0 Replies Latest reply on Jun 8, 2017 3:26 AM by venkateshg72779630
    ld: framework not found IBMMobilePush
    venkateshg72779630
      clang: error: linker command failed with exit code 1 (use -v to see invocation)
      Build Date: 2017-06-08 03:20:22 -0700
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-console@~1.0.1" via npm
      Installing "cordova-plugin-console" for ios
      Fetching plugin "cordova-plugin-statusbar@~1.0.1" via npm
      Installing "cordova-plugin-statusbar" for ios
      Fetching plugin "cordova-plugin-device@~1.1.5" via npm
      Installing "cordova-plugin-device" for ios
      Fetching plugin "cordova-plugin-appavailability@~0.4.2" via npm
      Installing "cordova-plugin-appavailability" for ios
      Fetching plugin "cordova-plugin-whitelist@~1.3.2" via npm
      Installing "cordova-plugin-whitelist" for ios
      Fetching plugin "https://github.com/edvenkat/com.xtify.mce.sdk" via git clone
      Repository "https://github.com/edvenkat/com.xtify.mce.sdk" checked out to git ref "master".
      Installing "com.xtify.mce.sdk" for ios
      COMPILE OUTPUT
      Now using system ruby.
      Building project: /private/tmp/gimlet/2567854/project/PocCommon.xcworkspace
      Configuration: Release
      Platform: device
      User defaults from command line:
        IDEArchivePathOverride = /private/tmp/gimlet/2567854/project/PocCommon.xcarchive
      Build settings from command line:
        CONFIGURATION_BUILD_DIR = /private/tmp/gimlet/2567854/project/build/device
        SHARED_PRECOMPS_DIR = /private/tmp/gimlet/2567854/project/build/sharedpch
      Build settings from configuration file '/private/tmp/gimlet/2567854/project/cordova/build-release.xcconfig':
        ARCHS = armv7 arm64
        CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES = YES
        CODE_SIGN_ENTITLEMENTS = /tmp/gimlet/2567854/project/app.entitlements
        CODE_SIGN_IDENTITY = iPhone Developer
        CONFIGURATION_BUILD_DIR = /tmp/gimlet/2567854/project/build
        CORDOVALIB = /tmp/gimlet/2567854/project/CordovaLib
        DEVELOPMENT_TEAM = NUWQ5U6487
        ENABLE_BITCODE = false
        HEADER_SEARCH_PATHS = "$(TARGET_BUILD_DIR)/usr/local/lib/include" "$(OBJROOT)/UninstalledProducts/include" "$(OBJROOT)/UninstalledProducts/$(PLATFORM_NAME)/include" "$(BUILT_PRODUCTS_DIR)"
        IPHONEOS_DEPLOYMENT_TARGET = 8.0
        ONLY_ACTIVE_ARCH = NO
        OTHER_CODE_SIGN_FLAGS = --keychain /tmp/gimlet/2567854/secure.keychain
        OTHER_LDFLAGS = -ObjC
        PROVISIONING_PROFILE = c97fe78b-6fb1-4aaf-9522-7babfcc14839
        SWIFT_OBJC_BRIDGING_HEADER = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h
        TARGETED_DEVICE_FAMILY = 1,2
      === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
      Check dependencies
      Write auxiliary files
      /bin/mkdir -p /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb
      write-file /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch.pch.hash-criteria
      /bin/mkdir -p /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy
      write-file /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch.pch.hash-criteria
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
      SymLink /tmp/gimlet/2567854/project/build/libCordova.a /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
        cd /tmp/gimlet/2567854/project/CordovaLib
        /bin/ln -sfh /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a /tmp/gimlet/2567854/project/build/libCordova.a
      CpHeader Classes/Public/CDVWebViewEngineProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVWebViewEngineProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVScreenOrientationDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVScreenOrientationDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDV.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDV.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDV.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegateImpl.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVCommandDelegateImpl.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandQueue.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVCommandQueue.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandQueue.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVWhitelist.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVWhitelist.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVWhitelist.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAppDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVAppDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVAppDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin+Resources.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVPlugin+Resources.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin+Resources.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVUIWebViewDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAvailability.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVAvailability.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVAvailability.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPluginResult.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVPluginResult.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPluginResult.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVInvokedUrlCommand.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVInvokedUrlCommand.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/NSMutableArray+QueueAdditions.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/NSMutableArray+QueueAdditions.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/NSDictionary+CordovaPreferences.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/NSDictionary+CordovaPreferences.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVPlugin.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVURLProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVURLProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVURLProtocol.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVCommandDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandDelegate.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVAvailabilityDeprecated.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVAvailabilityDeprecated.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVUserAgentUtil.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVUserAgentUtil.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVUserAgentUtil.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVTimer.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVTimer.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVTimer.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVConfigParser.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVConfigParser.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVConfigParser.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      CpHeader Classes/Public/CDVViewController.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVViewController.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVViewController.h /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova
