3 Replies Latest reply on May 23, 2006 8:40 AM by Newsgroup_User
    Animation: settings window greyed out
    Level 7
      I used FW MX 2004
      I asked an Internet colleage to animate a filmstrip for me, straight
      vertical movement, and send me the png file. She sent a gif file which
      moved as required. I then requested the png file so that I could adjust
      the speed.
      When the png file came, I observed the following:
      1 The filmstrip was visible all right and moved as wanted in the
      Original display.
      2 The preview display showed only the empty canvas.
      3 The frames panel showed the sort of Frames I expected.
      However, when I click on Modify | Animations, all sub-options including
      Settings are greyed out.
      The png file can be seen at the following URL:
      http://www.tudo.co.uk/filmstrip/filmstrip_smooth.png
      Did I make a mistake in not selecting something prior to trying
      animation settings,
      or did the animator not send me the correct png file, lock it in some
      way, etc?
      btw is there a way of changing ALL the delay values in the Frames panel
      in one go?
      Thanks.
      Adrian
        • 1. Re: Animation: settings window greyed out
          Level 7
          > Original display.
          Those settings only work if you are animating a symbol. The film strip
          wasn't converted to a symbol.
          > in one go?
          Shift + select all the frames in the frames panel and double click on
          the delay setting for the last one.
          Linda Rathgeber [PVII] **Adobe Community Expert**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Animation: settings window greyed out
            Level 7
            >> Original display.
            >> including Settings are greyed out.
            >> panel in one go?
            Hi, Linda,
            Thanks, I had a hunch that 'symbol' was at issue. I created the
            filmstrip as is and have to pay a sum agreed in advance to the person
            who animated it.
            It was agreed that she would send png and gif file. Then she sent only
            a working gif animation. I demanded the png file (to enable me to
            adjust the speed) and received the file you have seen, i.e. filmstrip
            not made into a symbol.
            She must have converted it into a symbol before creating the gif file.
            Can I demand that she converts the filmstrip into a symbol or do I have
            to do this myself (however easy it presumably is).
            If I do the conversion into symbol myself there is virtually nothing she
            has done to earn her money.
            In brief: Can I demand that she sends me a png file where the filmstrip
            is a symbol?
            Thanks.
            Adrian
            • 3. Re: Animation: settings window greyed out
              Level 7
              > is a symbol?
              That's between you and your animator. I'm not going to step between you. :-)
