2 Replies Latest reply on Jun 14, 2017 7:37 AM by stefaniea57611104
    Poster Printing - Including marks where to cut and stick
    stefaniea57611104
      I have an inkscape document which is Din A2 size. I want to convert it to a PDF-File containing Din A4-pages which can be printed out on home printers and then easily cutted and sticked together.
      I tried various times (printing PDF in Din A2, then again printing in Din A4 using the poster function) but
      -  how can I include a border on every Din A4-page to make sure that everything lies within the printable area
      - without shrinking the original size of the document
      - including marks ON the sheeds, ideally numbered, showing where to cut and stick
      - as it is not a poster but a pattern it would be fine seeing these marks even after having cut and sticked
      I hope one can help and plese tell me, which Adobe-Version I need - currently I have a test version of Adobe DC and I just don't come through.
      Thanks so far!
      [Moved out of (the mostly defunct) Print Design forum and into an Acrobat-specific forum - moderator]
        • 1. Re: Poster Printing - Including marks where to cut and stick
          jdanek Level 4
          There are a couple of ways to do what you want, 1.) is using Adobe Illustrator, the other is using 2.) Adobe Photoshop:
          Open the Inkscape file using 1.) Illustrator > View > Show Page Tiling; use the Page tool and print the selected page area; in other words, align the Page to where you want to print, but instead of printing > Save As > PDF.  2.) Using Photoshop, open the Inkscape file as a .tiff @ 150ppi @ RGB ( or CMYK ) > Set the Rectangle tool to a size slightly smaller than A4 ( you will have to determine how much bleed you will want to include in the capture > in PS use guides to divide the original poster into A4 sections > use the Rectangle tool to select each tile > Copy each tile and paste into a new PS document > Save As > Photoshop PDF.
          The methods above will not shrink the original.
          You would be better off using Illustrator for that > Open PDF created above ( one of tiles ) in Illustrator > you should see the page margins used in the print-to-PDF op > manually add trim marks and tile number.
          Yes, but you probably won't because each page will be trimmed to assemble the final poster.
          • 2. Re: Poster Printing - Including marks where to cut and stick
            stefaniea57611104 Level 1
            Thank you very much for your help, this is a great support!