      ProcessPCH /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -MD -MT dependencies -MF /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch.d -c /tmp/gimlet/2567854/project/CordovaLib/CordovaLib_Prefix.pch -o /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch.dia
      ProcessPCH /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -MD -MT dependencies -MF /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch.d -c /tmp/gimlet/2567854/project/CordovaLib/CordovaLib_Prefix.pch -o /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch.dia
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferen ces.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferen ces.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferen ces.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferen ces.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVTimer.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestu reHandler.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandle OpenURL.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelega te.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelega te.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelega te.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewNavigationDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelega te.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAddition s.o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAddition s.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAddition s.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAddition s.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewEngine.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalSt orage.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter .o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-bvgwknakrcqtrybvyfx tzphlnbvb/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter .d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter .dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilt er/CDVIntentAndNavigationFilter.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter .o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferen ces.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferen ces.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferen ces.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferen ces.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVTimer.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestu reHandler.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandle OpenURL.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelega te.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelega te.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelega te.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewNavigationDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelega te.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAddition s.o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAddition s.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAddition s.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAddition s.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWe bViewEngine.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Public/CDVPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalSt orage.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter .o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaL ib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F/tmp/gimlet/2567854/project/build -include /private/tmp/gimlet/2567854/project/build/sharedpch/CordovaLib_Prefix-dlmtqbclticfvvfrcxw cddgbpfiy/CordovaLib_Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter .d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter .dia -c /tmp/gimlet/2567854/project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilt er/CDVIntentAndNavigationFilter.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter .o
      Libtool /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
        export IPHONEOS_DEPLOYMENT_TARGET=8.0
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/2567854/project/build -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
      Libtool /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/2567854/project/build -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
      CreateUniversalBinary /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a normal armv7\ arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/CordovaLib .build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
      Strip /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -S /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
      SetOwnerAndGroup phonegap:staff /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
        /usr/sbin/chown -RH phonegap:staff /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
      SetMode u+w,go-w,a+rX /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
        /bin/chmod -RH u+w,go-w,a+rX /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/libCordova.a
      === BUILD TARGET PocCommon OF PROJECT PocCommon WITH CONFIGURATION Release ===
      Check dependencies
      Write auxiliary files
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon.LinkFileList
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon.LinkFileList
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Script-304B58A110DAC018002A0835.sh
      chmod 0755 /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Script-304B58A110DAC018002A0835.sh
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-all-non-framework-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap
      /bin/mkdir -p /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc
      write-file /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch.pch.hash-criteria
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap
      write-file /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap
      /bin/mkdir -p /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr
      write-file /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch.pch.hash-criteria
      Create product structure
      /bin/mkdir -p /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app
      SymLink build/PocCommon.app /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app
        /bin/ln -sfh /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app /tmp/gimlet/2567854/project/build/PocCommon.app
      PhaseScriptExecution Copy\ www\ directory /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Script-304B58A110DAC018002A0835.sh
        /bin/sh -c /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Script-304B58A110DAC018002A0835.sh
      CompileXIB PocCommon/Classes/MainViewController.xib
        export XCODE_DEVELOPER_USR_PATH=/Applications/Xcode.app/Contents/Developer/usr/bin/..
