9 Replies Latest reply on Jun 11, 2017 10:57 AM by davescm
    Brochure template design
    nkaretnikov
      Hello!
      there are tonnes of mock-ups out there that are great!
      With some one can easily do things like
      (Double-Gate-Fold-Brochure-Vol3-PIXEDEN)
      Sometimes though you have a particular thought in mind and cannot find a template of your dream.
      So, the Q goes. How to create a template? Again, youtube full of videos on how to use an already created mock-up or videos that claim to teach you but fails to deliver (e.x. Design A Polygon Tri Fold Brochure Cover Photoshop Tutorial - YouTube  ). I watched it but have no idea how to make the design folded and 3d-like (see that nice transition from the 5th to the 7th second of the video)
      So, what I would like to use is a tutorial on how to create a mock-up template from scratch. How to fold, add shadows, make a brochure look real.
        • 1. Re: Brochure template design
          Derek Cross Adobe Community Professional
          The best Adobe application for producing a brochure is InDesign. The images can be optimised in Photoshop.
          This Lynda.com online video tutorial shows you how: Designing a Brochure (you can a 30-day free trial).
          • 2. Re: Brochure template design
            nkaretnikov Level 1
            Thank you, Derek! But there is a catch, unfortunately.
            All those videos teach how to create a brochure for printing. What I'd like to get is a mock-up that imitates a brochure printed, I don't really intend to create a real brochure on paper.
            Here is an example Free-Tri-Fold-Mockup-PSD-File.psd 25 (unhide Ungroup, RGB8) (158 kb) 2017 г. Joxi That psd file has 4 smart objects to create a picture of a printed brochure, but the mock-up itself is not quite right and I have no idea how to change it. When trying to move it level by level all the shadows get mixed up
            1497103061447 (237 kb)  2017 г. Joxi
            My goal is to learn how to create a similar psd.
            • 3. Re: Brochure template design
              davescm Adobe Community Professional
              Here is a very quick way that you can adapt as needed.
              Starting with a flat mock up - in this case just a picture with three text boxes
              Select the image and text layers (not the white background) and right click and Convert to Smart object.
              With the Smart object layer selected Go to Edit Perpective Warp and add Layout grids in 3 sections
              Switch to Warp and pull the handles
              Tick in the options bar to make the changes
              Right click on the layer and in Blending options - layer styles add a drop shadow
              Add an empty new layer above the smart object and Alt Click on the border between the two in the layers panel so that it clips to the layer below ( a small downward arrow will appear).
              Set the blending mode of this layer to luminosity
              Make a rectangular selection over the centre "page" then paint with a soft black brush set to low opacity onto the new layer added above - this will paint a shadow
              A few more shadows and that is it
              You can modify this however you wish. Hopefully this gets you started
              Dave
              • 4. Re: Brochure template design
                Before I deleted the file from the last post I also used an alternative approach.
                This time I made a 3D extrusion in the shape of the leaflet and dropped the leaflet layout  smart object from the last post onto the extrusion material.
                This time the 3D lighting took care of the shading.
                The magnifying glass was a model I made for another post answer. I decided to use it again before I deleted it . The point being you can add objects around your mock up leaflet to make it look real.
                Dave
                • 5. Re: Brochure template design
                  nkaretnikov Level 1
                  Thank you, Dave!
                  Following your 1st advice I've easily created a rough approximation of the leaflet
                  1497142351118 (199 kb) 2017 г. Joxi
                  but not so lucky with the 3D approach.
                  Would you please tell how exactly do you create a 3D extrusion in the shape of the leaflet?
                  • 6. Re: Brochure template design
                    Sure,
                    Use the pen tool to make a path in the shape of the edge of the leaflet. It must be a closed path:
                    In the 3D panel choose 3D Extrusion - with the source as workpath
                    Rotate it 90 degrees on the x axis
                    Scale it on the z axis and in the Properties panel click on "Move to Ground"
                    Now you can just click on the extrusion material and in the properties panel click the folder next to diffuse and choose edit texture
                    This will open a psb document where you can add the document image as I showed in my previous post
                    Hope that helps
                    Dave
                    • 7. Re: Brochure template design
                      cmgap Adobe Community Professional
                      Nice Dave.
                      • 8. Re: Brochure template design
                        nkaretnikov Level 1
                        Thank you, Dave!
                        3D approach is way advanced as far as I can see!
                        Working with 3D without any experience is scaring though
                        On the step "rotate 90 degrees" CC2017 shows no X-Y-Z axis widget.
                        I have "View\Extras" selected and "Show Extras Options" all selected
                        Would by any chance you know how to make CC2017 display it?
                        • 9. Re: Brochure template design
                          You know - I don't know how to turn on and off the 3D axis tool. It is always just there.
                          As far as I remember there used to be a Shows - 3D Axis option but as I never switched that off, I don't know when it no longer appeared.
                          You could got to preferences Performance and try changing the drawing modes to see if it will appear (you will need to restart after changing)
                          In the meantime , even without that tool you can still rotate.
                          Either go to View - Show - 3D Mesh bounding box and tick it then rotate by grabbing the bounding box
                          or
                          With the object selected in the 3D panel - go to the properties panel - select Co-ordinates and enter the rotation directly
                          Dave
