9 Replies Latest reply on May 24, 2006 8:38 AM by Newsgroup_User
    FLASH PRELOADING PRIORITIES
    Level 7
      hi,
      my 300kB swf file has 57% of its size in 1.st frame. Even if the first
      frame is blank. I placed simple preloader there and the PRELOADER SHOWS
      AFTER 57%. I'm desperate - such a preloader is useless...
      I guess that there are some embedded fonts initializing in 1.st frame or
      something. Is there some way to tell flash to load my preloader first?
      some kind of priority or something.
      thanks
        • 1. Re: FLASH PRELOADING PRIORITIES
          hsheffer
          hi there
          I had the same question (published under actionscript forum):
          "I read a few articals on preload, I tried cuple of different methods, but the same problem kips not letting it work:
          The first 2 frames contains ONLY the preload stuff. the rest of the movie from frame 3 contains heavy stuff (700 KB).
          When I check the movie in the bandwidth profile it shoes me that the first frame contains all the 700 KB.
          What happends is that the preload movie is not working until all the movie is loaded - and then I dont need it any more...
          Did I do anything wrong?
          Waiting with you for help!
          • 2. Re: FLASH PRELOADING PRIORITIES
            Level 7
            This is because you have stuff in your movie that is set to be loaded before frame 1 - like embedded
            font, or items in library set for linkage export via actionscript. these will be loaded before frame
            1 and subsequentally before any preloader.
            --> **Adobe Certified Expert**
            --> www.mudbubble.com
            --> www.keyframer.com
            Pepa wrote:
            > hi,
            > thanks
            • 3. Re: FLASH PRELOADING PRIORITIES
              Level 7
              thanks chris
              your post was inspiring and really helped, I unchecked all "export in
              1.st frame" fields, but still my preloader starts at 48%
              I've used pretty much embedded fonts, but don't know how to tell flash
              to embedd them after frame1.
              any idea?
              THANKS
              > before frame 1 - like embedded font, or items in library set for linkage
              > export via actionscript. these will be loaded before frame 1 and
              > Pepa wrote:
              >> hi,
              >> SHOWS AFTER 57%. I'm desperate - such a preloader is useless...
              >> or something. Is there some way to tell flash to load my preloader
              >> first? some kind of priority or something.
              >> thanks
              • 4. Re: FLASH PRELOADING PRIORITIES
                Level 7
                thanks chris
                (I embedd fonts by clicking on properties panel -> EMBED, not via library)
                any idea?
                THANKS
                > Pepa wrote:
                >> hi,
                >> thanks
                • 5. Re: FLASH PRELOADING PRIORITIES
                  Level 7
                  check this out:
                  http://groups.google.com/group/macromedia.flash.actionscript/browse_thread/thread/c37a96a1 c4142ffb/086e5bb544c08621?lnk=st&q=frame+1+embed+fonts+group%3A*flash*&rnum=7&hl=en#086e5b b544c08621
                  There is a way to go into publish settings, flash tab, set AS to AS 2.0 and click Settings next to
                  it - and tell it not to embed fonts in frame 1 (my mistake earlier - there is no frame "0").
                  Pepa wrote:
                  > thanks chris
                  > any idea?
                  > THANKS
                  >> linkage export via actionscript. these will be loaded before frame 1
                  >> Pepa wrote:
                  >>> hi,
                  >>> first frame is blank. I placed simple preloader there and the
                  >>> PRELOADER SHOWS AFTER 57%. I'm desperate - such a preloader is
                  >>> useless...
                  >>> thanks
                  • 6. Re: FLASH PRELOADING PRIORITIES
                    Level 7
                    i sent too soon - publish settings > Flash > Settings (next to AS version) > Export Frame for
                    Classes: type in a different frame number (after your preloader but before your text is used in your
                    movie). OK - test movie.
                    Pepa wrote:
                    > thanks chris
                    > any idea?
                    > THANKS
                    >> Pepa wrote:
                    >>> hi,
                    >>> useless...
                    >>> thanks
                    • 7. Re: FLASH PRELOADING PRIORITIES
                      Level 7
                      another way is to open Library - upper right corner "Add Font..." and follow the menus. then drag an
                      instance of this movie clip containing your text field with embedded font to frame after preloader.
                      Font should get loaded on this frame.
                      Pepa wrote:
                      > thanks chris
                      > any idea?
                      > THANKS
                      >> Pepa wrote:
                      >>> hi,
                      >>> useless...
                      >>> thanks
                      • 8. Re: FLASH PRELOADING PRIORITIES
                        Level 7
                        CHRIS, you're great!
                        now it starts at about 3% ... COOOOOOOOOL
                        I work with flash for over 2years but there is still sooo much to explore
                        THANKS A LOT!
                        > check this out:
                        > and click Settings next to it - and tell it not to embed fonts in frame
                        > Pepa wrote:
                        >> thanks chris
                        >> any idea?
                        >> THANKS
                        >>> Pepa wrote:
                        >>>> hi,
                        >>>> useless...
                        >>>> frame or something. Is there some way to tell flash to load my
                        >>>> preloader first? some kind of priority or something.
                        >>>> thanks
                        • 9. Re: FLASH PRELOADING PRIORITIES
                          Level 7
                          cool!
                          yeah i have been using flash for 8 years and there's is always something new to learn.
                          > explore
                          > THANKS A LOT!
                          >> check this out:
                          >> 2.0 and click Settings next to it - and tell it not to embed fonts in
                          >> Pepa wrote:
                          >>> thanks chris
                          >>> flash to embedd them after frame1.
                          >>> any idea?
                          >>> THANKS
                          >>>> loaded before frame 1 - like embedded font, or items in library set
                          >>>> frame 1 and subsequentally before any preloader.
                          >>>> Pepa wrote:
                          >>>>> hi,
                          >>>>> useless...
                          >>>>> thanks