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module PocCommon --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/MainViewController-PartialInfo.plist --auto-activate-custom-fonts --target-device iphone --target-device ipad --minimum-deployment-target 8.0 --output-format human-readable-text --compile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app/MainViewController.nib /tmp/gimlet/2567854/project/PocCommon/Classes/MainViewController.xib
      CompileAssetCatalog /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app PocCommon/Images.xcassets
        /Applications/Xcode.app/Contents/Developer/usr/bin/actool --output-format human-readable-text --notices --warnings --export-dependency-info /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/assetcatalog_dependencies --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/assetcatalog_generated_info.plist --app-icon AppIcon --launch-image LaunchImage --compress-pngs --enable-on-demand-resources YES --sticker-pack-identifier-prefix .sticker-pack. --target-device iphone --target-device ipad --minimum-deployment-target 8.0 --platform iphoneos --product-type com.apple.product-type.application --compile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app /tmp/gimlet/2567854/project/PocCommon/Images.xcassets
      /* com.apple.actool.document.notices */
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][iphone][57x5 7][][][1x]: notice: 57x57 app icons only apply to iPhone apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][iphone][57x5 7][][][2x]: notice: 57x57@2x app icons only apply to iPhone apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][ipad][50x50] [][][1x]: notice: 50x50 iPad spotlight icons only apply to iPad apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][ipad][50x50] [][][2x]: notice: 50x50 iPad spotlight icons only apply to iPad apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][ipad][72x72] [][][1x]: notice: 72x72 app icons only apply to iPad apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./AppIcon.appiconset/[][ipad][72x72] [][][2x]: notice: 72x72@2x app icons only apply to iPad apps targeting releases of iOS prior to 7.0
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][] [1x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][] [2x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][r etina4][2x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[ipad][][1 x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[ipad][][2 x][portrait][full-screen][]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][7 36h][3x][portrait][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][7 36h][3x][landscape][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /tmp/gimlet/2567854/project/PocCommon/Images.xcassets:./LaunchImage.launchimage/[iphone][6 67h][2x][portrait][full-screen][8.0]: notice: This launch image only applies to iOS 6.x and prior but the minimum deployment is 7.0 or later.
      /* com.apple.actool.compilation-results */
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon29x29.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon29x29@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon29x29@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon40x40@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon40x40@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon57x57.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon57x57@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon60x60@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon60x60@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon29x29~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon29x29@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon40x40~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon40x40@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon50x50~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon50x50@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon72x72~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon72x72@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon76x76~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon76x76@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/AppIcon83.5x83.5@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-568h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-Portrait~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-Portrait@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-800-Portrait-736h@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-800-Landscape-736h@3x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-800-667h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700-568h@2x.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700-Portrait~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700-Landscape~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700-Portrait@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/Appl ications/PocCommon.app/LaunchImage-700-Landscape@2x~ipad.png
      /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbji /Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon.b uild/Release-iphoneos/PocCommon.build/assetcatalog_generated_info.plist
      CompileStoryboard PocCommon/CDVLaunchScreen.storyboard
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module PocCommon --output-partial-info-plist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/CDVLaunchScreen-SBPartialInfo.plist --auto-activate-custom-fonts --target-device iphone --target-device ipad --minimum-deployment-target 8.0 --output-format human-readable-text --compilation-directory /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build /tmp/gimlet/2567854/project/PocCommon/CDVLaunchScreen.storyboard
      ProcessInfoPlistFile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app/Info.plist PocCommon/PocCommon-Info.plist
        builtin-infoPlistUtility /tmp/gimlet/2567854/project/PocCommon/PocCommon-Info.plist -genpkginfo /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app/PkgInfo -expandbuildsettings -format binary -platform iphoneos -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/MainViewController-PartialInfo.plist -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/CDVLaunchScreen-SBPartialInfo.plist -additionalcontentfile /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/assetcatalog_generated_info.plist -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app/Info.plist
      LinkStoryboards
        /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --errors --warnings --notices --module PocCommon --target-device iphone --target-device ipad --minimum-deployment-target 8.0 --output-format human-readable-text --link /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/App lications/PocCommon.app /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/CDVLaunchScreen.storyboardc
