0 Replies Latest reply on Jun 12, 2017 2:58 AM by jahed ali
    Changing the properties of EAN13 barcode like bar width and text position.
    jahed ali Level 1
      Dear All,
         My requirement is to change default properties of EAN13 barcode  generated by Adobe Livecycle designer.I want to minimize the width of wide bar of EAN13 barcode and to change the embedded text position  . To achieve this i approached multiple options as explained below  but nothing worked for me .
      I worked with files like Designer.xdc , EAN13.xfo and changed the barcode properties like wideNarrowRatio & textLocation but these changes has no influence on the barcode appearance.
      I had highlighted the differences between the Adobe Livecycle generated EAN13 barcode and the online generated barcode for better understanding and to explain the changes that i am trying to achieve.
      ALD Generated EAN 13 Barcode
         Here you can notice that the width of wide bar is more when compared to online generated barcode and the Text is embedded meaning the alignment of text is enclosed with in the height of narrow barcode but where as in online generated barcode the text alignment is below the barcode.
      I am trying to achieve these differences in ALD generated barcode .
      Online Generated Barcode
