DB40EA7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                          0x7fffda74a000 -     0x7fffda7b9ff7  com.apple.SystemConfiguration (1.14 - 1.14) <2412CDE0-C317-31EA-8F53-7A58BBFCC720> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                          0x7fffda7ba000 -     0x7fffdab68fff  com.apple.VideoToolbox (1.0 - 1907.59.1.5) <75E2F901-572F-3FC8-A599-96A085EEBC88> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                          0x7fffdd00e000 -     0x7fffdd029ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                          0x7fffdd02a000 -     0x7fffdd037ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                          0x7fffdd038000 -     0x7fffdd05affb  com.apple.framework.Apple80211 (12.0 - 1200.47) <B692048E-1B61-3DAF-9CBA-4D314E7562DC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                          0x7fffdd05b000 -     0x7fffdd06afeb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                          0x7fffdd15e000 -     0x7fffdd1e997f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                          0x7fffdd1fd000 -     0x7fffdd218fff  com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                          0x7fffdd219000 -     0x7fffdd221ffb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                          0x7fffdd222000 -     0x7fffdd225ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                          0x7fffdd226000 -     0x7fffdd278fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                          0x7fffdd282000 -     0x7fffdd289ff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                          0x7fffdd61c000 -     0x7fffdd69aff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                          0x7fffddd36000 -     0x7fffddd5dfff  com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLin k
                          0x7fffde325000 -     0x7fffde34cff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                          0x7fffde34d000 -     0x7fffde3d9ff7  com.apple.CloudDocs (1.0 - 486.29) <751554B6-A09E-32A8-A604-9F1B1FD8B84D> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                          0x7fffdec71000 -     0x7fffdec7affb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                          0x7fffded41000 -     0x7fffded91ffb  com.apple.AddressBook.ContactsFoundation (8.0 - 2250.10) <3097DEAC-ED6B-358E-8E81-8B7011CECA91> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                          0x7fffded92000 -     0x7fffdedb4fff  com.apple.contacts.ContactsPersistence (1.0 - 2250.10) <7EC0366F-30A6-3538-8BC9-8CABD55C178D> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                          0x7fffdedfe000 -     0x7fffdf1ddff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                          0x7fffdf1de000 -     0x7fffdf20efff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                          0x7fffdf2a9000 -     0x7fffdf2b1ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                          0x7fffdf3c2000 -     0x7fffdf3d2fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                          0x7fffdf497000 -     0x7fffdf4adff3  com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                          0x7fffdf4b4000 -     0x7fffdf544ffb  com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                          0x7fffdf70d000 -     0x7fffdf73dff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                          0x7fffdf9ce000 -     0x7fffdfa5dff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                          0x7fffdfa5e000 -     0x7fffdfb9dfe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                          0x7fffdfb9e000 -     0x7fffdfc6eff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                          0x7fffdfcbe000 -     0x7fffdfd23ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                          0x7fffdfd24000 -     0x7fffdfd32ff7  com.apple.CrashReporterSupport (10.12 - 827) <14037A71-ECFE-394A-8D6E-2CECE98F02EE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                          0x7fffdfda4000 -     0x7fffdfdaeffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                          0x7fffdfdaf000 -     0x7fffdfdb3ff3  com.apple.DSExternalDisplay (3.1 - 380) <A195C0CE-8E4E-384B-9556-8270E306FE1D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
                          0x7fffdfde9000 -     0x7fffdfe5effb  com.apple.datadetectorscore (7.0 - 539.1) <9C312AAC-8AEE-3C72-BDE5-7FBF62452525> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                          0x7fffdfe9a000 -     0x7fffdfed9fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                          0x7fffdfeda000 -     0x7fffdffebfff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                          0x7fffe012e000 -     0x7fffe0139fff  com.apple.DisplayServicesFW (3.1 - 380) <83BB7C77-F18D-382D-9023-26132D925F75> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                          0x7fffe02d3000 -     0x7fffe0704ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                          0x7fffe1a5b000 -     0x7fffe1a5bfff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                          0x7fffe1a68000 -     0x7fffe1a73ff3  libGPUSupportMercury.dylib (14.0.16) <7E99C736-2F48-313E-BEF6-6F8BABFADD9F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                          0x7fffe1d2c000 -     0x7fffe1d48fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                          0x7fffe1d61000 -     0x7fffe2413fff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                          0x7fffe2459000 -     0x7fffe24cfff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                          0x7fffe24d0000 -     0x7fffe24e1fff  com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                          0x7fffe2aea000 -     0x7fffe2af1ffb  com.apple.IOAccelerator (311.13 - 311.13) <40C04C41-A76A-3687-8D64-F76E8C46AA81> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                          0x7fffe2af3000 -     0x7fffe2b07ff7  com.apple.IOPresentment (1.0 - 29.10) <A3F7C1F6-CE50-3804-AAAF-7B75EBC46BE4> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                          0x7fffe2b08000 -     0x7fffe2b2afff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                          0x7fffe2bc6000 -     0x7fffe2bd6ff3  com.apple.IntlPreferences (2.0 - 216) <47681AE8-4539-3525-890C-206B301CEC77> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                          0x7fffe2c11000 -     0x7fffe2dc8fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                          0x7fffe2ec4000 -     0x7fffe2f86ff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                          0x7fffe3438000 -     0x7fffe343bfff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                          0x7fffe36e9000 -     0x7fffe3762ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