      ProcessPCH /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch.pch PocCommon/PocCommon-Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -MD -MT dependencies -MF /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch.d -c /tmp/gimlet/2567854/project/PocCommon/PocCommon-Prefix.pch -o /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch.dia
      ProcessPCH /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch.pch PocCommon/PocCommon-Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -MD -MT dependencies -MF /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch.d -c /tmp/gimlet/2567854/project/PocCommon/PocCommon-Prefix.pch -o /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch.pch --serialize-diagnostics /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch.dia
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/main.o PocCommon/main.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/main.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/main.dia -c /tmp/gimlet/2567854/project/PocCommon/main.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/main.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MainViewController.o PocCommon/Classes/MainViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MainViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MainViewController.dia -c /tmp/gimlet/2567854/project/PocCommon/Classes/MainViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MainViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate.o PocCommon/Classes/AppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate.dia -c /tmp/gimlet/2567854/project/PocCommon/Classes/AppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVLogger.o PocCommon/Plugins/cordova-plugin-console/CDVLogger.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVLogger.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVLogger.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-console/CDVLogger.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVLogger.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVStatusBar.o PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVStatusBar.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVStatusBar.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVStatusBar.o
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:171: 95: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
        statusBarFrame = [self invertFrameIfNeeded:statusBarFrame orientation:self.viewController.interfaceOrientation];
      In module 'UIKit' imported from /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVPlugin.h:21:
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIViewController.h:314:54: note: 'interfaceOrientation' has been explicitly marked deprecated here
      @property(nonatomic,readonly) UIInterfaceOrientation interfaceOrientation NS_DEPRECATED_IOS(2_0,8_0) __TVOS_PROHIBITED;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:182: 40: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
        if (UIDeviceOrientationIsLandscape(orientation) && (rect.size.width < rect.size.height) ) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:204: 64: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
        if (UIDeviceOrientationIsLandscape(self.viewController.interfaceOrientation)) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:204: 44: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:213: 99: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:294: 32: warning: 'UIStatusBarStyleBlackTranslucent' is deprecated: first deprecated in iOS 7.0 - Use UIStatusBarStyleLightContent [-Wdeprecated-declarations]
        [self setStyleForStatusBar:UIStatusBarStyleBlackTranslucent];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:23:5: note: 'UIStatusBarStyleBlackTranslucent' has been explicitly marked deprecated here
        UIStatusBarStyleBlackTranslucent NS_ENUM_DEPRECATED_IOS(2_0, 7_0, "Use UIStatusBarStyleLightContent") = 1,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:299: 32: warning: 'UIStatusBarStyleBlackOpaque' is deprecated: first deprecated in iOS 7.0 - Use UIStatusBarStyleLightContent [-Wdeprecated-declarations]
        [self setStyleForStatusBar:UIStatusBarStyleBlackOpaque];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:24:5: note: 'UIStatusBarStyleBlackOpaque' has been explicitly marked deprecated here
        UIStatusBarStyleBlackOpaque NS_ENUM_DEPRECATED_IOS(2_0, 7_0, "Use UIStatusBarStyleLightContent") = 2,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:359: 29: warning: 'wantsFullScreenLayout' is deprecated: first deprecated in iOS 7.0 [-Wdeprecated-declarations]
        self.viewController.wantsFullScreenLayout = YES;
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIViewController.h:249:34: note: 'wantsFullScreenLayout' has been explicitly marked deprecated here
      @property(nonatomic,assign) BOOL wantsFullScreenLayout NS_DEPRECATED_IOS(3_0, 7_0) __TVOS_PROHIBITED; // Deprecated in 7_0, Replaced by the following:
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:373: 72: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:373: 52: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:407: 29: warning: 'wantsFullScreenLayout' is deprecated: first deprecated in iOS 7.0 [-Wdeprecated-declarations]
        self.viewController.wantsFullScreenLayout = isIOS7;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:416: 103: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      12 warnings generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVDevice.o PocCommon/Plugins/cordova-plugin-device/CDVDevice.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVDevice.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVDevice.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-device/CDVDevice.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/CDVDevice.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppAvailability.o PocCommon/Plugins/cordova-plugin-appavailability/AppAvailability.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppAvailability.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppAvailability.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-appavailability/AppAvailabil ity.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppAvailability.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate+MCE.o PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate+MCE.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate+MCE.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/AppDelegate+MCE.o
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEBeaconManager.h' [-Wincomplete-umbrella]
      #import "Headers/IBMMobilePush.h"
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCECustom.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCECustomRule.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEGeofenceManager.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlace.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlaceDailyVisit.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlaceVisit.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEVisitOperation.h' [-Wincomplete-umbrella]
      8 warnings generated.
