1 Reply Latest reply on Jun 13, 2017 9:33 PM by Dirk Becker
    Saving an XML file with AppleScript
    mBornbach
      I'm working on automating our page layout process. I've created a script that gathers information from an Excel file and pastes that information in XML format into Text Edit. My question is how do I get TextEdit (or another program) to save an XML file that can be imported into InDesign? Right now, I have to copy and paste the xml information from my created xml file to Adobe's sample xml file from the page automation demo. Then, I can save that file with a new name. Otherwise, it won't import into InDesign. Clearly, I'm doing something wrong with the saving options. Any suggestions would be appreciated. Here's the code if it helps:
      --Global variables
      global xml_list
      --PROMPTING THE USER TO SELECT THE FOLDER IN WHICH TO SAVE THE WORD FILES
      with timeout of 3000 seconds
        --Prompting the user to select the promotion's Excel file
        tell application "Finder" to set my_file to choose file with prompt "Choose the Promo's Excel File"
        set excel_report to POSIX path of my_file
        --SPECIFYING WHICH EXCEL COLUMNS TO WORK WITH
        set blain_number_column to "A"
        set image_name_column to "B"
        set image_path_column to "D"
        set blain_to_pic_number_column to "F"
        set image_to_pic_name_column to "G"
        set image_to_pic_path_column to "H"
        set page_number_column to "J"
        set vendor_column to "K"
        set description_column to "L"
        set LL_column to "M"
        set notes_column to "N"
        set reg_price_column to "O"
        set sale_price_column to "P"
        set possible_page_number_list to {"1.0", "2.0", "3.0", "4.0", "5.0", "6.0", "7.0", "8.0", "9.0", "10.0", "11.0", "12.0", "13.0", "14.0", "15.0", "16.0", "17.0", "18.0", "19.0", "20.0", "21.0", "22.0", "23.0", "24.0"}
        --CREATING EMPTY LISTS TO BE USED LATER IN DETERMINING IF
        --A FILE IS OPEN OR IF THERE IS A PROBLEM
        set problem_list to {}
        set number_list to {}
        --ADDING XML INFO TO A LIST
        tell application "Microsoft Excel"
        activate
        open excel_report
        repeat with i from 1 to count of possible_page_number_list
        set test_page_number to item i of possible_page_number_list
        my add_to_page_list(test_page_number, blain_number_column, image_path_column, image_to_pic_path_column, vendor_column, description_column, reg_price_column, sale_price_column, notes_column, page_number_column, LL_column) -->Calling the add_to_page_list function
        log xml_list
        --ADDING ALL NECESSARY INFO FROM THE LIST TO EACH XML FILE
        --Checking if the list for that page # is blank and only creating the XML file if it contains information
        if xml_list is not ("<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>" & linefeed & "<Root>" & linefeed & "</Root>") as string then
        --Opening Text Edit and Creating the XML File
        tell application "TextEdit"
        activate
        set new_document to make new document
        set text of new_document to xml_list
        --save document 1 in "/Volumes/NAS/Advertising Department/16_SCRIPTS/z_Future Scripts/Print Ad Layout/XML scripted/XML 4/XML_Testing.xml"
        end tell
        end if
        end repeat
        end tell
      end timeout
      --FUNCTIONS
      --FUNCTION TO ADD XML INFO FOR EACH PAGE TO A LIST
      on add_to_page_list(the_number, column1, column2, column3, column4, column5, column6, column7, column8, column9, column10)
        --Adding standard xml code to the top of the xml file
        set xml_list to "<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>" & linefeed & linefeed & "<Root>" & linefeed as string
        --Determining how many rows the Excel file has
        tell active sheet
        set image_count to 1
        set the_start_row to 2
        repeat with i from 1 to count of rows of used range
        set current_row to i
        --Determining the last used row number
        set row_count to count of rows of used range
        --Determining the last column
        select none
        set row_to_test to range "1:1"
        set cell_count to count cells of row_to_test
        set last_cell to get address of (get end cell cell_count of row_to_test direction toward the left)
        set first_cell to get address of (get end cell cell_count of row_to_test direction toward the right)
        if item 1 of last_cell is "$" and item 3 of last_cell is "$" then
        set last_column to item 2 of last_cell
