23 Replies Latest reply on Jun 23, 2017 8:27 AM by ZNB
    select date
    ZNB
      <cfset DateSelect=16/07/2017>
      <cfset NumJour=#Dayofweek(DateSelect -1)#>
      <cfset Dim=#dateadd('D',-NumJour,DateSelect)#>
      <CFQUERY name="MajAgenda2" datasource="#session.dbname#">
            SELECT AgendaObjet FROM Agenda WHERE AgendaDateDeb=#DateSelect# GROUP BY AgendaObjet
      </CFQUERY>
      <CFOUTPUT>MajAgenda2.recordcount :# MajAgenda2.recordcount# </CFOUTPUT>
      <CFOUTPUT query="MajAgenda2">
              <cfset AgendaObjet="#AgendaObjet#">
      </CFOUTPUT>
      Hello,
      I try to select an item for a date with no result
      Thank you for your help
      cordially
        • 1. Re: select date
          WolfShade Level 4
          Hello,
          The first thing you need to do is to CFSET the date within quotes:
          <cfset DateSelect = "16/07/2017" />
          Then use CFQUERYPARAM and CREATEODBCDATE in your query:
          <cfquery>
               SELECT AgendaObjet
               FROM Agenda
               WHERE AgendaDateDeb=<cfqueryparam value="#CreateODBCDate(DateSelect)#" />
          </cfquery>
          HTH,
          ^ _ ^
          • 2. Re: select date
            BKBK Adobe Community Professional & MVP
            <cfset dateSelect = createDate(2017,6,17)>
            If you wish to subtract one day, the use
            <cfset NumJour=dayOfWeek(dateadd('D',-1,DateSelect))>
            • 3. Re: select date
              ZNB Level 1
                      I now have an error message: "Syntax error in string in query expression 'CalendarDateDeb = # 11/6/2017 00: 00: 00 #" AND sitename =' SoBoat 'GROUP BY AgendaObject'. "With the following code:
                   <CFOUTPUT>
                     <cfset DateSelect="17/06/2017">
                     <!--- <cfset DateSelect="#Dateformat(dateadd('D',m,Dim),"DD/MM/YYYY")#">  --->
                     <cfset DateSelect=#createODBCDate(DateSelect)#>
                     <cfset an="#Year(DateSelect)#"><cfset mois="#Month(DateSelect)#"><cfset jour="#Day(DateSelect)#">
                     an : #an# - mois : #mois# - jour : #jour#
                     <cfset dateSelect = #createDate(an,mois,jour)#>
                     dateselect : #dateselect# --->
                     </CFOUTPUT>
                      SELECT
                       AgendaObjet
                      FROM Agenda
                      WHERE
                       AgendaDateDeb=#DateSelect#"
                      AND sitename='#Session.site#'
                     </CFQUERY>
                     <!--- <CFOUTPUT>MajAgenda2.recordcount :# MajAgenda2.recordcount# - DateSelect : #DateSelect#</CFOUTPUT> --->
                     </CFOUTPUT>
              I think it comes from dates in French!
              • 4. Re: select date
                haxtbh Level 4
                Its more likely the rogue " you have in the query.
                #DateSelect#"
                Remove the quote marks at the end of this.
                • 5. Re: select date
                  EddieLotter Level 4
                       <CFOUTPUT>
                         </CFOUTPUT>
                          SELECT
                           AgendaObjet
                          FROM Agenda
                          WHERE
                         </CFQUERY>
                         </CFOUTPUT>
                  Replace the entire block of code that you show above with the code shown below
                  <cfset DateSelect = createDate(2017,6,17)>
                    SELECT
                      AgendaObjet
                    FROM Agenda
                    WHERE
                      AgendaDateDeb = <cfqueryparam value="#DateSelect#" CFSQLType="CF_SQL_DATE">
                      AND sitename = '#Session.site#'
                  </CFQUERY>
                  <cfset AgendaObjet = MajAgenda2.AgendaObjet>
                  Cheers
                  Eddie
                  • 6. Re: select date
                    Dave Ferguson Level 3
                    Also, just an FYI.  If you are not outputting or quoting the code you don't need to put "#" signs around it.  For example...
                    can be
                    <cfset DateSelect = createODBCDate(DateSelect)>
                    can be
                    <cfset an= Year(DateSelect) ><cfset mois= Month(DateSelect) ><cfset jour= Day(DateSelect) >
                    • 7. Re: select date
                      ZNB Level 1
                      Thank you for all your advice.
                      For dates, it works!
                      On the other hand, I have problems now with the hours:
                        Selection date: 10:00:00
                      Date display: 1899-12-30 10: 00: 00.0.
                      Despite a TimeDate: <cfset CalendarHeureDeb = "# Timeformat (AgendaHeureDeb, 'HH: MM') #">, nothing changes!
                      Thank you for you precious help.
                      • 8. Re: select date
                        EddieLotter Level 4
                        What do you mean "nothing changes"?
                        Please post the code where you expect to see a change.
                        Cheers
                        Eddie
                        • 9. Re: select date
                          ZNB Level 1
                          my code :
                                 AgendaHeureDeb : #AgendaHeureDeb# (1899-12-30 10: 00: 00.0)
                                 <cfset AgendaHeureDeb="#Timeformat(AgendaHeureDeb,'HH:MM')#">
                          </CFOUTPUT>
                          Tank you
                          • 10. Re: select date
                            EddieLotter Level 4
                            You're overwriting your date value with a string value. Did you intend to do that?