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:9: warning: 'UIRemoteNotificationType' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
        UIRemoteNotificationType myTypes = UIRemoteNotificationTypeBadge | UIRemoteNotificationTypeAlert | UIRemoteNotificationTypeSound;
      In module 'UIKit' imported from /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVViewController.h:20:
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:68:32: note: 'UIRemoteNotificationType' has been explicitly marked deprecated here
      typedef NS_OPTIONS(NSUInteger, UIRemoteNotificationType) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:44: warning: 'UIRemoteNotificationTypeBadge' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:70:5: note: 'UIRemoteNotificationTypeBadge' has been explicitly marked deprecated here
        UIRemoteNotificationTypeBadge = 1 << 0,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:76: warning: 'UIRemoteNotificationTypeAlert' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:72:5: note: 'UIRemoteNotificationTypeAlert' has been explicitly marked deprecated here
        UIRemoteNotificationTypeAlert = 1 << 2,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:108: warning: 'UIRemoteNotificationTypeSound' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:71:5: note: 'UIRemoteNotificationTypeSound' has been explicitly marked deprecated here
        UIRemoteNotificationTypeSound = 1 << 1,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:135:22: warning: 'registerForRemoteNotificationTypes:' is deprecated: first deprecated in iOS 8.0 - Use -[UIApplication registerForRemoteNotifications] and UserNotifications Framework's -[UNUserNotificationCenter requestAuthorizationWithOptions:completionHandler:] [-Wdeprecated-declarations]
        [application registerForRemoteNotificationTypes:myTypes];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:210:1: note: 'registerForRemoteNotificationTypes:' has been explicitly marked deprecated here
      - (void)registerForRemoteNotificationTypes:(UIRemoteNotificationType)types NS_DEPRECATED_IOS(3_0, 8_0, "Use -[UIApplication registerForRemoteNotifications] and UserNotifications Framework's -[UNUserNotificationCenter requestAuthorizationWithOptions:completionHandler:]") __TVOS_PROHIBITED;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:248:60: warning: incompatible pointer types sending 'AppDelegate *' to parameter of type 'NSObject<MCEActionProtocol> *' [-Wincompatible-pointer-types]
        [[MCEActionRegistry sharedInstance] registerTarget:self withSelector:@selector(action:payload:) forAction:type];
      In module 'IBMMobilePush' imported from /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:13:
      PocCommon/Plugins/com.xtify.mce.sdk/IBMMobilePush.framework/Headers/MCEActionRegistry.h:51 :55: note: passing argument to parameter 'target' here
      -(BOOL)registerTarget:(NSObject <MCEActionProtocol> *)target withSelector:(SEL)selector forAction:(NSString*)type;
      14 warnings generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEPlugin.o PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEPlugin.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEPlugin.o
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m:231:56: warning: incompatible pointer types sending 'AppDelegate *' to parameter of type 'NSObject<MCEActionProtocol> *' [-Wincompatible-pointer-types]
        [[MCEActionRegistry sharedInstance] registerTarget:appDelegate withSelector:@selector(action:payload:) forAction:type];
      In module 'IBMMobilePush' imported from /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m:11:
      1 warning generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEEventCallbackQueue.o PocCommon/Plugins/com.xtify.mce.sdk/MCEEventCallbackQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/armv7 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-hfnezdjkprgfrdaaeiai opqhghyr/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEEventCallbackQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEEventCallbackQueue.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEEventCallbackQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/MCEEventCallbackQueue.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/main.o PocCommon/main.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/main.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/main.dia -c /tmp/gimlet/2567854/project/PocCommon/main.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/main.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate.o PocCommon/Classes/AppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate.dia -c /tmp/gimlet/2567854/project/PocCommon/Classes/AppDelegate.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MainViewController.o PocCommon/Classes/MainViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /tmp/gimlet/2567854/project
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MainViewController.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MainViewController.dia -c /tmp/gimlet/2567854/project/PocCommon/Classes/MainViewController.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MainViewController.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVLogger.o PocCommon/Plugins/cordova-plugin-console/CDVLogger.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVLogger.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVLogger.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-console/CDVLogger.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVLogger.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVStatusBar.o PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVStatusBar.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVStatusBar.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVStatusBar.o