        else if item 1 of last_cell is "$" and item 3 of last_cell is not "$" and item 4 of last_cell is "$" then
        set last_column to items 2 thru 3 of last_cell
        else if item 1 of last_cell is "$" and item 3 of last_cell is not "$" and item 4 of last_cell is not "$" and item 5 of last_cell is "$" then
        set last_column to items 2 thru 4 of last_cell
        else if item 1 of last_cell is "$" and item 3 of last_cell is not "$" and item 4 of last_cell is not "$" and item 5 of last_cell is not "$" and item 6 of last_cell is "$" then
        set last_column to items 2 thru 5 of last_cell
        end if
        --Setting the cell address for each info field
        set blain_number_cell to column1 & current_row as string
        set image_path_cell to column2 & current_row as string
        set image_to_pic_path_cell to column3 & current_row as string
        set vendor_cell to column4 & current_row as string
        set description_cell to column5 & current_row as string
        set reg_price_cell to column6 & current_row as string
        set sale_price_cell to column7 & current_row as string
        set notes_cell to column8 & current_row as string
        set page_cell to column9 & current_row as string
        set previous_page_cell to column9 & (current_row - 1) as string
        set current_LL_cell to column10 & current_row as string
        set test_LL_cell to column10 & (current_row + 1) as string
        set current_LL to value of cell current_LL_cell
        --Setting the cell address for the next info field in case it is a Lower Level (LL)
        set LL_row_list to {}
        set test_LL to value of cell test_LL_cell
        if test_LL contains "LL" then
        repeat
        set next_row to (current_row + 1)
        set LL_row_list to LL_row_list & next_row
        set test_LL_cell to "L" & next_row as string
        set next_test_LL_cell to "L" & (next_row + 1)
        if the value of cell next_test_LL_cell does not contain "LL" then
        exit repeat
        else
        set current_row to (current_row + 1)
        end if
        end repeat
        end if
        --Getting the values from every cell address
        if current_row is greater than or equal to the_start_row then
        set page_number to value of cell page_cell
        if (page_number as string) does not contain "0.0" then
        set the_vendor to value of cell vendor_cell as string
        set the_description to value of cell description_cell as string
        set reg_price to value of cell reg_price_cell as string
        set sale_price to value of cell sale_price_cell as string
        set the_notes to value of cell notes_cell as string
        set orig_blain_number to value of cell blain_number_cell as string
        set blain_number to my number_to_string(orig_blain_number)
        --REMOVING ILLEGAL XML CHARACTERS IN THE DESCRIPTION & FIXING THE IMAGE PATH
        --Changing illegal # characters in the description to ones xml can understand
        (*if the_description contains "#" then
        set search_character to "#"
        set replacement_character to "&#35;"
        repeat 5 times
        set the_description to my replace_characters(the_description, search_character, replacement_character) -->See replace_characters function at the bottom
        if the_description does not contain "# " then exit repeat
        end repeat
        end if*)
        --Changing illegal & characters in the description to ones xml can understand
        if the_description contains "&" then
        set search_character to "&"
        set replacement_character to "&amp;"
        repeat 5 times
        if the_description does not contain "& " then exit repeat
        end repeat
        end if
        --Changing image path so it doesn't have double // after the 1_4c_IMAGES folder (the // breaks the xml image import)
        set image_path to value of cell image_path_cell
        if image_path contains "1_4c_IMAGES//" then
        set search_character to "1_4c_IMAGES//"
        set replacement_character to "1_4c_IMAGES/"
        end if
        if the_notes contains "DESIGNER NOTE: " then
        set tid to AppleScript's text item delimiters
        set AppleScript's text item delimiters to "DESIGNER NOTE: "
        set my_notes to last text item of the_notes
        set AppleScript's text item delimiters to tid
        else if the_notes is "" then
        set my_notes to ""
        else
        set my_notes to the_notes
        end if
        --ADDING ALL NECESSARY INFO TO THE CURRENT PAGE LIST
        --Getting the large sale price and the cents
        set AppleScript's text item delimiters to "."
