• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
problem printing PSDs through indesign
New Here ,
Jun 15, 2017 Jun 15, 2017
Hi, I'm having a problem with psd files printing from indesign. They are cutout car images with hard lines like door edges, when printed directly from photoshop these lines are smooth. When printed through indesign these become jaggy. The are better when converted to jpegs but that's no use as they need the layers. Any thoughts? All software is up-to-date.
Views
539
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 15, 2017 Jun 15, 2017
That's not a rule of thumb, it's a myth.
That said, I would echo the advice to save as PDF from Photoshop and to print a PDF from InDesign.
Finally, if the OP is determined to print from InDesign they should check to be sure that Send image data is set to all instead of optimized subsampling.
Votes
Translate
Translate
Community Expert ,
Have you saved your psds with Maximum Compatibility turned on?
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Bill. Yes, that on. Just double checked, still the same. I don't know if it's relevant but the file is 60mb and brought in at 40% in indesign.
Votes
Translate
Translate
Report
Report
Community Expert ,
If you're using vector objects in Photoshop (like a vector mask), you should save as Photoshop PDF not Photoshop (PSD) files.
PSD files always turn the vectors into pixels at the resolution of the image. PDF files preserve the vector hard edges. InDesign will have no problem placing Photoshop PDF files.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Steve, no there are no vector objects. they are very stripped back, just a cutout car on one layer and shadows on another.
Votes
Translate
Translate
Report
Report
New Here ,
Interestingly saving as a PDF it did solve the jaggies on the hard lines, but because the cars are being put on solid colour backgrounds it created another problem in that the shadows aren't overprinting (they come up light on a dark background. So it needs to be a psd, if only I can get to the bottom of this odd behaviour!
Votes
Translate
Translate
Report
Report
Community Expert ,
For print work it is the general rule of thumb that Photoshop images should be imported into InDesign at 100% with a resolution of 300 ppi. I tried to duplicate your problem using (100%/300 ppi) images that had been silhouetted in Photoshop and they looked as good as when printed directly from Photoshop. Hopefully, that will solve your problem.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks again Bill, But it's not viable to resize the images every time, they will be used by different people on many jobs with fast turnarounds and constantly changing layouts!
Votes
Translate
Translate
Report
Report
Community Expert ,
In the large agency where I work that is just a fact of life—inconvenience breeds quality. I would suggest trying the resize I suggested just to see if that is the problem.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
You say, you print from InDesign. Why are you not exporting a PDF and print from Acrobat. In most cases the result is better.
Votes
Translate
Translate
Report
Report
New Here ,
In answer to Willi, we did make a print PDF with the same result. Saving the image as pdf, the shadows don't work on dark backgrounds. But Bob has cracked it, it's a Send image data issue, with all checked the jaggies are gone!
Votes
Translate
Translate
Report
Report
New Here ,
Jun 16, 2017 Jun 16, 2017
LATEST
Just as an update, making the PDF with no downsampling also fixed it.
Votes
Translate
Translate
Report
Report
