2 Replies Latest reply on Jun 14, 2017 6:38 AM by A. Patterson
    Scriptable plugin in Illustrator
    alam_84 Level 1
      Hi All,
      I am a regular plugin developer for InDesign and now I just started plugin development for Illustrator
      As in InDesign we have a concept of making plugin scriptable means plugin can expose some method/property to an existing DOM object so that we can access that method in scripting DOM.
      e.g I have added a method HelloWorld in the document object in C++ native plugin and in jsx script we can access that method as follows
      app.activeDocument.HelloWorld() // exposed method in C++ plugin is accessible in scripting DOM
      Does we have same scriptable plugin feature in Illustrator? means adding a method in C++ plugin, expose it and make it accessible in scripting DOM.?
      Regards,
      Alam
        • 1. Re: Scriptable plugin in Illustrator
          LeoTaro Level 4
          I don't this functionality is available in Illustrator plugins.
          • 2. Re: Scriptable plugin in Illustrator
            A. Patterson Level 4
            Actually, you can add scripting to an AI plugin, but it's limited. You can expose scripting support but it requires the script to perform a LoadLibrary() call on your plugin before your scripting is available. I've only just begun to play around with this myself but it seems promising (it'd be nicer if our scripting could just be there when our plugin was loaded, but you take what you can get).
            I think this is what you want:
            http://www.adobe.com/devnet/scripting/estk.html
            If you run the installer inside, I believe you'll end up with an SDK folder somewhere. Look for:
            SoCClient.h
            SoSharedLibDefs.h
            Those are the headers you need. You'll have to piece together how to do it from the sketchy documentation, but it's not as bad as that sounds.
