13 Replies Latest reply on Jun 24, 2017 6:02 AM by D Fosse
    Color setting synchronisation issue
    catheriner95250316
      Hi all,  I just purchased a new monitor (BenQ SW2700PT) and have now noticed that the colours are very different between different CC applications on the same monitor. In Bridge, under Color settings, it says that CC applications are synchronised but I am still seeing quite a difference.
      Bridge and Camera Raw colors seem to be the same but Photoshop is not.
      Has anyone else had this problem? Any help will be very much appreciated.
        • 2. Re: Color setting synchronisation issue
          D Fosse Adobe Community Professional & MVP
          If there is a difference between color managed applications (e.g. Photoshop and ACR), you have a defective monitor profile. This often affects applications differently. You need to rerun your calibrator, and make sure it's set to produce v2, matrix-based profiles - not v4 and/or table-based. The latter policies are known to be problematic in some scenarios.
          The color settings determine document profile policies. That's not the issue here. This is the monitor profile. So don't worry about the synchronisation message - there's no particular need to have them synchronized anyway (mine deliberately aren't).
          Note that applications without color management will never display correctly on a wide gamut monitor. That's the deal you implicitly accept when buying one. There's nothing you can do to ever make them display correctly (except "dumb it down" to sRGB, but then it's no longer wide gamut). You need to use color managed software only.
          2 people found this helpful
          • 3. Re: Color setting synchronisation issue
            NB, colourmanagement Adobe Community Professional
            Hi Catherine,
            D Fosse has made some helpful suggestions.
            Rather than using your own photo or n image you've created, I would take a known "test" image and use that to make some checks,
            [a "test" image is useful because it's generally a composite of various images including skin-tone and other "memory colours" - which means that even without a reference proof print you can tell pretty much is the appearance is in the ballpark.]
            - you can download my test image in CMYK or RGB as preferred here for free:
            [ downloads | colourmanagement.net   ].
            Next, open that image in all the apps you are having issues with and compare the appearance.
            Photoshop would be the reference application if I were making this test.
            Note: If an app warns you about the document (image) causing an embedded profile mismatch, then just accept the document's embedded profile.
            Maybe do that test now, then calibrate the Benq and repeat the test.
            Testing and good notes are the secret behind a lot of such issues.
            Using V2 profiles [in this case your display profile] is a good policy generally, as D Fosse wrote, V4 ICC profiles can cause issues with some applications.
            Please let us know how you get on.
            I hope this helps
            if so, please do mark my reply as "helpful", so others who have similar issues can see the solution
            thanks
            neil barstow, colourmanagement
            • 4. Re: Color setting synchronisation issue
              catheriner95250316 Level 1
              Hi D Fosse,
              Thank you for your advice. I'm waiting for my calibrator to arrive. It should be here early next week and will follow your advice and let you know how it goes.
              • 5. Re: Color setting synchronisation issue
                Hi Neil,
                Thanks for your advice. I downloaded your test image and on my monitor it looks great in photoshop, but definitely not in Bridge and ACR.  I'll have to wait a few days now for my calibrator to arrive.
                I'll let you know how it looks after I have recalibrated.
                Kind Regards
                Catherine
                • 6. Re: Color setting synchronisation issue
                  Hi Catherine
                  When I view that image in Bridge and in Camera RAW I see the same appearance throughout.
                  However, try this,
                  in Photoshop make a copy of my test-image, go to edit / convert to profile - and convert to sRGB
                  save the file with a new name, I suggest you include "sRGB" in there
                  now open the sRGB version in Bridge and in ACR.
                  I'd be interested to know if that makes any difference?
                  I hope this helps
                  if so, please do mark my reply as "helpful" and if you're OK now, please mark it as "correct" below, so others who have similar issues can see the solution
                  thanks
                  • 7. Re: Color setting synchronisation issue
                    Hi Neil,
                    I did as you suggested and not really any difference with the sRGB copy. Maybe a slight improvement.