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:171: 95: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
        statusBarFrame = [self invertFrameIfNeeded:statusBarFrame orientation:self.viewController.interfaceOrientation];
      In module 'UIKit' imported from /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVPlugin.h:21:
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIViewController.h:314:54: note: 'interfaceOrientation' has been explicitly marked deprecated here
      @property(nonatomic,readonly) UIInterfaceOrientation interfaceOrientation NS_DEPRECATED_IOS(2_0,8_0) __TVOS_PROHIBITED;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:182: 40: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
        if (UIDeviceOrientationIsLandscape(orientation) && (rect.size.width < rect.size.height) ) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:204: 64: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
        if (UIDeviceOrientationIsLandscape(self.viewController.interfaceOrientation)) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:204: 44: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:213: 99: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:294: 32: warning: 'UIStatusBarStyleBlackTranslucent' is deprecated: first deprecated in iOS 7.0 - Use UIStatusBarStyleLightContent [-Wdeprecated-declarations]
        [self setStyleForStatusBar:UIStatusBarStyleBlackTranslucent];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:23:5: note: 'UIStatusBarStyleBlackTranslucent' has been explicitly marked deprecated here
        UIStatusBarStyleBlackTranslucent NS_ENUM_DEPRECATED_IOS(2_0, 7_0, "Use UIStatusBarStyleLightContent") = 1,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:299: 32: warning: 'UIStatusBarStyleBlackOpaque' is deprecated: first deprecated in iOS 7.0 - Use UIStatusBarStyleLightContent [-Wdeprecated-declarations]
        [self setStyleForStatusBar:UIStatusBarStyleBlackOpaque];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:24:5: note: 'UIStatusBarStyleBlackOpaque' has been explicitly marked deprecated here
        UIStatusBarStyleBlackOpaque NS_ENUM_DEPRECATED_IOS(2_0, 7_0, "Use UIStatusBarStyleLightContent") = 2,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:359: 29: warning: 'wantsFullScreenLayout' is deprecated: first deprecated in iOS 7.0 [-Wdeprecated-declarations]
        self.viewController.wantsFullScreenLayout = YES;
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIViewController.h:249:34: note: 'wantsFullScreenLayout' has been explicitly marked deprecated here
      @property(nonatomic,assign) BOOL wantsFullScreenLayout NS_DEPRECATED_IOS(3_0, 7_0) __TVOS_PROHIBITED; // Deprecated in 7_0, Replaced by the following:
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:373: 72: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:373: 52: warning: implicit conversion from enumeration type 'UIInterfaceOrientation' (aka 'enum UIInterfaceOrientation') to different enumeration type 'UIDeviceOrientation' (aka 'enum UIDeviceOrientation') [-Wenum-conversion]
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:407: 29: warning: 'wantsFullScreenLayout' is deprecated: first deprecated in iOS 7.0 [-Wdeprecated-declarations]
        self.viewController.wantsFullScreenLayout = isIOS7;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-statusbar/CDVStatusBar.m:416: 103: warning: 'interfaceOrientation' is deprecated: first deprecated in iOS 8.0 [-Wdeprecated-declarations]
      12 warnings generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVDevice.o PocCommon/Plugins/cordova-plugin-device/CDVDevice.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVDevice.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVDevice.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-device/CDVDevice.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/CDVDevice.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppAvailability.o PocCommon/Plugins/cordova-plugin-appavailability/AppAvailability.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppAvailability.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppAvailability.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/cordova-plugin-appavailability/AppAvailabil ity.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppAvailability.o
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate+MCE.o PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate+MCE.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate+MCE.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/AppDelegate+MCE.o
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEBeaconManager.h' [-Wincomplete-umbrella]
      #import "Headers/IBMMobilePush.h"
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCECustom.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCECustomRule.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEGeofenceManager.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlace.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlaceDailyVisit.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEPlaceVisit.h' [-Wincomplete-umbrella]
      <module-includes>:1:1: warning: umbrella header for module 'IBMMobilePush' does not include header 'MCEVisitOperation.h' [-Wincomplete-umbrella]
      8 warnings generated.
