1 Reply Latest reply on Jun 9, 2017 8:41 AM by kerrishotts
      • 1. Re: Can you tell me "Reactjs" mobile app folder structure for phongap legacy build???
        kerrishotts Adobe Community Professional
        PhoneGap Build does not enforce much structure beyond having a "config.xml" file, and that it either needs to be a sibling of "index.html" or in the parent directory with "index.html" inside a "www" folder. Beyond that, you can use whatever structure you want.
        Valid structures:
        zip-root/
           config.xml
           index.html
           res/
           etc.
        zip-root/
           config.xml
           res/
           www/
               index.html
               etc.
        (Note: access to icons and splash resources are relative to config.xml, and usually placed in a res/ directory that's a sibling to config.xml.)
        Beyond the above, PhoneGap Build doesn't enforce anything. If you're having problems, please share platforms, OS versions, plugins you're using, sample code that has the issue, and the error messages you're receiving.
