Has anyone seen/made a script that will remove the duplicate swatches in InDesign? I found one that will get rid of “copies” but not that will remove the ones with the auto-numbered filenames (ex. Color, Color 1, Color 2 etc.). Basically I need a script that can clean up a file after people are done working with pulling from a variety of sources.
These are the final swatches I want left in the folder and how they are named in our files:
Primary_Red RGB (186)
Primary_Gray RGB (425)
Primary_Blue RGB (7459)
These are the duplicates we often end up with in the file:
Primary_Red RGB (186) 2
Primary_Gray RGB (425) 2
Primary_Blue RGB (7459) 2
Primary_Red RGB (186) 3
Primary_Gray RGB (425) 3
Primary_Blue RGB (7459) 3
Any assistance would be amazing!
Thank you
That doesn't sound too daunting. Either you go by the names, and remove all that have a Same Name + space + a digit, or, if you don't trust this to be correct, literally compare the RGB or CMYK values of each entry to every other entry (where you then could perhaps delete the one with the longest name).
But how do you do this as a script? We have 21 colors in our palette and 21 times sometimes 3 duplicates is a bit much to do manually. Especially for users that are not too good in InDesign.