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:9: warning: 'UIRemoteNotificationType' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
        UIRemoteNotificationType myTypes = UIRemoteNotificationTypeBadge | UIRemoteNotificationTypeAlert | UIRemoteNotificationTypeSound;
      In module 'UIKit' imported from /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstalle dProducts/iphoneos/include/Cordova/CDVViewController.h:20:
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:68:32: note: 'UIRemoteNotificationType' has been explicitly marked deprecated here
      typedef NS_OPTIONS(NSUInteger, UIRemoteNotificationType) {
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:44: warning: 'UIRemoteNotificationTypeBadge' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:70:5: note: 'UIRemoteNotificationTypeBadge' has been explicitly marked deprecated here
        UIRemoteNotificationTypeBadge = 1 << 0,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:76: warning: 'UIRemoteNotificationTypeAlert' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:72:5: note: 'UIRemoteNotificationTypeAlert' has been explicitly marked deprecated here
        UIRemoteNotificationTypeAlert = 1 << 2,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:134:108: warning: 'UIRemoteNotificationTypeSound' is deprecated: first deprecated in iOS 8.0 - Use UserNotifications Framework's UNAuthorizationOptions for user notifications and registerForRemoteNotifications for receiving remote notifications instead. [-Wdeprecated-declarations]
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:71:5: note: 'UIRemoteNotificationTypeSound' has been explicitly marked deprecated here
        UIRemoteNotificationTypeSound = 1 << 1,
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:135:22: warning: 'registerForRemoteNotificationTypes:' is deprecated: first deprecated in iOS 8.0 - Use -[UIApplication registerForRemoteNotifications] and UserNotifications Framework's -[UNUserNotificationCenter requestAuthorizationWithOptions:completionHandler:] [-Wdeprecated-declarations]
        [application registerForRemoteNotificationTypes:myTypes];
      /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPho neOS10.1.sdk/System/Library/Frameworks/UIKit.framework/Headers/UIApplication.h:210:1: note: 'registerForRemoteNotificationTypes:' has been explicitly marked deprecated here
      - (void)registerForRemoteNotificationTypes:(UIRemoteNotificationType)types NS_DEPRECATED_IOS(3_0, 8_0, "Use -[UIApplication registerForRemoteNotifications] and UserNotifications Framework's -[UNUserNotificationCenter requestAuthorizationWithOptions:completionHandler:]") __TVOS_PROHIBITED;
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:248:60: warning: incompatible pointer types sending 'AppDelegate *' to parameter of type 'NSObject<MCEActionProtocol> *' [-Wincompatible-pointer-types]
        [[MCEActionRegistry sharedInstance] registerTarget:self withSelector:@selector(action:payload:) forAction:type];
      In module 'IBMMobilePush' imported from /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/AppDelegate+MCE.m:13:
      PocCommon/Plugins/com.xtify.mce.sdk/IBMMobilePush.framework/Headers/MCEActionRegistry.h:51 :55: note: passing argument to parameter 'target' here
      -(BOOL)registerTarget:(NSObject <MCEActionProtocol> *)target withSelector:(SEL)selector forAction:(NSString*)type;
      14 warnings generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEPlugin.o PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEPlugin.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEPlugin.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEPlugin.o
      /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m:231:56: warning: incompatible pointer types sending 'AppDelegate *' to parameter of type 'NSObject<MCEActionProtocol> *' [-Wincompatible-pointer-types]
        [[MCEActionRegistry sharedInstance] registerTarget:appDelegate withSelector:@selector(action:payload:) forAction:type];
      In module 'IBMMobilePush' imported from /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEPlugin.m:11:
      1 warning generated.