                    If I view an image on my laptop screen, it looks the same in Photoshop, Bridge & ACR, but not on the monitor. I'll try recalibrating and see if that solves it.
                    Thanks again for your help.
                    Catherine
                    • 8. Re: Color setting synchronisation issue
                      gator soup Level 4
                      try running a copy of the WHACKED RGB PDI target through your apps to be sure your settings aren't doing you in
                      DOWNLOAD PDI TEST IMAGE Photodisc Color Management Calibration Target Reference Image Baby Faces How To Achieve True Pri…
                      READ THE FULL TIPS & INSTRUCTIONS...
                      Expert Tips & Instructions about how to use the PDI reference images in Photoshop:
                      You always want to open a tagged Getty-Photodisc image (PDI) "using its embedded profile":
                      • Do not Convert its tagged/embedded ICC Profile to a different Profile
                      • Do not Assign or Assume another Profile
                      • Do not alter these PDI images in any way
                      • Do not save over them
                      Some Adobe color-management policy settings will mysteriously Assign or Assume (apply) the wrong profile and/or Convert to a different profile — so be positive you are using my original document profile imprinted on each image, and have not inadvertently ignored or Converted or Assigned or Assumed the wrong source profile behind the scenes.
                      OPEN THE PDI IMAGE CORRECTLY IN ADOBE PHOTOSHOP:
                      "Use the embedded profile (instead of the working space)" is always the correct first move when opening documents with embedded ICC color profiles that do not match Photoshop's working profile...
                      • 9. Re: Color setting synchronisation issue
                        Hi Catherine
                        great
                        so that rules out one possible issue I think.
                        on my system the appearance is very similar between those applications so there is plainly an issue with your system
                        I would indeed follow DFosse's advice and recalibrate then go from there.
                        • 10. Re: Color setting synchronisation issue
                          Is this a laptop + external monitor setup? In other words there are two displays here?
                          When your calibrator arrives try that first. A fresh new profile is always the first step in any display troubleshooting. However - there may be a second thing to try if you still see a difference.
                          It could be you've been bitten by a rather obscure and unpredictable bug that causes ACR to use the wrong monitor profile. So if you have the ACR window up on the BenQ, it may still use the laptop display's profile - while Photoshop itself does it correctly.
                          The way it's been described to me, ACR uses the primary display's profile (in your case laptop) even when the application window is on the secondary display (in your case the BenQ). I don't know it the opposite can happen too. Anyway, this obviously isn't how it should work.
                          A way to test this is to switch primary and secondary display assignment in the OS if possible. You can also - purely for testing purposes! - set the BenQ profile as default for both screens. If everything then displays correctly on the BenQ (nevermind the laptop) - then this is likely the problem.
                          • 11. Re: Color setting synchronisation issue
                            Hi gator soup,
                            I wasn't able to open the downloaded files for some reason.  In the meantime, my issue seems to have been fixed by following the advice of D Fosse.  Thanks for your help
                            • 12. Re: Color setting synchronisation issue
                              Hi D Fosse,
                              While waiting for the calibrator to arrive, I thought I'd try your suggestion about switching the primary and secondary display assignment. It worked! The color difference is now very minimal. Thanks heaps for your advice. I really appreciate everyone's help.
                              • 13. Re: Color setting synchronisation issue
                                This isn't something that happens often, but when it does, it's always in a laptop + external configuration - both Windows and Mac. It's hard to tell whether it's a bug in ACR, or it's some kind of hardwired laptop behavior that overrides ACR.
                                Anyway, a new profile from the calibrator should clean up the rest. When you say "minimal" difference, that's still too much. ACR and Photoshop should always be absolutely identical. When they're not, the problem is nearly always in the monitor profile.
                                The thing is, even if both end up in the same monitor profile, the source profiles are very different - and so the conversion itself, the actual math, is also different. One works in linear gamma ProPhoto, the other works with rendered files in sRGB, Adobe RGB or gamma 1.8 ProPhoto. Different calculations to end up in the same destination/monitor profile.