                          0x7fffe38be000 -     0x7fffe38cbff3  com.apple.MobileKeyBag (2.0 - 1.0) <F42EB8B1-BA68-3769-98BE-26A18AED902F> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                          0x7fffe38dc000 -     0x7fffe3904ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <512ADEC6-D694-3D73-A48A-6BE79CD39539> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                          0x7fffe39b6000 -     0x7fffe39c1fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                          0x7fffe3e0e000 -     0x7fffe3e10fff  com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
                          0x7fffe4299000 -     0x7fffe42daff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <6A21AB41-3AAA-32F3-9D46-2555A143A8B9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                          0x7fffe431d000 -     0x7fffe4324ff3  com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                          0x7fffe4987000 -     0x7fffe49c1ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <1C6083B7-F020-3634-8F53-CC9E07F27EC5> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                          0x7fffe49c2000 -     0x7fffe49dcfff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                          0x7fffe49dd000 -     0x7fffe49ecff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                          0x7fffe49f5000 -     0x7fffe4a18ff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                          0x7fffe56df000 -     0x7fffe56e2fff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                          0x7fffe5771000 -     0x7fffe57fefff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                          0x7fffe57ff000 -     0x7fffe581eff7  com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                          0x7fffe581f000 -     0x7fffe5a85fef  com.apple.SkyLight (1.600.0 - 170.3) <83AB220F-48C0-3063-8ED3-ACDB69243B4D> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                          0x7fffe5c64000 -     0x7fffe5c70ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                          0x7fffe635c000 -     0x7fffe63d0fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                          0x7fffe680f000 -     0x7fffe6815ff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                          0x7fffe68a1000 -     0x7fffe6967ff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                          0x7fffe69b0000 -     0x7fffe69c5ff3  com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                          0x7fffe69c6000 -     0x7fffe69d4ffb  com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                          0x7fffe69db000 -     0x7fffe69dcfff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                          0x7fffe69dd000 -     0x7fffe6b6dff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                          0x7fffe763c000 -     0x7fffe76fcfff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                          0x7fffe7b47000 -     0x7fffe7b4dfff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                          0x7fffe7c1e000 -     0x7fffe7c20ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                          0x7fffe7c4c000 -     0x7fffe7c73ff7  com.apple.contacts.vCard (1.0 - 2250.10) <19E37E68-E945-3534-8658-87AA411D0AD4> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                          0x7fffe7c75000 -     0x7fffe7c90ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
                          0x7fffe7c91000 -     0x7fffe7c9cfff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
                          0x7fffe7d2e000 -     0x7fffe7d2fff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
                          0x7fffe7d30000 -     0x7fffe7f43fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
                          0x7fffe7f5f000 -     0x7fffe7f66fff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
                          0x7fffe7f67000 -     0x7fffe7f67fff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
                          0x7fffe7f68000 -     0x7fffe7f6cffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
                          0x7fffe7f6d000 -     0x7fffe7f6effb  libSystem.B.dylib (1238.60.2) <FC9E9F13-3B18-305C-BE0A-97C7843652B0> /usr/lib/libSystem.B.dylib
                          0x7fffe7fda000 -     0x7fffe8005ff3  libarchive.2.dylib (41.50.2) <B4F507BC-B24E-3BE7-B658-94D798E2CD81> /usr/lib/libarchive.2.dylib
                          0x7fffe8006000 -     0x7fffe8082fc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
                          0x7fffe8086000 -     0x7fffe8086ff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
                          0x7fffe8087000 -     0x7fffe8097ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
                          0x7fffe8098000 -     0x7fffe80a6ff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
                          0x7fffe80a7000 -     0x7fffe80fdff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
                          0x7fffe80fe000 -     0x7fffe8128fff  libc++abi.dylib (307.3) <30199352-88BF-30BD-8CFF-2A4FBE247523> /usr/lib/libc++abi.dylib
                          0x7fffe8129000 -     0x7fffe8139ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
                          0x7fffe813a000 -     0x7fffe8150fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
