I've got an image on my AIR app where the user have to draw a line with his finger on it. The purpose is to draw the line somewhere quite precise.
So, to draw a line, here's what I did :
var drawingLine:MovieClip = new MovieClip();
addChildAt(drawingLine,0);stage.addEventListener(MouseEvent.MOUSE_DOWN, MouseDown);
stage.addEventListener(MouseEvent.MOUSE_UP, MouseUp);function MouseDown(event:MouseEvent):void{
drawingLine.graphics.lineStyle(3);
drawingLine.graphics.moveTo(mouseX, mouseY);
stage.addEventListener(MouseEvent.MOUSE_MOVE, MouseMove);
}function MouseMove(event:MouseEvent):void{
drawingLine.graphics.lineTo(mouseX, mouseY);
}function MouseUp(event:MouseEvent):void{
stage.removeEventListener(MouseEvent.MOUSE_MOVE, MouseMove);
So, now, how can I determine an area and check if the user has draw his lines in the area ? The line should be inside the area completely. If possible, of course.
I thought about using hitTestObject
but I don't think that's the good way to do it.
Read about getPixel() here:
BitmapData - Adobe ActionScript® 3 (AS3 ) API Reference
With that you would have a bitmapData copy (to make it simple have it be the size of the stage) of the maze, or whatever it is you're showing the user, and you could check the stage mouse location against the bitmapData. So, as the user moves around the stage you will know the color of the pixel under than location in the off-screen bitmapData image.
You will know in real time if they have stayed within the lines.
