17 Replies Latest reply on Jun 13, 2017 6:50 AM by Mikie9
    Issue with missing font code
    mikeb41294032 Level 1
      Can someone please help with the code below??
      I am using this code to detect missing fonts as part of a script that exports pdfs.
      The issue is but not on every document it will error thinking there is a missing font, but when I go under the Type/Find Font/Fonts in document all is good.
      I can even do a direct pdf export out of InDesign without any issues and the fonts are fine in the pdf.
      I am not a scripter so can someone please look and see if there's a bug in this code?? also what would it take to check within the document bounds and not look at any text frames on the pasteboard?
      Maybe there is a better option for checking for missing fonts than what I am using.
      Thanks in advance!
      var usedFonts = app.activeDocument.fonts;
      var missingItem = '\n'
      for(var i = 0; i < usedFonts.length; i++){
          if(usedFonts[i].status != FontStatus.INSTALLED){
              missingItem += '\n' + usedFonts[i].fontFamily;
         alert('Document Contains Missing Fonts Job Aborted!')
                       exit();