                          0x7fffe8151000 -     0x7fffe8151ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
                          0x7fffe8152000 -     0x7fffe8153ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
                          0x7fffe820d000 -     0x7fffe82f2ff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
                          0x7fffe8490000 -     0x7fffe84e3ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
                          0x7fffe8535000 -     0x7fffe853cff3  libdscsym.dylib (148.3) <63492BDA-33A8-31DE-90E8-A3D44F07EB9C> /usr/lib/libdscsym.dylib
                          0x7fffe855e000 -     0x7fffe855efff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
                          0x7fffe856e000 -     0x7fffe8573ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
                          0x7fffe8574000 -     0x7fffe8666ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
                          0x7fffe8667000 -     0x7fffe888cffb  libicucore.A.dylib (57165.0.1) <2931B842-2946-3576-AD1D-1CDA22FA1388> /usr/lib/libicucore.A.dylib
                          0x7fffe8892000 -     0x7fffe8893fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
                          0x7fffe8894000 -     0x7fffe88adffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
                          0x7fffe88ae000 -     0x7fffe88c4ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
                          0x7fffe88c5000 -     0x7fffe8b6dff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
                          0x7fffe8ba0000 -     0x7fffe8c1aff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
                          0x7fffe8c1b000 -     0x7fffe8fed047  libobjc.A.dylib (709) <DC77AA6E-A4E4-326D-8D7F-82D63AA88F99> /usr/lib/libobjc.A.dylib
                          0x7fffe8ff0000 -     0x7fffe8ff4fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
                          0x7fffe8ff5000 -     0x7fffe9026fff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
                          0x7fffe9043000 -     0x7fffe905fffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
                          0x7fffe9060000 -     0x7fffe9099fff  libsandbox.1.dylib (592.60.1) <B3A1C3BD-084C-389B-9AFD-4BCFDBE9B5B6> /usr/lib/libsandbox.1.dylib
                          0x7fffe909a000 -     0x7fffe90acffb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
                          0x7fffe90ad000 -     0x7fffe90aeff3  libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
                          0x7fffe90af000 -     0x7fffe91fcff7  libsqlite3.dylib (254.7) <07CD6DE3-394D-3C6A-A4B4-4CAB1054A041> /usr/lib/libsqlite3.dylib
                          0x7fffe9258000 -     0x7fffe92a8fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
                          0x7fffe92f1000 -     0x7fffe92fefff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
                          0x7fffe92ff000 -     0x7fffe93eeffb  libxml2.2.dylib (30.16) <D2A6861B-D9FA-3BFC-B664-830C3FCE6065> /usr/lib/libxml2.2.dylib
                          0x7fffe93ef000 -     0x7fffe9418fff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
                          0x7fffe9419000 -     0x7fffe942aff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
                          0x7fffe9439000 -     0x7fffe943dff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
                          0x7fffe943e000 -     0x7fffe9448fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
                          0x7fffe9449000 -     0x7fffe9450fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
                          0x7fffe9451000 -     0x7fffe9459fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
                          0x7fffe945a000 -     0x7fffe94ddfdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
                          0x7fffe94de000 -     0x7fffe950ffff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
                          0x7fffe9510000 -     0x7fffe9515ffb  libdyld.dylib (433.5) <EC3D88D2-3D40-3274-8E26-362C2D7352C8> /usr/lib/system/libdyld.dylib
                          0x7fffe9516000 -     0x7fffe9516ffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
                          0x7fffe9517000 -     0x7fffe9523ffb  libkxld.dylib (3789.60.24) <5DFCDC05-6CBC-35A6-8B92-DF6803492E12> /usr/lib/system/libkxld.dylib
                          0x7fffe9524000 -     0x7fffe9524fff  liblaunch.dylib (972.60.2) <D3306CFF-58AA-3C90-B06C-B70E80E60C5B> /usr/lib/system/liblaunch.dylib
                          0x7fffe9525000 -     0x7fffe952aff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
                          0x7fffe952b000 -     0x7fffe952dff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
                          0x7fffe952e000 -     0x7fffe952fffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
                          0x7fffe9530000 -     0x7fffe9548ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
                          0x7fffe9549000 -     0x7fffe9549ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
                          0x7fffe954a000 -     0x7fffe95d7fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
                          0x7fffe95d8000 -     0x7fffe95dbffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
                          0x7fffe95dc000 -     0x7fffe95dffff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
                          0x7fffe95e0000 -     0x7fffe95f8fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
                          0x7fffe95f9000 -     0x7fffe95fffff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
                          0x7fffe9600000 -     0x7fffe9629ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
                          0x7fffe962a000 -     0x7fffe964cff7  libsystem_kernel.dylib (3789.60.24) <6E9E485F-91F6-36B7-A125-AE91DC978BCC> /usr/lib/system/libsystem_kernel.dylib
                          0x7fffe964d000 -     0x7fffe9694fe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
                          0x7fffe9695000 -     0x7fffe96b3ff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
                          0x7fffe96b4000 -     0x7fffe970dffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
