Hello CBE,
If you want to show multiple ways to navigate correctly, you
would need to record it one way, then in editing go back to that
screen and add the other 2 correct possibilities (clickboxes).
There really isn't a way to add multiple correct actions on the fly
while recording.
But that is not really branching
Lets say you get to that fork in the road, where a user
could use multiple ways to move on to the correct item maybe by
different paths which would require different screens (all roads
leading to rome).
Record all three into the same file (or multiple files if you
like) then use your fork in the road to point to the slide where
the path would be different, and by your description all come back
to one. That is simple branching.
Hope that helps,
TM
