8 Replies Latest reply on Jun 30, 2017 2:23 AM by mark@headTrix
    how to limit the area of custom cursor
    ratna_282017 Level 1
      hello, I'd like to limit the area of my custom cursor only inside the rectangle shown below, is it possible? and how is the code? thank you very much
        • 1. Re: how to limit the area of custom cursor
          mark@headTrix Adobe Community Professional
          Yes, check this out!
          OLDER FORMER POST - QUESTION ANSWERED
          Can I confine my cursor to a specific area on my stage?
          hope that helps!
          mark
          • 2. Re: how to limit the area of custom cursor
            hello headTrix, thanks for your help, the script you suggest was written in as3, I've tried to write in as2,  here are my script:
            onClipEvent(mouseMove) {
              var topNum:Number=200;
              if(_xmouse<topNum)
              brush.enabled=true;
              _root.brush._x = _root._xmouse;
              _root.brush._y = _root._ymouse;
              trace("oke");
              else
              brush.enabled=false;
            the trace showed "oke", but the brush still visible all around the stage. where did I get it wrong? thank you
            • 3. Re: how to limit the area of custom cursor
              Hi Ratna,
              I know its possible, I've done it in Flash Actionscript 1.0, and AS3... its been a while since I've programmed in Actionscript.
              But maybe knowing that its possible, and this code can help get you started in the right direction!
              function startScroll(e:MouseEvent):void {
              var ypos:Number = e.currentTarget.y
              var xpos:Number = e.currentTarget.x
              e.currentTarget.startDrag(false,new Rectangle(-xpos,ypos,stage.stageWidth,0));
              something like that!
              hope that helps!
              mark
              • 4. Re: how to limit the area of custom cursor
                hi there,
                its a bit tough to sort through code or to test since I only have Animate CC 2017
                but for AS2 check out this start drag function
                public startDrag([lockCenter: Boolean], [left: Number], [top: Number], [right: Number], [bottom: Number]) : Void
                Parameters
                lockCenter: Boolean [optional] - A Boolean value that specifies whether the draggable movie clip is locked to the center of the mouse position (true), or locked to the point where the user first clicked the movie clip (false).
                left: Number [optional] - Value relative to the coordinates of the movie clip's parent that specify a constraint rectangle for the movie clip.
                top: Number [optional] - Value relative to the coordinates of the movie clip's parent that specify a constraint rectangle for the movie clip.
                right: Number [optional] - Value relative to the coordinates of the movie clip's parent that specify a constraint rectangle for the movie clip.
                bottom: Number [optional] - Value relative to the coordinates of the movie clip's parent that specify a constraint rectangle for the movie clip.
                Hope that helps!
                mark
                • 5. Re: how to limit the area of custom cursor
                  So many thanks for your response sir
                  I explored your suggestion but still can't get how to write the syntax in as2.
                  Then I tried stating the var like the following script, and it works.
                  Thanks again for your referral
                  onClipEvent(enterFrame){
                  var leftBoundary:Number = 147.95;
                  var rightBoundary:Number = 1053.6;
                  var topBoundary:Number = 199.95;
                  var bottomBoundary:Number = 709.75;
                  if (_root._xmouse > leftBoundary && _root._ymouse > topBoundary && _root._xmouse < rightBoundary && _root._ymouse < bottomBoundary)
                    this._x = _root._xmouse;
                    this._y = _root._ymouse;
                  else
                    this._x = 788.6;
                    this._y = 354.9;
                  • 6. Re: how to limit the area of custom cursor
                    HI!
                    Glad that you were able to get it to work! Seems a bit complex!
                    For kicks and giggles ... you can try this
                    name_of_MC.onPress = function() {
                      this.startDrag([lockCenter: True], [left: Number], [top: Number], [right: Number], [bottom: Number]) : Void
                    name_of_MC.onRelease = function() {
                      this.stopDrag();
                    Maybe this image can help explain how you can put in the numbers in the script above.
                    Hope that helps!
                    mark
                    • 7. Re: how to limit the area of custom cursor
                      Thank you so much Sir!
                      Here is the following script I use as you suggest:
                      on(press){
                      startDrag(this, true, 147.95, 199.95, 1053.6, 709.75);
                      _parent.kuas = true;
                      It works really well, and move "smoothly", way better than the previous one I used.
                      • 8. Re: how to limit the area of custom cursor
                        Woo HOO! So glad I could help and that you got it working... with the clean easy code!
                        Good job!
