1. Re: Photoshop CC (2017) Showing desaturated/less contrasty images compared to LR
D Fosse Jun 15, 2017 11:04 AM (in response to john76269000)Can you post a side-by side screenshot?
What calibrator are you using?
BTW there's no particular reason color settings should match, you can set them to whatever you like independently. Photoshop will preserve any incoming profile.
3. Re: Photoshop CC (2017) Showing desaturated/less contrasty images compared to LR
D Fosse Jun 15, 2017 1:43 PM (in response to john76269000)Ah, this isn't about color profiles. It's about different on-screen resampling algorithms with extremely noisy (or binary) images. Yes, stars are equivalent to noise in this context.
You need to view both at 100%, or 1:1, which maps exactly one image pixel to exactly one screen pixel. This is the only really truthful representation of the file. Then they will be identical.
On-screen scaling softens the image, and the effect varies with different algorithms.
4. Re: Photoshop CC (2017) Showing desaturated/less contrasty images compared to LR
john76269000 Jun 15, 2017 4:41 PM (in response to D Fosse)Hmmm ... thanks for the insight. But how do I workaround this? I mean, when i take the images to PS from LR after the initial editing for blending etc (like in this case blending in a different exposure for fg), it's changing the look of the images a bit. Is there anyway I can minimize the issue for night sky shots?
Also, you are spot on, I actually don't see any issue for daytime landscapes. That's why I probably didn't notice it before.
5. Re: Photoshop CC (2017) Showing desaturated/less contrasty images compared to LR
D Fosse Jun 15, 2017 10:17 PM (in response to john76269000)There's no workaround as such. When you display, say, a 6500 pixel image using 2500 pixels on screen, something has to go. The question is what. How do you treat a 2-pixel sharp transition when you have less then a pixel to do it?
In a normal photograph this isn't a noticeable problem. But when you have lots of very sharp pixel transitions - noise or stars - there are different ways to do it.
If 100% is too close, try the regular intervals like 50 or 25, rather than fit or fill.
6. Re: Photoshop CC (2017) Showing desaturated/less contrasty images compared to LR
john76269000 Jun 16, 2017 10:12 AM (in response to D Fosse)Ok, I see what you are saying. Thanks a lot for clarifying this. It's not a huge difference .... I can apply a little edit in LR to make it look same for publishing in web (which wont be viewed as 1:1).
Thanks a lot!