        set large_sale_price to first text item of sale_price
        set sale_price_cents to last text item of sale_price
        --Adding all the text info to the list
        if (page_number as string) is the_number then
        set xml_list to xml_list & "<body><body_price><large_price>" & large_sale_price & "</large_price><small_price>" & sale_price_cents & "</small_price><kerning> </kerning><sale_wording>SALE</sale_wording>" & linefeed & "<heading>" & the_vendor & " " & the_description & "." & "</heading><blain_number>" & " " & blain_number & "</blain_number><reg_price> Reg. " & reg_price & "</reg_price></body_price>" & linefeed & "</body>" & linefeed as string
        if the_notes is not "" then set xml_list to xml_list & "<disclaimer> " & my_notes & "</disclaimer>" & linefeed as string
        --Adding the image info to the list
        set xml_list to xml_list & "<image" & image_count & "a href=\"file://" & image_path & "\"></image" & image_count & "a" & ">" & linefeed as string
        set image_count to (image_count + 1)
        set image_to_pic_path_orig to value of cell image_to_pic_path_cell as string
        if (image_to_pic_path_orig as string) is not "N/A" and (image_to_pic_path_orig as string) is not equal to image_path then
        if image_to_pic_path_orig contains ", " then
        set AppleScript's text item delimiters to ", "
        set image_to_pic_paths to every text item of image_to_pic_path_orig
        else
        set image_to_pic_paths to image_to_pic_path_orig
        end if
        if image_path is not "" then
        set image_count to "2"
        else
        set image_count to "1"
        end if
        repeat with image_to_pic_path in image_to_pic_paths
        set xml_list to xml_list & "<image" & image_count & " href=\"file://" & image_path & "\"></image" & image_count & ">" & linefeed as string
        set image_count to image_count + 1
        end repeat
        else
        set xml_list to xml_list & linefeed as string
        end if
        else
        end if
        end if
        end if
        end repeat
        set xml_list to xml_list & "</Root>"
        log xml_list
        end tell
        end tell
      end add_to_page_list
      --FUNCTION TO CHANGE EXCEL SCIENTIFIC NOTATION TO REAL NUMBERS
      on number_to_string(this_number)
        set this_number to this_number as string
        if this_number contains "E+" then
        set x to the offset of "." in this_number
        set y to the offset of "+" in this_number
        set z to the offset of "E" in this_number
        set the decimal_adjust to characters (y - (length of this_number)) thru ¬
        -1 of this_number as string as number
        if x is not 0 then
        set the first_part to characters 1 thru (x - 1) of this_number as string
        else
        set the first_part to ""
        end if
        set the second_part to characters (x + 1) thru (z - 1) of this_number as string
        set the converted_number to the first_part
        repeat with i from 1 to the decimal_adjust
        try
        set the converted_number to ¬
        the converted_number & character i of the second_part
        on error
        set the converted_number to the converted_number & "0"
        end try
        end repeat
        return the converted_number
        else
        return this_number
        end if
      end number_to_string
      --FUNCTION TO REPLACE CHARACTERS
      on replace_characters(the_phrase, search_string, replacement_string)
        --Changing illegal xml characters to ones xml can understand
        set AppleScript's text item delimiters to search_string
        --set item_count to count of text items of the_phrase
        set text_items to text items of the_phrase
        set AppleScript's text item delimiters to replacement_string
        set the_phrase to text_items as Unicode text
        log the_phrase
        return the_phrase
      end replace_characters
