7 Replies Latest reply on Jun 28, 2017 1:56 PM by ItoolsMobile
    Android Build Failed with: not accepted the license agreements of the following SDK components
    ItoolsMobile Level 1
      My Android build started failed to build.  Here are the errors being returned in the log:
      Build Date: 2017-06-13 02:42:40 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an in !cubating feature.
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > You have not accepted the license agreements of the following SDK components:
        [SDK Patch Applier v4, Google Repository].
        Before building your project, you need to accept the license agreements and complete the installation of the missing components using the Android Studio SDK Manager.
        Alternatively, to learn how to transfer the license agreements from one workstation to another, go to http://d.android.com/r/studio-ui/export-licenses.html
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.095 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      This seems to be an issue on the build server side.  Any ideas how I can get this building again? My app id is: com.squashthebeef.app1
