3 Replies Latest reply on Dec 18, 2008 3:59 PM by John Hall
    formatting my data
    Hulfy Level 1
      I want to query my cf table and output it without putting it in a datasource. In a CFM page I would use the code attached. Is there a way to use this code and output the contents to a textarea or "coldfusion" area?
      H.
        • 1. Re: formatting my data
          rtalton Level 4
          Is there a CF forum you can post this question in?
          • 2. Re: formatting my data
            Level 7
            "Hulfy" <webforumsuser@macromedia.com> wrote in message
            news:gief7v$5k0$1@forums.macromedia.com...
            > Hi,
            > datasource.
            > code
            You need to make sure it is outputting valid XHTML, then you can use e4x to
            access the output.
            • 3. Re: formatting my data
              John Hall Level 4
              If you need to query a server DB, you'll have to have something to talk to the DB and coldfusion is a good alternative. If you want to do it on the desktop, you can do AIR with its embedded SQLite DB.
