I have several time-consuming Photoshop scripts and want to adjust them. Execution time is a measure of script efficiency for my goals. Hence, I want to measure the execution time of a Photoshop script. Any help would be highly appreciated.
var totalTime = new TimeIt();
... do cool stuff ...
totalTime.stop();
// log it out
totalTime.getTime();
function TimeIt() {
// member variables
this.startTime = new Date();
this.endTime = new Date();
// member functions
// reset the start time to now
this.start = function () {
// reset the end time to now
this.stop = function () {
// get the difference in milliseconds between start and stop
this.getTime = f
...Copy link to clipboard
totalTime.stop();
// log it out
function TimeIt() {
// member variables
// member functions
this.getTime = function () {
return (this.endTime.getTime() - this.startTime.getTime()) / 1000;
// get the current elapsed time from start to now, this sets the endTime
this.getElapsed = function () {
this.endTime = new Date(); return this.getTime();
Thanks a lot for answering!!! But, sorry for misunderstanding!!! It was my fault when formulating the question! I need a script to measure the execution time of Photoshop Actions. Sorry!!!
Create a jsx file with the code above.
Replace this line:
whit this line:
doAction("ActionName", "ActionSetName");
replace the last line with:
alert(totalTime.getTime());
All working!!! Thank you so much!!!!
I suggest use high resolution timer or buil-in profiler in extend script toolkit.
$.hiresTimer
reading this timer get time of script execution and it also reset timer. So I suggest do first dummy reading for reseting timer at some point and second reading will show you how much time script spend since first reading.
Thank you for answering, but I am new to scripting hence I do not understand how and where to use $.hiresTimer to solve my issue in Photoshop...
//reset timer
$.hiresTimer;
//something you want measure
var a = app.activeDocument.artLayers.add();
var b = app.activeDocument.artLayers.add();
var c = app.activeDocument.artLayers.add();
//show message and read time
alert("Time: "+($.hiresTimer/1000000)+"s");
//reset timer beacause we don't want measure how long take click to "OK" button
$.hiresTimer;
a.remove()
b.remove()
c.remove()
I want to measure the time of a Photoshop Action... like doAction("ActionName", "ActionSetName");
What strings should I use instead of
and
a.remove()
Thank you very much for helping me!!!
There would be lines of code... something like you wrote. I don't know how to run recorded action.
