I am using PS CC. I have an image pasted into a layer. The image is smaller than the layer canvas. I can select the image with the move tool, resize the image using the handles, and move the image around on the layer canvas, and I can delete the image. How do I copy just the iimage and past it into a new file without copying the entire canvas in the layer? I have tried dragging the image over but I always get the whole canvas.
Hi
If you are working with separate windows:
1. Select the area you want in the first document with the marquee tool
2. With the move tool drag over to the other window and release on the canvas
If you are working with tabbed documents:
1. Select the part you want in the first document
2. With the move tool click and drag the selected area onto the tab for the second document and hold while Photoshop switches to the second document then whilst still holding drag down onto the canvas and release
Dave
Hi Jim_Palik,
You may simply drag the layer on top of the new document and it should work fine.
You may also refer How to copy layers from one Photoshop document to another? - Graphic Design Stack Exchange
Akash
Hi
Dave
Are you asking how to move the contents of a layer to a new file?
If you are asking how to move a selection within a layer to a new file:
