0 Replies Latest reply on Jun 12, 2017 7:35 PM by Felaray
    Windows build failed,but ios and android is success.
    Felaray
      My appid: 2656003, I have issue on windows build. this is my log.
      Expected Behaviour
      Remote build success
      Actual Behaviour
      Remote build failed
      Steps to Reproduce
      1. new project
      2. cordova plugin add phonegap-plugin-push
      3. cordova platform add android
      4. phonegap remote build android
      Platform and Version (eg. Android 5.0 or iOS 9.2.1)
      windows
      Cordova CLI version and cordova platform version
      cordova --version                                    -7.0.1 cordova platform version                        -windows 5.0.0
      Plugin version
      phonegap-plugin-push@1.10.4
      Logs taken while reproducing problem
      Error - Plugin error (you probably need to remove plugin files from your app): Fetching plugin "phonegap-plugin-push@1.10.4" via npm Installing "phonegap-plugin-push" at "1.10.4" for windows Updating appxmanifests with ToastCapable=true... Failed to install 'phonegap-plugin-push':Error: Cannot find module 'C:\cygwin\tmp\gimlet\2656003\project\platforms\windows\cordova\lib\AppxManifest' at Function.Module._resolveFilename (module.js:337:15) at Function.Module._load (module.js:287:25) at Module.require (module.js:366:17) at require (module.js:385:17) at module.exports (C:\cygwin\tmp\gimlet\2656003\project\cordova\plugins\phonegap-plugin-push\hooks\windows\ setToastCapable.js:5:24) at runScriptViaModuleLoader (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cor dova-lib\src\hooks\HooksRunner.js:187:18) at runScript (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cor dova-lib\src\hooks\HooksRunner.js:165:16) at C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cord ova-lib\src\hooks\HooksRunner.js:133:20 at _fulfilled (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\q\q.js: 787:54) at self.promiseDispatch.done (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\q\q.js: 816:30) Cannot find module 'C:\cygwin\tmp\gimlet\2656003\project\platforms\windows\cordova\lib\AppxManifest' - You can fix this here
