I was trying to automate the rendering process by operating aepx file and then rendering with aerender executable.
It worked fine sometimes that I replace footages by setting the "fullpath" property of <fileReference> node in aepx file.
However, I found the approach does not work if I replace the original image with another one that is not in the same folder.
Anyone could help with experience on operating aepx file?
BTW: Same problem is already encountered before, as mentioned in :
https://forums.adobe.com/thread/1226083
Thanks a lot.
Hi robertw,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
