• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
[Q] Illustrator seems forgeting what selected after 50 sec on Mac. How to avoid?
Contributor ,
Jun 14, 2017 Jun 14, 2017
I'm not sure what's going on the detail, but it seems only on Mac with Illustrator CC 2017. Windows seems fine.
Currently my code is monitoring what object selected and significant performance issue on certain case.
I got workaround to work, but I'd like to know if there's better solution.
It is from CEP plugin JavaScript file and used CSInterface.evalScript() to call JSX.
JSX part is simple and only accessing followings:
     documents.length
     activeDocument.selection.length and typename
On Windows (i7 2.5GHz machine), it responds about 9 - 15 ms.
On Mac (i7 2.5GHz machine), it responds 20-40 ms. It's obviously slower than Windows.
But if I left for over 50 sec, it responds 2 - 30 second (not millisecond) on Mac.
Illustrator is foreground.
Second request become fast as usual.
My current workaround is ping above function every 10 second and avoid Illustrator forget the selection.
I tried ping with app.version instead of above selection code, so I think it's not CEP or app object part.
Is there any better solution?
Thank you,
Naoki
TOPICS
Scripting
Views
724
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Jun 16, 2017 Jun 16, 2017
It's funny, I never seen such case.
Here is a sample code of get notifications from plugins
var csInterface = new CSInterface();
csInterface.addEventListener("com.custom.csxs.events.selectionChanged", function(payload){
  alert(payload.data);
Some my hybrid extensions have similler conponents and almost work fine in my Mac.
Can you show me more detail?
Votes
Translate
Translate
Report
Report
Contributor ,
Jun 19, 2017 Jun 19, 2017
Ten A
Thank you very much for the tips.
Is your hybrid extensions event from Plugin SDK (C++) or Extention Builder (ActionScript)?
I probably have to do same way.
Following is the current code and need to improve.
CEP JS is calling JSX with evalScript().
1) It is polling every 100 ms in certain state when Illustrator is in foreground.
2) Other time is every 10 sec in foreground mode.
3) It was polling every 10 sec when Illustrator is in background.
It has flag to avoid duplicate request.
a) JSX part execution time is 120 - 180 micro second on i7 2.5GHz Mac.
b) CEP JS / JSX part has a lot of over head and responding 20 - 50 ms in most of the case.
The issue happens after 30-40 sec (50 sec is for sure),
above b) response become 2 sec to 30 sec (not miliseconds).
Then it does not recover and Illustrator does not respond in regular timing via CEP JS/JSX.
Regular operation on Illustrator UI seems fine though.
The only way to recover I far as I know is call $.gc() from ExtendScript Tool Kit.
Restarting Illustrator does not help.
I think it might be related garbage collector, but not really sure.
So I put $.gc() in following jsxFunc() part. It seems helped some case.
But it still get into unresponsive state.
I appreciate any suggestions.
Thank you,
Naoki
CEP / JavaScript
console.time("polling"); // performance measurement (NodeJs)
adobe_iface.evalScript("jsxFunc()", function (response) {
    console.timeEnd("polling"); // performance measurement (NodeJs)
    // other tasks
JSX
function jsxFunc(){
    $.hiresTimer; // reset
    $.gc(); // Garbage collector
    var result = "Unsupported";
    try{
        if(documents.length){
            var _sel = activeDocument.selection; // TextRange when Text chars are selected
            if("TextRange" == _sel.typename){ // Text char selected
                var _target = _sel;
                result = "TextRange";
            }else if(0 != _sel.length){ // Array: Single and Multiple items case
                for(var i=0; i<_sel.length; i++){
                    if(i == 0){
                        result = _sel.typename;
                    }else{
                        if(result != _sel.typename){
                            //$.writeln("Got Mixed"); // debug only
                            result = "Mixed";
                            break;
            }else{ // No selection
                result = "NoSelection";
        }else{
            // no doc opened
    }catch(e){
        $.writeln("EXCEPTION: ", e);
    $.writeln("jsxFunc: result = ", result, " ", $.hiresTimer, " \xB5s"); // micro second
    return result;
Recovery code / JSX
#target illustrator
$.gc();
$.writeln("GC done: time = ", $.hiresTimer, " \xB5s"); // micro second
Votes
Translate
Translate
Report
Report
Community Expert ,
I understand your solution. Probably, There are some complication problems in background and its difficult to clearly all thing.
However, Most easy way to monitoring selection targets is using kAIArtSelectionChangedNotifier in native object.
Here is a demo movie.
https://www.youtube.com/watch?v=jmqbrARzwME
In this case, The plugin is monitoring what objects selected and if selection changed the plugin notify messege to CEP extension.
Votes
Translate
Translate
Report
Report
Contributor ,
Jun 20, 2017 Jun 20, 2017
Ten A
Thank you very much for the video and the pointer.
Your following article was also very helpful.
  notifierの設定 - 手抜きLab@DTPの現場
I could manage to update MarkedObjectsUI sample code from CC 2017 SDK package
and monitor selection change event in CEP's JavaScript code.
Thank you very much,
Naoki
Votes
Translate
Translate
Report
Report
Guru ,
Jun 18, 2017 Jun 18, 2017
It sounds like Illustrator might be going to sleep in the same way that the ESTK can.
There's a well know terminal command to stop it doing that.
The fix at the end of Re: ID CC 2014 plus ExtendScript (Yosemite) slow to the point of not working...  might solve the problem.
Also there's grefel's fix there.
Might work, might not. Please get back with the result.
HTH
Trevor
Votes
Translate
Translate
Report
Report
Contributor ,
Trevor,
Thank you very much for the pointer.
It looks like one or multiple app or service got into the issue.
The problem code is for targeting end user environment, so I cannot take the solution.
It seems similar code works fine on Photoshop and InDesign on Mac though.
Thank you,
Naoki
Votes
Translate
Translate
Report
Report
Contributor ,
Jun 23, 2017 Jun 23, 2017
LATEST
I revisited this solution for disabling App Nap on Illustrator only.
Following seems working from short term testing and did not show any slowness..
That is command to run in Terminal.
After done, Illustrator need to restart.
Turn off App Nap for Illustrator (not default setting)
defaults write com.adobe.illustrator NSAppSleepDisabled -bool true
Resume default: App Nap for Illustrator
defaults write com.adobe.illustrator NSAppSleepDisabled -bool false
Thank you,
Naoki
Votes
Translate
Translate
Report
Report
