I have scanned documents at 300 dpi and some at 600 dpi, when I OCR the file some of the files shrink in size. Does this process take the image back to a 150 dpi or does it stay at 300 or 600 dpi? Is there a compression factor in the OCR?
What settings do you use?
As mentioned I scanned documents at 300 & 600 dpi. When I OCR I use the enhanced scan option and have the system convert image to text. Not sure what other setting your talking about.
I mean the settings at "Recognize Text".
currently my setting are at:
Document Language: English
Output: Searchable Image (Exact)
Downsample to: Field is grayed out.
Just noticed that if I switch Output to Editable Text and Images, downsample to field is set at 600 dpi.
This may fix my problem, is that what I need so keep the 600 dpi on my documents?
Searchable Image (Exact) will not modify your scanned images:
Well I used the
This did reduce my file size from 4.4MB to 1.5MB. I'm ok with this as long as the file clarity is not compromised.
