1 Reply Latest reply on Jun 9, 2017 1:58 AM by LeoTaro
    Add a bitmap to a button
    Pierrot Dev
      I have compiled the sample code "EmptyPanel" of the sdk, then made my own version with a control bar and some buttons.
      I would like to add bitmaps to the buttons, adding the BS_BITMAP style to the native windows buttons then sending
      hInst = (HINSTANCE)GetWindowLongPtr((HWND)ctrlBarPlatformWindow, GWLP_HINSTANCE);
      hBmp = LoadBitmap(hInst, MAKEINTRESOURCE(IDB_BITMAP1));
      hBmp hInst are global to the plugin class. hBmp returns 0;
      then
      SendMessage((HWND)hwndButtonPrevious, (UINT)BM_SETIMAGE, (WPARAM)IMAGE_BITMAP, (LPARAM)hBmp);
      The function is called in the CtrlBarWindowProc between two Push/Pop AppContext otherwise not working.
      Buttons are responding normally to command and make the job.
      But I never had any image on it!
      I tried many variations, but nothing happen.
      I guess something wrong with hInst, hBmp, or the place where I Send the BM_SETIMAGE message
      Any idea?
      Pierre
        • 1. Re: Add a bitmap to a button
          LeoTaro Level 4
          The LoadBitmap call is failing (hBmp is NULL), because you are using the application HINSTANCE rather than the one for your plugin (dll). Add a DllMain function to your plugin and store the HINSTANCE.
          HINSTANCE hDll = NULL;
          BOOL APIENTRY DllMain( HINSTANCE hinstDLL, DWORD ul_reason, LPVOID reserved)
            if (DLL_PROCESS_ATTACH == ul_reason)
                 hDll = hinstDLL;
            return TRUE;
