1 Reply Latest reply on Jun 10, 2017 11:01 AM by kerrishotts
    From cli-6.2.0 to 6.5.0 phonegap does not compile my app
    isaiass18
      I have no idea what happens, this is my log when compiling:
      Build Date: 2017-06-10 07:41:51 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      null
      org.xwalk:xwalk_core_library:19+
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportCardviewV72340Library
      :prepareComAndroidSupportCustomtabs2340Library
      :prepareComAndroidSupportSupportCompat2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUi2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUtils2600Alpha1Library
      :prepareComAndroidSupportSupportFragment2600Alpha1Library
      :prepareComAndroidSupportSupportMediaCompat2600Alpha1Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42600Alpha1Library
      :prepareComFacebookAndroidFacebookAndroidSdk4141Library
      :prepareComGoogleAndroidGmsPlayServicesAuth1026Library
      :prepareComGoogleAndroidGmsPlayServicesAuthBase1026Library
      :prepareComGoogleAndroidGmsPlayServicesBase1026Library
      :prepareComGoogleAndroidGmsPlayServicesBasement1026Library
      :prepareComGoogleAndroidGmsPlayServicesGcm1026Library
      :prepareComGoogleAndroidGmsPlayServicesIdentity1026Library
      :prepareComGoogleAndroidGmsPlayServicesIid1026Library
      :prepareComGoogleAndroidGmsPlayServicesTasks1026Library
      :prepareOrgXwalkXwalk_core_library19495145Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseAssets
      :createXwalkCommandLineFileRelease
      :mergeReleaseResources
      /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:55: error: XWalkWebViewEngine is not abstract and does not override abstract method evaluateJavascript(String,ValueCallback<String>) in CordovaWebViewEngine
      public class XWalkWebViewEngine implements CordovaWebViewEngine {
      Note: /project/src/com/adobe/phonegap/push/PushPlugin.java uses unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      1 error
      :compileReleaseJavaWithJavac FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':compileReleaseJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 8.491 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      1 error
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: From cli-6.2.0 to 6.5.0 phonegap does not compile my app
          kerrishotts Adobe Community Professional
          When you update your CLI, you will usually need to update some plugins. Best guess here is that you're using an older version of the Crosswalk plugin and need to bump the version #. OTH, if you're using the most recent version, you can try a version or two previous just in case the issue is a recent regression.
          (Side note: Crosswalk is EOL. If you're targeting Android 5+, you should be able to do without.)