                            Try the following as an alternative:
                              <cfset AgendaHeureDebFormatted = Timeformat(AgendaHeureDeb,'HH:MM')>
                              AgendaHeureDebFormatted : #AgendaHeureDebFormatted#
                            </CFOUTPUT>
                            Cheers
                            Eddie
                            • 11. Re: select date
                              EddieLotter Level 4
                              Furthermore, check the documentation on allowable masks for the TimeFormat() function. If you want minutes, use "nn" not "MM" as the mask.
                              Cheers
                              Eddie
                              • 12. Re: select date
                                ZNB Level 1
                                Still no change!
                                In Access, time = 10:00
                                <Cfset CalendarHeureDeb = "# Timeformat (AgendaHeureDeb, 'HH: nn') #">
                                Result: 1899-12-30 10: 00: 00.0
                                I do not understand !
                                • 13. Re: select date
                                  EddieLotter Level 4
                                  Please show your test code as it is now. It looks like you are still using # symbols where you should not be.
                                  Cheers
                                  Eddie
                                  • 14. Re: select date
                                    ZNB Level 1
                                    No changes!
                                    My code:
                                            SELECT
                                             AgendaObjet,
                                             AgendaHeureDeb
                                            FROM Agenda
                                            WHERE
                                            GROUP BY AgendaHeureDeb,AgendaObjet
                                           </CFQUERY>
                                           AgendaHeureDeb1 : #AgendaHeureDeb# - HeureSelect : #HeureSelect#
                                           <cfset AgendaHeureDeb="Timeformat(AgendaHeureDeb,'HH:nn')">
                                           <A href="Agenda_Maj.cfm?Mode=creation&DateSelect=#Dateformat(dateadd('D',m,Dim),"DD/MM/YY")# &HeureSelect=#HeureSelect#"> </A>
                                          <CFIF MajAgenda2.recordcount EQ "0" AND HeureSelect EQ "AgendaHeureDeb">
                                    • 15. Re: select date
                                      You must represent dates as datetime objects, not as strings. To repeat,
                                      <cfset AgendaHeureDeb = parseDateTime(AgendaHeureDeb)> <!--- To ensure datetime object --->
                                      <cfset CalendarHeureDeb = timeformat(AgendaHeureDeb,'HH:nn')>
                                      • 16. Re: select date
                                        ZNB Level 1
                                                SELECT
                                                 AgendaObjet,
                                                 AgendaHeureDeb
                                                FROM Agenda
                                                WHERE
                                        </CFQUERY>
                                               <!--- <CFOUTPUT>MajAgenda2.recordcount :# MajAgenda2.recordcount# </CFOUTPUT> --->
                                                <cfset heuredeb="#Hour(AgendaHeureDeb)#"><cfset mindeb="#Minute(AgendaHeureDeb)#">
                                                heuredeb : #heuredeb# - mindeb : #NumberFormat(mindeb,'00')#
                                                <cfset AgendaHeureDeb=#heuredeb#&":"&#mindeb#>
                                                <cfset AgendaHeureDeb = timeformat(AgendaHeureDeb,'HH:nn')>
                                        Result :
                                             HeureSelect : 10:00
                                             heuredeb : 10 - mindeb : 00
                                             AgendaHeureDeb : 1899-12-30 10:00:00.0
                                        • 17. Re: select date
                                          ZNB Level 1
                                          Why was my application accepted and rejected?
                                          THANK YOU
                                          • 18. Re: select date
                                            Strange. In your code it appears that ColdFusion fails to see the timeformat function. What happens when you replace the 3 lines with the ones I gave:
                                            CalendarHeureDeb : #CalendarHeureDeb #
                                            • 19. Re: select date
                                              ZNB Level 1
                                              Indeed, the "timeformat" function does not seem to work!
                                              By replacing "agenda" with "calendar", I have an improvement
                                              : I have the time but not the minutes.
                                              Here's the code:
                                              AgendaHeureDeb : #CalendarHeureDeb#
                                              Tank you !
                                              • 20. Re: select date
                                                Sorry to hear that. You might have a bug, but it's too early to say.
                                                Now time for a workaround. Why don't you try this:
                                                <cfset simpleDateFormat = createobject("java", "java.text.SimpleDateFormat").init("HH:MM")>
                                                <cfset AgendaHeureDeb = simpleDateFormat.format(AgendaHeureDeb)>
                                                • 21. Re: select date
                                                  ZNB Level 1
                                                  hello
                                                  result :
                                                  HeureSelect : 10:30 heuredeb : 10 - mindeb : 00 AgendaHeureDeb : 1899-12-30 10:00:00.0
                                                  If it's an Adobe problem, like I have a hosted account, what should I ask the host?
                                                  Tank you
                                                  • 22. Re: select date
                                                    Sorry, there was an error in post. Please read
                                                    <cfset simpleDateFormat = createobject("java", "java.text.SimpleDateFormat").init("hh:mm")>
                                                    If you still fail to get 10:00 you should contact the host.
                                                    • 23. Re: select date
                                                      ZNB Level 1
                                                      Résult :
                                                      HeureSelect : 10:00 heuredeb : 10 - mindeb : 00 AgendaHeureDeb : 1899-12-30 10:00:00.0
                                                               http://www.zennetbuilder.com/admin/Agenda_Maj.cfm?Mode=creation&DateSelect=20/06/17&HeureS elect=10:00
                                                      always the same problem !
                                                      I contact my web host
                                                      Thanks to all