                          0x7fffe970e000 -     0x7fffe9717ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
                          0x7fffe9718000 -     0x7fffe9721ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
                          0x7fffe9722000 -     0x7fffe972afe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
                          0x7fffe972b000 -     0x7fffe9735ff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
                          0x7fffe9736000 -     0x7fffe9739ff7  libsystem_sandbox.dylib (592.60.1) <DC780631-BD23-36B1-9376-668619E18D25> /usr/lib/system/libsystem_sandbox.dylib
                          0x7fffe973a000 -     0x7fffe973bff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
                          0x7fffe973c000 -     0x7fffe9743ffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
                          0x7fffe9744000 -     0x7fffe9757ff7  libsystem_trace.dylib (518.60.2) <6B145B10-5874-3E89-90CD-D370DB475BA1> /usr/lib/system/libsystem_trace.dylib
                          0x7fffe9758000 -     0x7fffe975dffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
                          0x7fffe975e000 -     0x7fffe9787ff7  libxpc.dylib (972.60.2) <1C9AF716-69DF-359F-85E9-7DFDE362F9A2> /usr/lib/system/libxpc.dylib
                      External Modification Summary:
                        Calls made by other processes targeting this process:
                          task_for_pid: 882
                          thread_create: 0
                          thread_set_state: 0
                        Calls made by this process:
                          task_for_pid: 0
                          thread_create: 0
                          thread_set_state: 0
                        Calls made by all processes on this machine:
                          task_for_pid: 851899
                          thread_create: 0
                          thread_set_state: 0
                      VM Region Summary:
                      ReadOnly portion of Libraries: Total=611.8M resident=0K(0%) swapped_out_or_unallocated=611.8M(100%)
                      Writable regions: Total=38.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=38.5G(100%)
                                                      VIRTUAL   REGION
                      REGION TYPE                        SIZE    COUNT (non-coalesced)
                      ATS (font support)                31.9M        9
                      ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
                      Accelerate framework               512K        5
                      Activity Tracing                   256K        2
                      CG backing stores                 95.2M       16
                      CG image                         195.2M       35
                      CoreAnimation                      316K       15
                      CoreUI image data                 2340K       19
                      CoreUI image file                  184K        5
                      Foundation                          24K        3
                      Image IO                           260K       19
                      Kernel Alloc Once                    8K        2
                      MALLOC                            37.4G     3463
                      MALLOC guard page                   64K       14
                      MALLOC_LARGE (reserved)            412K        2         reserved VM address space (unallocated)
                      Memory Tag 242                      12K        2
                      Memory Tag 251                      12K        2
                      OpenGL GLSL                        256K        4
                      SQLite page cache                   64K        2
                      STACK GUARD                       56.2M       63
                      Stack                            191.0M       70
                      VM_ALLOCATE                      646.6M       48
                      __DATA                            63.7M      386
                      __GLSLBUILTINS                    2588K        2
                      __IMAGE                            528K        2
                      __LINKEDIT                       137.2M       75
                      __TEXT                           474.6M      349
                      __UNICODE                          556K        2
                      mapped file                      237.3M       59
                      shared memory                     16.4M       22
                      TOTAL                             39.5G     4670
                      TOTAL, minus reserved VM space    39.5G     4670
                      Model: MacBookPro11,4, BootROM MBP114.0172.B16, 4 processors, Intel Core i7, 2,2 GHz, 16 GB, SMC 2.29f24
                      Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
                      Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453120
                      Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453120
                      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x152), Broadcom BCM43xx 1.0 (7.21.171.126.1a2)
                      Bluetooth: Version 5.0.4f18, 3 services, 27 devices, 1 incoming serial ports
                      Network Service: Wi-Fi, AirPort, en0
                      Serial ATA Device: APPLE SSD SM0256G, 251 GB
                      USB Device: USB 3.0 Bus
                      USB Device: Apple Internal Keyboard / Trackpad
                      USB Device: Bluetooth USB Host Controller
                      USB Device: USB Receiver
                      Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
                      • 8. Re: photoshop scroll bar mac os sierra issue
                        S_Gans Adobe Community Professional
                        I can attest to there being weird crashes that happen with Photoshop, and weird behaviors that're near impossible to explain (eg: I had a couple of versions of PS on my machine a ways back - still do. When I opened CC2015.1, I'd also get CC2014 opening at the same time - for no apparent reason. Nobody could help, until I tracked it down to a Safari plugin that'd been installed by one of Adobe's things! I don't remember what - but as soon as I disabled it, all worked as it should!)
