3 Replies Latest reply on Jun 10, 2017 11:38 PM by ori3185g
    Pixel Polly Issue
      Hey guys, I'm using the pixel polly effect and for some reason, when it 'explodes', the shreds of the left image are getting 'stuck' within some force field.
      Does anybody knows how to fix it so the shreds will spread away like the right layer and won't get stuck?
      Image may contain: fireworks, night and text
        • 1. Re: Pixel Polly Issue
          Mike_Abbott Adobe Community Professional
          my guess is that the layer on which pixel polly is getting 'stuck' is smaller than, or does not extend to the edge of, your comp. Pixel polly is constrained by the edges of the layer on which it sits.
          A basic solution:
          1. Remove pixel polly from that layer - cut it to the clipboard.
          2. Precompose that layer with the 'move all attributes' option selected.
          3. Paste the pixel polly effect back onto the new precomposed layer.
          • 2. Re: Pixel Polly Issue
            vishuagg19 Adobe Community Professional
            Layer size / Solid size seems to be smaller  than the composition size or edges don't cover the complete comp area.
            You can simply pre-compose the layer by right pre-compose > select Leave all attributes in "current comp" > click ok.
            Than check the Collapse the Transformation icon of the layer.
            Screen shot for reference.
            • 3. Re: Pixel Polly Issue
              ori3185g Level 1
              Thank you both!
              It worked.
