2 Replies Latest reply on Jun 9, 2017 8:12 AM by marcelt2t
    objects at 100% ?
    marcelt2t Level 1
      Sometimes I place one object inside the other, both the identical size, set to responsive width, yet when the browser stretches I find one sizes slightly different than the other, leaving a 1-2 pixel deviation.  This is most noticeable when dealing with keylines (see examples below)
      We can set object to 100% of the browser width, but it seems we should have the option of 100% when placed inside another object (button) as well to avoid this problem.  Has anyone found a fix?
      These examples show button in button, but I get the same with rectangles simply placed on top of each other as well
      in muse;
      outer object;
      inner object;
      result in stretched browser (note the right edge);
        • 1. Re: objects at 100% ?
          Ussnorway Adobe Community Professional
          no you can't
          the corrent code is to set to browser width
          change the way the internet works
          • 2. Re: objects at 100% ?
            marcelt2t Level 1
            Hey Ussnorway,
            Not to challenge you, but setting an object to fill browser width, is basically the same as 100%
            And when coding manually you can infact set a width of 100% on a div/object, which then fills 100% of it's container, be it another div or the entire page.
            Responsive/fluid on the other hand is using relative positioning percentages, hence Muses lack of control in regards to only using one system.