                        So - this seems to happen almost exclusively when you access filters - in this case, Liquify. From what you say, it seems to affect what I call the "fancy" ones at the top of the filters menu. How's about the ones that don't use a dedicated window - I mean, something simple like, Noise? Blur (without the Gallery)? I'm trying to determine if it has to do with just the opening of special windows to do the job.
                        Do you have any third party plugins or extensions installed? Have you tried disabling those? IF you have any third party plugins, and they open their own special windows to do their job, does anything weird happen?
                        Sorry to put you through all these questions, but there're so many things to consider here. The errors you get on top have been previously attributed to lots of other apps, particularly when there isn't enough RAM. You have the max RAM you can have in there... is your hard drive very full though? I see some VM use, but the only way that'd affect things is if your HD is tight on space.
                        So - trying to find out what's not playing nicely with your PS Preference file like this.
                        BTW - have you started into the Recovery drive and checked the drive and also Permissions? If this is trying to access something in a Library folder where the permissions are messed up, things like this can happen too.
                        My answers here are kind of "stream of consciousness", since I'm kinda running through what I'd be troubleshooting if it was my machine.....
                        Weirdly - DO check the Acrobat plugin in Safari and make sure it's Sierra's version... I know, sounds weird, but after my own experience, I don't consider anything weird anymore!
                        • 9. Re: photoshop scroll bar mac os sierra issue
                          ivan.gusyev Level 1
                          thanks for the reply again
                          just tested with noise filter - it does not have scroll bar button so there is no issue could be with it, everything works fine. but, for example, blur filter do have scroll bar and this issues is present here again
                          no, i do not have any third party plugins or extensions installed. this is new just installed mac os with new root user and ps an lt on it. so there is no other things that could conflict with it
                          my ssd have free space of 225gb from 256gb
                          i checked the drive and permissions - everything is fine with it
                          there is only one plugin installed in safari - Creative Cloud Desktop Plugin.v_3_0_0_0. tried to disable it but the issue was again
                          • 10. Re: photoshop scroll bar mac os sierra issue
                            ivan.gusyev Level 1
                            update 1. just tried to reconstruct the issue using remote access teamviewer app (from my other notebook via teamviewer to my macbook) - but i failed. via remote access everything works fine - no issues. as soon as i disconnected from teamviewer and returned back to normal work - got the issue again
                            update 2. completely reinstalled mac os (from macOS Recovery - https://support.apple.com/en-us/HT204904) to the latest sierra. after setup the first thing i made - was installing latest version of photoshop (did not installed any other apps, did not plugged in any mouse or wacom tablet - just virgin unspoiled mac os). anyway got the issue again! so now it is clear that the problem for sure is NOT in mouse or other apps/drivers/periphery
                            • 11. Re: photoshop scroll bar mac os sierra issue
                              ivan.gusyev Level 1
                              update 3. just completely reinstalled mac os to Yosemite 10.10 (this version was Initially pre-installed on this macbook mid 2015 from factory). after setup the first thing I did was install it latest version of photoshop 2017 (i did not installed any other apps, did not plugged in any mouse or wacom tablet - just virgin unspoiled mac os). anyway got the same issue again!
                              so now it is clear that the problem for sure is NOT ONLY in mac os Sierra
                              • 12. Re: photoshop scroll bar mac os sierra issue
                                ivan.gusyev Level 1
                                update 4. just got the same issue on macbook pro 13 early 2015 (2,7 core i5, 8gb, Intel Iris Graphics 6100)! it was new macbook from one of a retail shops around
                                so now it is clear that the problem for sure is NOT ONLY in my macbook - it is present on all other macbooks also! (at least tested by me so far)
                                • 13. Re: photoshop scroll bar mac os sierra issue
                                  ivan.gusyev Level 1
                                  it is already 4 month passed since i have informed you regarding this issue. you promised to fix it in the future updates. still now did not received any updates from you for a long period of time. so what is the status - did you solved the issue raised in ticket 0189012423?
                                  • 14. Re: photoshop scroll bar mac os sierra issue
                                    ivan.gusyev Level 1
                                    it was fixed in recent update
