2 Replies Latest reply on Jun 14, 2017 2:28 AM by steu40
    Delete a set of tags - Indesign
    steu40
      Hi everybody.
      I need some help with the code below. Unfortunately, I have no experience with the Java language, but I guess that (for my needs) it should be easy to get to a solution.
      The code below helps me to automate a compilation of an instruction manual automatically deleting tags (in Indesign).
      In particular, I create a database document with all the parts of the manual, each tagged with a particular XML tag.
      Now, the process that I want to automate is:
      1. Declare a set of tags to be deleted (in the code below tag01, tag02, and tag03);
      2. Delete the contents marked with the above tags;
      3. Delete empty frames.
      I found the code below that should do these operations, but it deletes only a part (I dont know why!) of the contents marked with tag to be deleted. Anyone can help me?
      Further, does anybody know a code that allows me to declare a set of tags in an external file, as an example a txt file or js file, and then take these tags in the script in object (operation n°1)?
      P.S. The operation n°3 work correctly.
      In this figure is shown a part of the xml schema of the document in object.
      Thank you for your time.
      var myDocument= app.activeDocument;
      //  1.  Declare a set of tags to be deleted
      var tag_da_eliminare = new Array();
      tag_da_eliminare[0] = "tag01";
      tag_da_eliminare[1] = "tag02";
      tag_da_eliminare[2] = "tag03";
      //  2.  Delete the contents marked with the above tags
      for (var j=0; j<tag_da_eliminare.length; j++) {
          var tag_incriminato = tag_da_eliminare[j];
          alert(tag_incriminato)
          FindEmail(myDocument);
      //  3.  Delete empty frames (WORK CORRECTLY)
      var myStories = app.activeDocument.stories.everyItem().getElements();
      for (i = myStories.length - 1; i >= 0; i--){
          var myTextFrames = myStories[i].textContainers;
          for (j = myTextFrames.length - 1; j >= 0; j--)    {
              if (myTextFrames[j].contents == ""){
                  myTextFrames[j].remove();
      alert("process Completed");
      // FUNCTIONS
      function FindEmail(elm)
      for (var i=0; i<elm.xmlElements.length; i++)
             XMLelementName=elm.xmlElements[i].markupTag.name.toString();
             if(XMLelementName==tag_incriminato)
                  //elm.xmlElements[i].markupTag = "mail";
                 elm.xmlElements[i].remove();
                 //alert(i);
            FindEmail(elm.xmlElements[i]);
        • 1. Re: Delete a set of tags - Indesign
          Loic Aigon Level 2
          Try this:
          //Our main function
          var main = function() {
          var doc = app.properties.activeDocument, xTags, tagNames;
          //Exit if no open documents
          if ( !doc ) return;
          xTags = doc.xmlTags;
          //Exit if there is only one tag, meaning no contents has been added to the root
          if ( xTags.length==1 ) {
          alert("Only one xml tag found. Add an d apply more tags then start again…" );
          return;
          //Getting tag names while excluding teh root name
          //because you don't want and can't remove the root xml element.
          tagNames = xTags.everyItem().name;
          tagNames = tagNames.join("#").replace ( "#"+doc.xmlElements[-1].markupTag.name, "" ).split("#" );
          //Displaying window so user can pick 1 to n tags to remove
          var w = getWindow(tagNames);
          //Exit if user cancelled dialog
          if ( w.show()==0 ) return;
          //Calling cleaning routine
          cleanDoc ( doc, w.tags );
          //Cleaning routine
          var cleanDoc = function ( doc, tagNames ) {
          var n = tagNames.length, root = doc.xmlElements[0];
          //Looping through tag names to remove them.
          //Be aware there are actually scriptUI list items
          //So we need to look at the text property
          while ( n-- ) {
          removeXMLElements ( root, tagNames[n].text );
          //Cleaning empty text frames
          removeEmptyTextFrames ( doc );
          //removing Empty TextFrames routine
          var removeEmptyTextFrames = function( doc ) {
          var fgp = app.findGrepPreferences.properties,
          cgp = app.changeGrepPreferences.properties,
          found = [], n = 0;
          app.findGrepPreferences = app.changeGrepPreferences = null;
          //getting empty frames thanks to GREP
          app.findGrepPreferences.findWhat = "\\A\\Z";
          found = doc.findGrep();
          n = found.length;
          //removing found items
          while ( n-- ) {
          found[n].parentTextFrames[0].remove();
          app.changeGrepPreferences.properties = cgp;
          //Removing specific XMLEelemnts given supplied tag name
          var removeXMLElements = function (root,  tagName ) {
          //getting compliant items
          var xes = root.evaluateXPathExpression ( ".//"+tagName ),
          n = xes.length;
          //Looing through results and remove them
          while ( n-- ) {
          xes[n].remove();
          //Window factory function
          var getWindow = function(tags) {
          var w = new Window("dialog", "XMLCleaner"),
          u,
          ls = w.add('listbox',u,tags,{multiselect:true}),
          btnGp = w.add('group'),
          koBtn = btnGp.add('button',u,'Cancel'),
          okBtn = btnGp.add('button',u,'Apply');
          w.preferredSize.width = 200;
          w.alignChildren = ["fill","top"];
          okBtn.enabled = false;
          koBtn.onClick = function(){ w.close(0) };
          okBtn.onClick = function(){
          w.tags = ls.selection;
          w.close(1);
          ls.onChange = function() {
          okBtn.enabled = ls.selection!==null;
          return w;
          var u;
          //Calling our script
          app.doScript ( "main()",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
          • 2. Re: Delete a set of tags - Indesign
            steu40 Level 1
            Thank you for your time. The code works perfectly.
            Unfortunately I have a lot of tag to delete, so for me it would be more convenient define the tags in a external txt (o js/jsx) file.
            In this case, I could manage the txt file by an Excel file (Is the easiest way for me and my colleagues to manage the content of the manual).
            Is possible to replace the part of code witch get tag name by window?
            Thanks a lot.
