• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
4K No compression video
New Here ,
Jun 12, 2017 Jun 12, 2017
Hello
I have a few  3840x2160 images and I want to make a 4k video but I need it to be pixel detailed. I mean is for quality testing in Tv's so the video(in the TV) is examined with a microscope to check the pixels going on and off. All my images are pixel detailed but the final product somehow gets data loss and end with a blurry thing (at pixel lvls).
Any idea?
Yea and srry for bad english
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 14, 2017 Jun 14, 2017
Heya Dex:
Either of the following two options will give you great image quality:
A. Add your Comp to the Adobe Media Encoder Queue.  Then, set the format to HEVC (H265) and the preset to Match Source - High Bitrate.
B. Add your Comp to the Render Queue.  Then, set the Render Settings to "Best Settings" and the Output Module to "Lossless".  Heads up:  You're looking at 32MB per frame (a lot more if you're working at higher than 8 bits per channel).
Another consideration is how you're going about play
Votes
Translate
Translate
Community Expert ,
What video file format are you currently exporting to?  And, at what settings?
Votes
Translate
Translate
Report
Report
New Here ,
Using premiere CC
my output 3840x2160, with square pixels, lvl 5.0 with main profile and main tier
The sequence is a 3840x2160 (1.0) same as output, but some one it drops the quality when rendering
Votes
Translate
Translate
Report
Report
LEGEND ,
Jun 13, 2017 Jun 13, 2017
Can we please see a screenshot of your render and output settings?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jul 24, 2017 Jul 24, 2017
Hi Dexfever,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
Votes
Translate
Translate
Report
Report
New Here ,
Nov 20, 2017 Nov 20, 2017
Tnx Warren! The issue solved with the h265 format. Also seems that one of the TV sources needed an aditional configuration line in the OS supporting them. Now the video displays as needed.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Good news!
Could I trouble you to make my post as correct?
Votes
Translate
Translate
Report
Report
Community Expert ,
Heya Dex:
Another consideration is how you're going about playing your rendered movies to your TV.  If your TV support playing H265, you're all set.  You're also probably good if you're playing H265 files to your TV via HMDI from your laptop.  If your hardware requires something else, you'll have to consider working with whatever it supports.
-Warren
Votes
Translate
Translate
Report
Report
