• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Command line generation
Explorer ,
Jun 13, 2017 Jun 13, 2017
We are using RoboHelp 2015. We need to generate our online help as WebHelp from a command line automatically as part of the product build process. The requirement is to enable automatic generation of the help whenever the software is built. I found the following article with instructions on Peter Grainge's site. I would like to know if this will work as described or if anything in that article has changed or if there are other things I'd need to do to make command-line generation work. Also, I'd like to know what information to provide to our Build and Release team. Please advise!
Thank you,
Kathe
Command Line Generation
Views
393
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
If you do not get a response here, there's a link to the author in the article.
Votes
Translate
Translate
Report
Report
Contributor ,
As recently as 2016, I used Peter's instructions to generate from the command line. Worked fine for me.
Paul Hanson
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 30, 2017 Jun 30, 2017
Just to close this out, we were able to build RH from the command line. It took a bit of doing before we got it right. For example, I don't think the instructions made it clear that you need to run the command from the same directory where RH resides. Maybe that's intuitive for others, but it didn't occur to me until I got a command line error and figured it out. In any case, it works and we plan to get a copy of RH for our engineering Build & Release team so they can use the command line to build Help as part of each interim product build. Very useful to our QA team, as they always want to see the full help output whenever Doc updates/adds/removes a topic.
Thanks!
Kathe
Votes
Translate
Translate
Report
Report
Contributor ,
You do realize that when your engineering Build & Release team uses their copy of RH, they will need to have direct access to your RH projects. Your solution would not work for me as I store all of my projects locally on my c:\ drive on my laptop which I typically shut down at night. Did you consider the option of kicking off a compile to whatever directory your engineering Build & Release team uses before you leave at night?
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 07, 2017 Jul 07, 2017
LATEST
Thanks, PRHmusic2. I'll look into this.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
