2 Replies Latest reply on May 23, 2006 6:05 AM by Newsgroup_User
    rotate object
    sopphinken Level 1
      Is there anyway to rotate an object around another object's pivot?
        • 1. Re: rotate object
          James Newton, ACP Level 3
          There are several ways. You can set the other object to be the parent of the object to rotate. You can use multiply() with the transforms of the pivot object and the object to rotate. Or you can simply use the following syntax with the rotate() method:
          v3DMember = member("3D Member Name")
          vObjectToRotate = v3DMember.model("Rotating Object Name")
          vPivotObject = v3DMember.model("Pivot Object Name")
          vPosition = vPivotObject.worldPosition
          vAxis = randomVector() -- replace with the (unit) vector that defines the axis of rotation
          vAngle = random(360) -- replace with the angle you want to turn
          vObjectToRotate.rotate(vPosition, vAxis, vAngle, #world)
          • 2. Re: rotate object
            Level 7
            Take a look at rotate in the dictionary and the optional parameter
            relativeTo.
            Agust�n Mar�a Rodr�guez
            www.onwine.com.ar > Macromedia Director demos & code
