2 Replies Latest reply on Jun 13, 2017 5:30 PM by ozzytheartist
    Scrip for saving as (jpeg or png) and incremental sequence name
    ozzytheartist
      Scenario:
      I'm trying to make a time lapse video.
      I have a finished (only one file, so no batching) drawing/painting file with many layers. I made all the layers invisible. Then, I started at my background layers and enabled the visibility of a particular layer, changed the opacity of that one layer to, lets say 25%, and saved the image as a jpeg file named "1" (however, png would be better now that I think about it). Then, I went back to the same layer, changed the opacity to 50% and saved a jpeg file as "2"........ I made it to 250 images and I cannot afford to keep going this way.
      Is there a script that could save the images and add a sequential name as in the example, after I have manually modified the opacity of the layer?
      I found this unique name command but is either not doing it or is saving the images in some random place.
      function CreateUniqueFileName( inFolder, inFileName, inExtension ) {
        inFileName = inFileName.replace(/[:\/\\*\?\"\<\>\|]/g, "_");  // '/\:*?"<>|' -> '_'
        var uniqueFileName = inFolder + inFileName + inExtension;
        var fileNumber = 1;
        while ( File( uniqueFileName ).exists ) {
        uniqueFileName = inFolder + inFileName + "_" + fileNumber + inExtension;
        fileNumber++;
        return uniqueFileName;
      I also found this code, which works but the image gets overwritten every time.
      var doc = app.activeDocument;
      var Path = doc.path;
      var Name = doc.name.replace(/\.[^\.]+$/, '');
      var Suffix = "-Copy";
      var saveFile = File(Path + "/" + Name + Suffix + ".jpg");
      SaveJPEG(saveFile, 8);
      function SaveJPEG(saveFile, jpegQuality){
      jpgSaveOptions = new JPEGSaveOptions();
      jpgSaveOptions.embedColorProfile = true;
      jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
      jpgSaveOptions.matte = MatteType.NONE;
      jpgSaveOptions.quality = jpegQuality;
      activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
      I wish there was something easy like (see red words):
      var Suffix = "i";
      var i=1;
      var saveFile = File(Path + "/" + Name + (Suffix+1) + ".jpg");
      I would appreciate any help. Saving: choosing the quality and renaming is taking too long. I like having the control over the opacity but I want to make the saving process faster and only focus on the opacity/transitions.
      Thanks!