      CompileC /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEEventCallbackQueue.o PocCommon/Plugins/com.xtify.mce.sdk/MCEEventCallbackQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-cache-path=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Users/phonegap/Library/Developer/Xcode/DerivedData/ModuleCache/Sess ion.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -fvisibility=hidden -Wno-sign-conversion -Wno-infinite-recursion -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-generated-files.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-own-target-headers.hmap -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/PocCommon-all-target-headers.hmap -iquote /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/PocCommon-project-headers.hmap -I/tmp/gimlet/2567854/project/build/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/InstallationBuildProductsLocation/A pplications/usr/local/lib/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/include -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/Uninstal ledProducts/iphoneos/include -I/tmp/gimlet/2567854/project/build -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources/arm64 -I/Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsm bji/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommo n.build/Release-iphoneos/PocCommon.build/DerivedSources -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -include /private/tmp/gimlet/2567854/project/build/sharedpch/PocCommon-Prefix-clwibryutfpvdyfyfxss tobynoxc/PocCommon-Prefix.pch -MMD -MT dependencies -MF /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEEventCallbackQueue.d --serialize-diagnostics /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEEventCallbackQueue.dia -c /tmp/gimlet/2567854/project/PocCommon/Plugins/com.xtify.mce.sdk/MCEEventCallbackQueue.m -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/MCEEventCallbackQueue.o
      Ld /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon normal armv7
        export IPHONEOS_DEPLOYMENT_TARGET=8.0
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -arch armv7 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/2567854/project/build -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon.LinkFileList -Xlinker -rpath -Xlinker @executable_path/Frameworks -miphoneos-version-min=8.0 -dead_strip -Xlinker -object_path_lto -Xlinker /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon_lto.o -fobjc-arc -fobjc-link-runtime -ObjC /tmp/gimlet/2567854/project/build/libCordova.a -lz -framework IBMMobilePush -framework CoreTelephony -framework CoreLocation -lsqlite3 -Xlinker -dependency_info -Xlinker /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon_dependency_info.dat -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/armv7/PocCommon
      ld: framework not found IBMMobilePush
      clang: error: linker command failed with exit code 1 (use -v to see invocation)
      Ld /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon normal arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -L/tmp/gimlet/2567854/project/build -F/tmp/gimlet/2567854/project/build -FPocCommon/Plugins/com.xtify.mce.sdk -filelist /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon.LinkFileList -Xlinker -rpath -Xlinker @executable_path/Frameworks -miphoneos-version-min=8.0 -dead_strip -Xlinker -object_path_lto -Xlinker /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon_lto.o -fobjc-arc -fobjc-link-runtime -ObjC /tmp/gimlet/2567854/project/build/libCordova.a -lz -framework IBMMobilePush -framework CoreTelephony -framework CoreLocation -lsqlite3 -Xlinker -dependency_info -Xlinker /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon_dependency_info.dat -o /Users/phonegap/Library/Developer/Xcode/DerivedData/PocCommon-ctlfczaxzyhuupbwlnhvsjpsmbj i/Build/Intermediates/ArchiveIntermediates/PocCommon/IntermediateBuildFilesPath/PocCommon. build/Release-iphoneos/PocCommon.build/Objects-normal/arm64/PocCommon
      ** ARCHIVE FAILED **
      The following build commands failed:
      (2 failures)
      Error code 65 for command: xcodebuild with args: -xcconfig,/private/tmp/gimlet/2567854/project/cordova/build-release.xcconfig,-workspace,P ocCommon.xcworkspace,-scheme,PocCommon,-configuration,Release,-destination,generic/platfor m=iOS,-archivePath,PocCommon.xcarchive,archive,CONFIGURATION_BUILD_DIR=/private/tmp/gimlet /2567854/project/build/device,SHARED_PRECOMPS_DIR=/private/tmp/gimlet/2567854/project/buil d/sharedpch
