1. Re: No green maximize button in Photoshop open window
gener7 Jun 16, 2017 9:19 AM (in response to photoguyscott)The problem is that the Open dialog box is a abbreviated OSX system box that Photoshop calls up. It's not part of Photoshop.
If you need something more robust, try Bridge CS6. There you can customize a full screen dialog and since it's the old style Flash panels, you can call it up inside Photoshop as Minibridge. You can also adjust thumbnail sizes and even resize the dialog to your workflow.
It's a better way to go since the OSX dialogs are limited.
2. Re: No green maximize button in Photoshop open window
photoguyscott Jun 17, 2017 8:19 AM (in response to gener7)Thanks, I figured that it was something like that, but I didn’t have that problem with Yosemite. Do you know is that something that Mac will address in the future or does it usually stay like that? I do use Bridge, but after so many years of opening images the same way in Photoshop, it is hard to change. Thanks for your help.
3. Re: No green maximize button in Photoshop open window
John T Smith Jun 17, 2017 8:44 AM (in response to photoguyscott)You will have to ask Apple
4. Re: No green maximize button in Photoshop open window
gener7 Jun 17, 2017 11:42 PM (in response to photoguyscott)Well, I did try something and it seems to stick. Move your cursor to the edge of the Open dialog until it becomes a double arrow.
Double-click on that arrow and the window will extend to the edge of the screen. Repeat for all sides until you have a full screen window. It stays that way after closing and opening Photoshop. I use CC 2017 with OSX 10.12.5 and it does work. I don't know about CS6.
5. Re: No green maximize button in Photoshop open window
Conrad C Jun 17, 2017 9:58 AM (in response to gener7)1 person found this helpfulgener7 wrote
Move your cursor to the edge of the Open dialog until it becomes a double arrow. Double-click on that arrow and the window will extend to the edge of the screen. Repeat for all sides until you have a full screen window. It stays that way after closing and opening Photoshop. I use CC 2017 with OSX 10.12.5 and it does work. I don't know about CS6.
One way to speed that up: Hold down the Option key and drag any corner of the Open dialog box. Holding down Option should scale the entire dialog box out from the center.
photoguyscott wrote
I have a ton of files that I need to search through on a regular basis and having a full screen window in the dialog box certainly helps. Thanks
For searching and opening many files quickly, I think the Open dialog box is too slow; it might be faster to bypass it entirely. Instead, do your searching in whatever program you do it most quickly, whether that's the Mac Finder, or a photo organizer like Adobe Bridge or Lightroom. Then just drag and drop the image (or as many selected images as you want) into Photoshop or onto its application icon.
